[opa-nightly-tests] jam OPA_Daily_Tests_0330Mon_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Mon Mar 30 23:46:04 CDT 2015
*** OPA Tests on 0330Mon ***
   Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 41s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 54s
quail: Ran 1(1/0/0) tests, Grand total test time =  1m 6s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 42s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 47s
   Timekeeper log
Timekeeper started at Mon Mar 30 23:40:28 CDT 2015
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0330Mon_2340
CC= cc -m64
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu.hdfgroup.uiuc.edu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=72.36.68.242 47038 22
SSH_CONNECTION=72.36.68.242 47038 72.36.68.177 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Monday, March 30, 2015 11:40:23 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Monday, March 30, 2015 11:40:23 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Monday, March 30, 2015 11:40:24 PM CDT =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:40:07 up 55 days, 15:05, 21 users,  load average: 0.04, 0.58, 1.29
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   7494904  22605288  25% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    262692  29837500   1% /tmp
/dev/sda6             31738392   8018156  22082012  27% /var
/dev/sda7             31738392  18488460  11611708  62% /usr
/dev/sda8            124991068    192220 118347148   1% /var/tmp
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 333161984 123137920  74% /mnt/ftp
gumund:/data/web     480719104 333161984 123137920  74% /mnt/web
/dev/mapper/VolGroup00-home
                     198351840  44079224 144034256  24% /home
/dev/sde1            565688764 404240988 132248840  76% /scr
/dev/sdc1            961432072 879849716  32744356  97% /mnt/scr1
/dev/sdd1            961432072 866487696  46106376  95% /mnt/hdf
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0330Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0330Mon.1020: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0330Mon.1020': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 11:40pm  up 28 day(s),  6:19,  2 users,  load average: 0.02, 0.01, 0.07
/                  (rpool/ROOT/solaris):483550499 blocks 483550499 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483593 files
/proc              (proc              ):       0 blocks    29931 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):17977360 blocks  2229252 files
/system/object     (objfs             ):       0 blocks 2147483423 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):483550499 blocks 483550499 files
/tmp               (swap              ):17977360 blocks  2229252 files
/var/share         (rpool/VARSHARE    ):483550499 blocks 483550499 files
/export            (rpool/export      ):483550499 blocks 483550499 files
/export/home       (rpool/export/home ):483550499 blocks 483550499 files
/export/home/kurz  (rpool/export/home/kurz):483550499 blocks 483550499 files
/rpool             (rpool             ):483550499 blocks 483550499 files
/home              (jam:/home         ):308545232 blocks 50540752 files
/mnt/ftp           (gumund:/mnt/ftp   ):295114208 blocks 60891218 files
/mnt/web           (gumund:/mnt/web   ):295114208 blocks 60891218 files
/mnt/hdf           (jam:/mnt/hdf      ):189888752 blocks 112884118 files
/mnt/scr1          (jam:/mnt/scr1     ):163164656 blocks 118265777 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 1s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:40:35 up 55 days, 15:06, 21 users,  load average: 0.31, 0.59, 1.27
/dev/sda2             31738420    262800  29837392   1% /tmp
/dev/sdc1            961432072 879849752  32744320  97% /mnt/scr1
Mon Mar 30 23:40:45 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0330Mon_2340
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Mon Mar 30 23:41:47 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:40:37 up 59 days, 10:07,  1 user,  load average: 0.05, 0.45, 0.81
/dev/sda7             22292052   4057680  17083720  20% /
/dev/sda5             12192608    385388  11177876   4% /tmp
/dev/sda3             12192636   2095644   9467648  19% /var
/dev/sda1               101086     18613     77254  20% /boot
/dev/sdc1             41279536  26242224  12940432  67% /usr
/dev/sdb             152754284 116735404  28259420  81% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
jam:/home            198351872  44079104 144034816  24% /home
jam:/mnt/hdf         961432576 866487296  46106624  95% /mnt/hdf
jam:/mnt/scr1        961432576 879849472  32744448  97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Mar 30 23:40:47 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-400.1.1.el5 #1 SMP Thu Dec 18 00:59:53 EST 2014 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0330Mon_2340
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Mar 30 23:41:20 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:40:40 up 60 days,  6:38,  6 users,  load average: 0.02, 0.35, 0.70
/dev/sda6         54205540  13673788  37771612  27% /
tmpfs              6099132         0   6099132   0% /dev/shm
/dev/sda1           194241     47728    136273  26% /boot
/dev/sda2         12850716   7764500   4426760  64% /tmp
/dev/sda3         12850716   8702220   3489040  72% /var
/dev/sdd         152623212  73296232  71567520  51% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Mar 30 23:40:51 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.8.1.el6.x86_64 #1 SMP Wed Jan 28 21:11:36 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0330Mon_2340
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Mar 30 23:41:31 CDT 2015
Total time = 0m 40s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:40:42 up 59 days,  9:37,  2 users,  load average: 0.69, 1.36, 2.62
/dev/mapper/vg_ostrich-lv_root
                     140479384  16266796 117073544  13% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               487652     92973    369079  21% /boot
/dev/sdb2            124477364  92180040  25967572  79% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Mon Mar 30 23:40:53 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0330Mon_2340
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Mon Mar 30 23:42:26 CDT 2015
Total time = 1m 33s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0330Mon_2342
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Mon Mar 30 23:45:34 CDT 2015
Total time = 3m 8s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:41  up 36 days,  9:08, 1 user, load averages: 1.68 1.75 1.98
Filesystem             512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2            488555536  173301848 314741688    36% 21726729  39342711   36%   /
devfs                         361        361         0   100%      626         0  100%   /dev
72.36.68.242:/home      396703680   88158456 288068504    24%   675632  50540752    1%   /home
72.36.68.242:/mnt/hdf  1922864144 1732975392  92212752    95%  9225834 112884118    8%   /mnt/hdf
72.36.68.242:/mnt/scr1 1922864144 1759699576  65488568    97%  3844186 118265766    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Mon Mar 30 23:41:51 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.uiuc.edu 13.4.0 Darwin Kernel Version 13.4.0: Wed Dec 17 19:05:52 PST 2014; root:xnu-2422.115.10~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_0330Mon_2341
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Mon Mar 30 23:42:56 CDT 2015
Total time = 1m 5s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:40  up 20 days,  8:17, 3 users, load averages: 0.14 0.10 0.17
/dev/disk0s2           1951845952  203067736 1748266216    11% 25447465 218533277   10%   /
devfs                         375        375          0   100%      650         0  100%   /dev
/dev/disk1s2           1952853344    1296640 1951556704     1%   162078 243944588    0%   /Volumes/Milvinae
72.36.68.242:/mnt/scr1 1922864144 1759699648   65488496    97%  3844192 118265760    3%   /mnt/scr1
72.36.68.242:/home      396703680   88158456  288068504    24%   675632  50540752    1%   /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Mon Mar 30 23:41:03 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.uiuc.edu 12.6.0 Darwin Kernel Version 12.6.0: Wed Dec 17 19:11:40 PST 2014; root:xnu-2050.48.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0330Mon_2341
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Mon Mar 30 23:41:56 CDT 2015
Total time = 0m 54s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
