[opa-nightly-tests] jam OPA_Daily_Tests_0417Thu_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Thu Apr 17 23:24:22 CDT 2014
*** OPA Tests on 0417Thu ***
   Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 46s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 58s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
ostrich: Ran 1(1/0/0) tests, Grand total test time =  1m 39s
jam: Ran 6(0/0/0) hosts, Grand total test time =  2m 45s
   Timekeeper log
Timekeeper started at Thu Apr 17 23:21:49 CDT 2014
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0417Thu_2321
A__z="*SHLVL
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu.hdfgroup.uiuc.edu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake -j 8
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=72.36.68.242 42514 22
SSH_CONNECTION=72.36.68.242 42514 72.36.68.177 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Thursday, April 17, 2014 11:21:44 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Thursday, April 17, 2014 11:21:44 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Thursday, April 17, 2014 11:21:45 PM CDT =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:21:27 up 35 days, 14:10, 14 users,  load average: 1.05, 1.37, 2.42
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   5837700  24262492  20% /
/dev/sda1               101086     17515     78352  19% /boot
/dev/sda2             31738420    235368  29864824   1% /tmp
/dev/sda6             31738392  22444252   7655916  75% /var
/dev/sda7             31738392  18348308  11751860  61% /usr
/dev/sda8            124991068   1472536 117066832   2% /var/tmp
/dev/sde1            565688764 378844116 157645712  71% /scr
tmpfs                  8313628         0   8313628   0% /dev/shm
/dev/mapper/VolGroup00-home
                     198351840  23882468 164231012  13% /home
gumund:/data/ftp     480719104 387074816  69225088  85% /mnt/ftp
gumund:/data/web     480719104 387074816  69225088  85% /mnt/web
/dev/sdc1            961432072 852264496  60329576  94% /mnt/scr1
/dev/sdd1            961432072 882420004  30174068  97% /mnt/hdf
STANDARD_OPT=deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0417Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0417Thu.15587: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0417Thu.15587': No such file or directory
Thu Apr 17 23:21:48 CDT 2014
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 11:21pm  up 433 day(s),  5:48,  1 user,  load average: 0.01, 0.18, 0.63
/                  (rpool/ROOT/solaris):490386219 blocks 490386219 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483588 files
/proc              (proc              ):       0 blocks    29924 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):23602672 blocks  2224943 files
/system/object     (objfs             ):       0 blocks 2147483423 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):490386219 blocks 490386219 files
/tmp               (swap              ):23602672 blocks  2224943 files
/var/share         (rpool/VARSHARE    ):490386219 blocks 490386219 files
/export            (rpool/export      ):490386219 blocks 490386219 files
/export/home       (rpool/export/home ):490386219 blocks 490386219 files
/export/home/kurz  (rpool/export/home/kurz):490386219 blocks 490386219 files
/rpool             (rpool             ):490386219 blocks 490386219 files
/mnt/scr1          (jam:/mnt/scr1     ):218335104 blocks 118693462 files
/home              (jam:/home         ):348938744 blocks 50654697 files
/mnt/hdf           (jam:/mnt/hdf      ):158024136 blocks 113103735 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 1s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:21:56 up 35 days, 14:11, 14 users,  load average: 1.31, 1.40, 2.40
/dev/sda2             31738420    235476  29864716   1% /tmp
/dev/sda6             31738392  22444660   7655508  75% /var
/dev/sdc1            961432072 852264528  60329544  94% /mnt/scr1
Thu Apr 17 23:22:06 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0417Thu_2322
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Apr 17 23:23:04 CDT 2014
Total time = 0m 58s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:21:58 up 35 days, 11:00,  0 users,  load average: 0.00, 0.10, 0.40
/dev/sda7             22292052   4049036  17092364  20% /
/dev/sda5             12192608    567128  10996136   5% /tmp
/dev/sda3             12192636   1855156   9708136  17% /var
/dev/sda1               101086     18578     77289  20% /boot
/dev/sdc1             41279536  26140292  13042364  67% /usr
/dev/sdb             152754284  36633192 108361632  26% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
jam:/home            198351872  23881728 164231168  13% /home
jam:/mnt/hdf         961432576 882419712  30174208  97% /mnt/hdf
jam:/mnt/scr1        961432576 852264960  60329984  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Apr 17 23:22:08 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-371.6.1.el5 #1 SMP Wed Mar 12 20:03:51 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0417Thu_2322
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Apr 17 23:22:41 CDT 2014
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:22:01 up 9 days, 10:18,  0 users,  load average: 0.00, 0.32, 1.16
/dev/sda6         54336612  12496780  39079692  25% /
tmpfs              1962216      1048   1961168   1% /dev/shm
/dev/sda1           198337     50108    137989  27% /boot
/dev/sda2         12981788    406192  11916140   4% /tmp
/dev/sda3         12981788   3029064   9293268  25% /var
/dev/sdd         152754284  63645808  81349016  44% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Apr 17 23:22:11 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-431.11.2.el6.x86_64 #1 SMP Tue Mar 25 19:59:55 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0417Thu_2322
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Apr 17 23:22:57 CDT 2014
Total time = 0m 46s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:22:03 up 9 days, 10:58,  1 user,  load average: 16.62, 15.80, 15.03
/dev/mapper/vg_ostrich-lv_root
                     140610456  12038792 121432620  10% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               495844     96919    373325  21% /boot
/dev/sdb2            124608436  47563288  70715396  41% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Thu Apr 17 23:22:13 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-431.11.2.el6.ppc64 #1 SMP Mon Mar 3 13:31:04 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0417Thu_2322
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu Apr 17 23:23:52 CDT 2014
Total time = 1m 39s
*** finished tests in ostrich ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:22  up 9 days, 12:34, 1 user, load averages: 0.12 0.20 0.43
Filesystem             512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2           1951845952  239950864 1711383088    13% 30057856 213922886   12%   /
devfs                         373        373          0   100%      646         0  100%   /dev
/dev/disk1s2           1952853344    1296848 1951556496     1%   162104 243944562    0%   /Volumes/Milvinae
72.36.68.242:/mnt/scr1 1922864144 1704529152  120658992    94%  3416504 118693448    3%   /mnt/scr1
72.36.68.242:/home      396703680   47764936  328462024    13%   561687  50654697    1%   /mnt/home
72.36.68.242:/mnt/hdf  1922864144 1764840008   60348136    97%  9006217 113103735    7%   /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Thu Apr 17 23:22:16 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.uiuc.edu 12.5.0 Darwin Kernel Version 12.5.0: Sun Sep 29 13:33:47 PDT 2013; root:xnu-2050.48.12~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0417Thu_2322
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Thu Apr 17 23:23:11 CDT 2014
Total time = 0m 55s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
