[opa-nightly-tests] jam OPA_Daily_Tests_0331Tue_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Tue Mar 31 23:34:45 CDT 2015
*** OPA Tests on 0331Tue ***
Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 3s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 51s
quail: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 51s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 56s
Timekeeper log
Timekeeper started at Tue Mar 31 23:29:00 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0331Tue_2328
A__z="*SHLVL
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu.hdfgroup.uiuc.edu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=72.36.68.242 49343 22
SSH_CONNECTION=72.36.68.242 49343 72.36.68.177 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Tuesday, March 31, 2015 11:28:54 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Tuesday, March 31, 2015 11:28:54 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Tuesday, March 31, 2015 11:28:56 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:28:39 up 56 days, 14:54, 16 users, load average: 0.15, 0.27, 1.05
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 7525972 22574220 26% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 477632 29622560 2% /tmp
/dev/sda6 31738392 8013036 22087132 27% /var
/dev/sda7 31738392 18488460 11611708 62% /usr
/dev/sda8 124991068 192216 118347152 1% /var/tmp
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 333188608 123111296 74% /mnt/ftp
gumund:/data/web 480719104 333188608 123111296 74% /mnt/web
/dev/mapper/VolGroup00-home
198351840 44080280 144033200 24% /home
/dev/sde1 565688764 428793460 107696368 80% /scr
/dev/sdc1 961432072 880445264 32148808 97% /mnt/scr1
/dev/sdd1 961432072 871778316 40815756 96% /mnt/hdf
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0331Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0331Tue.27681: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0331Tue.27681': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
11:28pm up 29 day(s), 6:08, 1 user, load average: 0.01, 0.01, 0.04
/ (rpool/ROOT/solaris):477103799 blocks 477103799 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483594 files
/proc (proc ): 0 blocks 29934 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):25668880 blocks 2229252 files
/system/object (objfs ): 0 blocks 2147483423 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):477103799 blocks 477103799 files
/tmp (swap ):25668880 blocks 2229252 files
/var/share (rpool/VARSHARE ):477103799 blocks 477103799 files
/export (rpool/export ):477103799 blocks 477103799 files
/export/home (rpool/export/home ):477103799 blocks 477103799 files
/export/home/kurz (rpool/export/home/kurz):477103799 blocks 477103799 files
/rpool (rpool ):477103799 blocks 477103799 files
/home (jam:/home ):308543120 blocks 50540751 files
/mnt/ftp (gumund:/mnt/ftp ):295060760 blocks 60891215 files
/mnt/web (gumund:/mnt/web ):295060760 blocks 60891215 files
/mnt/hdf (jam:/mnt/hdf ):179307512 blocks 112859485 files
/mnt/scr1 (jam:/mnt/scr1 ):161973560 blocks 118258777 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:29:07 up 56 days, 14:54, 16 users, load average: 0.22, 0.28, 1.02
/dev/sda2 31738420 477744 29622448 2% /tmp
/dev/sda6 31738392 8013104 22087064 27% /var
/dev/sdc1 961432072 880445300 32148772 97% /mnt/scr1
Tue Mar 31 23:29:17 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0331Tue_2329
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Tue Mar 31 23:30:18 CDT 2015
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:29:09 up 13:43, 0 users, load average: 0.00, 0.05, 0.34
/dev/sda7 22292052 4048920 17092480 20% /
/dev/sda5 12192608 562792 11000472 5% /tmp
/dev/sda3 12192636 2096076 9467216 19% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26229508 12953148 67% /usr
/dev/sdb 152754284 116955200 28039624 81% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
jam:/home 198351872 44080128 144033792 24% /home
jam:/mnt/hdf 961432576 871778304 40816640 96% /mnt/hdf
jam:/mnt/scr1 961432576 880445440 32149504 97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Mar 31 23:29:19 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-402.el5 #1 SMP Tue Feb 10 17:49:04 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0331Tue_2329
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Tue Mar 31 23:29:52 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:29:12 up 61 days, 6:27, 1 user, load average: 0.00, 0.04, 0.33
/dev/sda6 54205540 13673796 37771604 27% /
tmpfs 6099132 0 6099132 0% /dev/shm
/dev/sda1 194241 47728 136273 26% /boot
/dev/sda2 12850716 7707064 4484196 64% /tmp
/dev/sda3 12850716 8706488 3484772 72% /var
/dev/sdd 152623212 104318596 40545156 73% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Mar 31 23:29:22 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.8.1.el6.x86_64 #1 SMP Wed Jan 28 21:11:36 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0331Tue_2329
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Tue Mar 31 23:30:06 CDT 2015
Total time = 0m 44s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:29:14 up 60 days, 9:25, 2 users, load average: 0.13, 1.05, 2.49
/dev/mapper/vg_ostrich-lv_root
140479384 16266928 117073412 13% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 92065340 26082272 78% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Tue Mar 31 23:29:24 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0331Tue_2329
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Tue Mar 31 23:31:04 CDT 2015
Total time = 1m 40s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0331Tue_2331
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Tue Mar 31 23:34:15 CDT 2015
Total time = 3m 11s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:30 up 37 days, 8:57, 1 user, load averages: 1.85 1.88 1.85
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 173655368 314388168 36% 21770919 39298521 36% /
devfs 362 362 0 100% 627 0 100% /dev
72.36.68.242:/home 396703680 88160560 288066400 24% 675633 50540751 1% /home
72.36.68.242:/mnt/hdf 1922864144 1743556632 81631512 96% 9250467 112859485 8% /mnt/hdf
72.36.68.242:/mnt/scr1 1922864144 1760890672 64297472 97% 3851186 118258766 3% /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tue Mar 31 23:30:25 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.uiuc.edu 13.4.0 Darwin Kernel Version 13.4.0: Wed Dec 17 19:05:52 PST 2014; root:xnu-2422.115.10~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0331Tue_2330
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Tue Mar 31 23:31:27 CDT 2015
Total time = 1m 2s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:29 up 21 days, 8:06, 2 users, load averages: 0.23 0.17 0.17
/dev/disk0s2 1951845952 203839216 1747494736 11% 25543900 218436842 10% /
devfs 373 373 0 100% 646 0 100% /dev
/dev/disk1s2 1952853344 1296640 1951556704 1% 162078 243944588 0% /Volumes/Milvinae
72.36.68.242:/mnt/scr1 1922864144 1760890720 64297424 97% 3851191 118258761 3% /mnt/scr1
72.36.68.242:/home 396703680 88160560 288066400 24% 675633 50540751 1% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Tue Mar 31 23:29:34 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.uiuc.edu 12.6.0 Darwin Kernel Version 12.6.0: Wed Dec 17 19:11:40 PST 2014; root:xnu-2050.48.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0331Tue_2329
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Tue Mar 31 23:30:24 CDT 2015
Total time = 0m 50s
*** finished tests in kite ***
More information about the opa-nightly-tests
