[opa-nightly-tests] jam OPA_Daily_Tests_0417Thu_FAILED!!!
Larry Knox
lrknox at hdfgroup.org
Fri Apr 18 06:30:15 CDT 2014
Emu system clock is out of sync. We'll get it corrected today.
Larry
-----Original Message-----
From: opa-nightly-tests-bounces at lists.mcs.anl.gov [mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
Sent: Thursday, April 17, 2014 11:24 PM
To: opa-nightly-tests at lists.mcs.anl.gov
Subject: [opa-nightly-tests] jam OPA_Daily_Tests_0417Thu_FAILED!!!
*** OPA Tests on 0417Thu ***
Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam PASSED kite: standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 46s
jam: Ran 1(1/0/0) tests, Grand total test time = 0m 58s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
ostrich: Ran 1(1/0/0) tests, Grand total test time = 1m 39s
jam: Ran 6(0/0/0) hosts, Grand total test time = 2m 45s
Timekeeper log
Timekeeper started at Thu Apr 17 23:21:49 CDT 2014 Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0417Thu_2321
A__z="*SHLVL
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu.hdfgroup.uiuc.edu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake -j 8
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=72.36.68.242 42514 22
SSH_CONNECTION=72.36.68.242 42514 72.36.68.177 22 SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing === ===== Run Tests: Thursday, April 17, 2014 11:21:44 PM CDT ===== Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory ===== configure: Thursday, April 17, 2014 11:21:44 PM CDT ===== checking for a BSD-compatible install... /usr/bin/ginstall -c checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Thursday, April 17, 2014 11:21:45 PM CDT ===== Thursday, April 17, 2014 11:21:45 PM CDT ========================= Dumping done =========================
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
More information about the opa-nightly-tests
