[opa-nightly-tests] jelly OPA_Daily_Tests_1128Tue
hdftest hdftest at hdfgroup.org
Wed Nov 29 00:20:48 CST 2023
*** OPA Tests on 1128Tue ***
   Tests Summary
   Tests Time Summary
jelly: Ran 6(0/0/0) hosts, Grand total test time =  20m 43s
   Timekeeper log
Timekeeper started at Wed Nov 29 00:00:17 CST 2023
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Wed Nov 29 00:20:17 CST 2023, looking for processes to terminate...
terminating process PID.jelly_jelly (48311)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
terminating process PID.koala_koala (48394)
terminating process PID.moohan_moohan (48736)
terminating process PID.platypus_platypus (48721)
Timekeeper ended at Wed Nov 29 00:20:18 CST 2023
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:59:55 up 125 days,  4:02,  2 users,  load average: 0.00, 0.01, 0.05
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      22424    4171880   1% /dev/shm
tmpfs                        65880516    1280804   64599712   2% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9251008    7515968  56% /
/dev/md0                   3904859232 2561022588 1343836644  66% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7972522088 3746160536  69% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  439385600   16914304  97% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  880366592   32228352  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  884357120   28237824  97% /mnt/scr1
10.10.10.85:/data/web       480719104  439385600   16914304  97% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/29138
10.10.10.86:/home           961432576  153523200  759070720  17% /home
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/22417
tmpfs                        13176104          0   13176104   0% /run/user/10022
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1128Tue
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 00:00:23 up 125 days,  4:02,  2 users,  load average: 0.14, 0.05, 0.06
tmpfs                        65880516    1280844   64599672   2% /run
/dev/mapper/centos00-root    16766976    9251124    7515852  56% /
10.10.10.86:/mnt/scr1       961432576  884358144   28235776  97% /mnt/scr1
Wait For /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1129Wed to appear
	****INCOMPLETE jelly: snaptest did not complete****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:00:38 up 18 days, 13:42,  0 users,  load average: 43.52, 43.17, 43.20
/dev/sda7             22292052   4428152  16713248  21% /
/dev/sda5             12192608    374836  11188428   4% /tmp
/dev/sda3             12192636   1493420  10069872  13% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  80017912  64976912  56% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
gumund:/data/ftp     480719104 439385600  16914304  97% /mnt/ftp
gumund:/data/web     480719104 439385600  16914304  97% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
	****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 00:00:35 up 143 days, 16:38,  0 users,  load average: 0.22, 0.26, 0.15
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     32972  12158288   1% /tmp
/dev/sda3             12850716   4889944   7301316  41% /var
/dev/sdd             152623212 121629844  23233908  84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
	****INCOMPLETE platypus: snaptest did not complete****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 00:00:38 up 75 days,  6:07,  1 user,  load average: 0.42, 0.49, 0.35
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    402384   3537460  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-var   16371712   3818796  12552916  24% /var
/dev/mapper/centos_moohan-scr  858065536 399046624 459018912  47% /scr
/dev/mapper/centos_moohan-tmp   16371712     33400  16338312   1% /tmp
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 153523200 759070720  17% /home
jam:/mnt/hdf                   961432576 880366592  32228352  97% /mnt/hdf
jam:/mnt/scr1                  961432576 884358144  28235776  97% /mnt/scr1
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
	****INCOMPLETE moohan: snaptest did not complete****
Testing ostrich
ostrich is not reachable (Wed Nov 29 00:00:37 CST 2023)
	****SYSTEM ERROR: ostrich is not reachable (Wed Nov 29 00:00:37 CST 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
*** finished tests in jelly ***
More information about the opa-nightly-tests mailing list
