[opa-nightly-tests] jam OPA_Daily_Tests_1107Thu
HDF Tester hdftest at hdfgroup.org
Thu Nov 7 22:27:42 CST 2013
*** OPA Tests on 1107Thu ***
   Tests Summary
PASSED emu: standard
PASSED jam: standard
PASSED koala: standard
PASSED ostrich: standard
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
ostrich: Ran 1(1/0/0) tests, Grand total test time =  1m 30s
emu: Ran 1(1/0/0) tests, Grand total test time =  8m 38s
jam: Ran 5(0/0/0) hosts, Grand total test time =  9m 34s
   Timekeeper log
Timekeeper started at Thu Nov  7 22:18:19 CST 2013
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 22:17:58 up 55 days, 14:08, 32 users,  load average: 0.41, 0.32, 0.42
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   5496672  24603520  19% /
/dev/sda1               101086     17507     78360  19% /boot
/dev/sda2             31738420   1285260  28814932   5% /tmp
/dev/sda6             31738392  16685828  13414340  56% /var
/dev/sda7             31738392  18334792  11765376  61% /usr
/dev/sda8            124991068    551804 117987564   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  63279224 124834256  34% /home
/dev/sde1            565688764 223677460 312812368  42% /scr
/dev/sdc1            961432072 806401960 106192112  89% /mnt/scr1
/dev/sdd1            961432072 829707368  82886704  91% /mnt/hdf
tmpfs                  8313628        16   8313612   1% /dev/shm
gumund:/data/ftp     480719104 382928128  73371776  84% /mnt/ftp
gumund:/data/web     480719104 382928128  73371776  84% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1107Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1107Thu.27906: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1107Thu.27906': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
ostrich
wren
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 10:18pm  up 272 day(s),  5:45,  0 users,  load average: 0.05, 0.42, 0.88
/                  (rpool/ROOT/solaris):490546270 blocks 490546270 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483589 files
/proc              (proc              ):       0 blocks    29927 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):20581552 blocks  2225413 files
/system/object     (objfs             ):       0 blocks 2147483423 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):490546270 blocks 490546270 files
/tmp               (swap              ):20581552 blocks  2225413 files
/var/share         (rpool/VARSHARE    ):490546270 blocks 490546270 files
/export            (rpool/export      ):490546270 blocks 490546270 files
/export/home       (rpool/export/home ):490546270 blocks 490546270 files
/export/home/kurz  (rpool/export/home/kurz):490546270 blocks 490546270 files
/rpool             (rpool             ):490546270 blocks 490546270 files
/mnt/scr1          (jam:/mnt/scr1     ):310060168 blocks 117847402 files
/home              (jam:/home         ):270145232 blocks 50800977 files
/mnt/hdf           (jam:/mnt/hdf      ):263449408 blocks 113472763 files
/mnt/web           (gumund:/mnt/web   ):195581888 blocks 60886618 files
/mnt/ftp           (gumund:/mnt/ftp   ):195581888 blocks 60886618 files
TEST_TYPES=standard
Thursday, November  7, 2013 10:18:34 PM CST
*** starting standard tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/emu_1107Thu_2218
*** finished standard tests for emu ***
Thursday, November  7, 2013 10:27:12 PM CST
Total time = 8m 38s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 22:18:26 up 55 days, 14:09, 32 users,  load average: 0.52, 0.35, 0.43
/dev/sda2             31738420   1285364  28814828   5% /tmp
/dev/sda6             31738392  16686332  13413836  56% /var
/dev/sdc1            961432072 806401996 106192076  89% /mnt/scr1
TEST_TYPES=standard
Thu Nov  7 22:18:36 CST 2013
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1107Thu_2218
*** finished standard tests for jam ***
Thu Nov  7 22:19:38 CST 2013
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 22:18:28 up 57 days, 11:20,  6 users,  load average: 0.17, 0.18, 0.23
/dev/sda7             22292052   3782764  17358636  18% /
/dev/sda5             12192608   1468192  10095072  13% /tmp
/dev/sda3             12192636   2327788   9235504  21% /var
/dev/sda1               101086     18565     77302  20% /boot
/dev/sdc1             41279536  26139052  13043604  67% /usr
/dev/sdb1             76581768  39339228  33352376  55% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
jam:/home            198351872  63279104 124834816  34% /home
jam:/mnt/hdf         961432576 829707264  82887680  91% /mnt/hdf
jam:/mnt/scr1        961432576 806402048 106192896  89% /mnt/scr1
TEST_TYPES=standard
Thu Nov  7 22:18:38 CST 2013
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-348.16.1.el5 #1 SMP Wed Aug 21 04:00:25 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1107Thu_2218
*** finished standard tests for koala ***
Thu Nov  7 22:19:12 CST 2013
Total time = 0m 34s
*** finished tests in koala ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 22:18:31 up 57 days, 11:25,  2 users,  load average: 0.05, 0.41, 0.34
/dev/mapper/vg_ostrich-lv_root
                     140610456  11270504 122200908   9% /
tmpfs                  7821696         0   7821696   0% /dev/shm
/dev/sda2               495844     92936    377308  20% /boot
/dev/sdb2            124608436  36458996  81819688  31% /scr
TEST_TYPES=standard
Thu Nov  7 22:18:41 CST 2013
*** starting standard tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-358.18.1.el6.ppc64 #1 SMP Fri Aug 2 17:07:40 EDT 2013 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1107Thu_2218
*** finished standard tests for ostrich ***
Thu Nov  7 22:20:11 CST 2013
Total time = 1m 30s
*** finished tests in ostrich ***
Testing wren
ssh -o ConnectTimeout=60 wren -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname wren
/home/hdftest/snapshots-opa: Operation timed out.
****SYSTEM ERROR wren: Abnormal exit from runtest ****
	****SYSTEM ERROR wren: runtest command failed ****
More information about the opa-nightly-tests mailing list
