[opa-nightly-tests] jam OPA_Daily_Tests_1106Wed
HDF Tester
hdftest at hdfgroup.org
Wed Nov 6 22:49:02 CST 2013
*** OPA Tests on 1106Wed ***
Tests Summary
PASSED emu: setenvN 2 CC cc -m64
PASSED jam: standard
PASSED koala: standard
PASSED ostrich: standard
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 34s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
ostrich: Ran 1(1/0/0) tests, Grand total test time = 1m 32s
emu: Ran 1(1/0/0) tests, Grand total test time = 8m 41s
jam: Ran 5(0/0/0) hosts, Grand total test time = 9m 37s
Timekeeper log
Timekeeper started at Wed Nov 6 22:39:36 CST 2013
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
22:39:14 up 54 days, 14:29, 34 users, load average: 0.39, 0.22, 0.14
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 5493472 24606720 19% /
/dev/sda1 101086 17507 78360 19% /boot
/dev/sda2 31738420 1288608 28811584 5% /tmp
/dev/sda6 31738392 14896596 15203572 50% /var
/dev/sda7 31738392 18334792 11765376 61% /usr
/dev/sda8 124991068 545356 117994012 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 63265028 124848452 34% /home
/dev/sde1 565688764 220679040 315810788 42% /scr
/dev/sdc1 961432072 795291204 117302868 88% /mnt/scr1
/dev/sdd1 961432072 827930140 84663932 91% /mnt/hdf
tmpfs 8313628 16 8313612 1% /dev/shm
gumund:/data/ftp 480719104 382928128 73371776 84% /mnt/ftp
gumund:/data/web 480719104 382928128 73371776 84% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1106Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1106Wed.15938: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1106Wed.15938': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
ostrich
wren
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
10:39pm up 271 day(s), 6:06, 0 users, load average: 0.05, 0.39, 0.53
/ (rpool/ROOT/solaris):497562945 blocks 497562945 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483589 files
/proc (proc ): 0 blocks 29927 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):20985152 blocks 2225416 files
/system/object (objfs ): 0 blocks 2147483423 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):497562945 blocks 497562945 files
/tmp (swap ):20985152 blocks 2225416 files
/var/share (rpool/VARSHARE ):497562945 blocks 497562945 files
/export (rpool/export ):497562945 blocks 497562945 files
/export/home (rpool/export/home ):497562945 blocks 497562945 files
/export/home/kurz (rpool/export/home/kurz):497562945 blocks 497562945 files
/rpool (rpool ):497562945 blocks 497562945 files
/mnt/scr1 (jam:/mnt/scr1 ):332281680 blocks 117855319 files
/home (jam:/home ):270173624 blocks 50800983 files
/mnt/hdf (jam:/mnt/hdf ):267003864 blocks 113482425 files
/mnt/web (gumund:/mnt/web ):195581928 blocks 60886618 files
/mnt/ftp (gumund:/mnt/ftp ):195581928 blocks 60886618 files
TEST_TYPES=setenvN 2 CC cc -m64
Wednesday, November 6, 2013 10:39:51 PM CST
*** starting setenvN 2 CC cc -m64 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/emu_1106Wed_2239
*** finished setenvN 2 CC cc -m64 tests for emu ***
Wednesday, November 6, 2013 10:48:31 PM CST
Total time = 8m 40s
*** finished tests in emu ***
Wednesday, November 6, 2013 10:48:32 PM CST
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
22:39:43 up 54 days, 14:30, 34 users, load average: 0.53, 0.26, 0.15
/dev/sda2 31738420 1288712 28811480 5% /tmp
/dev/sda6 31738392 14896976 15203192 50% /var
/dev/sdc1 961432072 795291240 117302832 88% /mnt/scr1
TEST_TYPES=standard
Wed Nov 6 22:39:53 CST 2013
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1106Wed_2239
*** finished standard tests for jam ***
Wed Nov 6 22:40:55 CST 2013
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
22:39:45 up 56 days, 11:41, 5 users, load average: 0.22, 0.17, 0.12
/dev/sda7 22292052 3782772 17358628 18% /
/dev/sda5 12192608 1429300 10133964 13% /tmp
/dev/sda3 12192636 2325412 9237880 21% /var
/dev/sda1 101086 18565 77302 20% /boot
/dev/sdc1 41279536 26139052 13043604 67% /usr
/dev/sdb1 76581768 36095000 36596604 50% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
jam:/home 198351872 63264768 124849152 34% /home
jam:/mnt/hdf 961432576 827930624 84664320 91% /mnt/hdf
jam:/mnt/scr1 961432576 795291648 117303296 88% /mnt/scr1
TEST_TYPES=standard
Wed Nov 6 22:39:55 CST 2013
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-348.16.1.el5 #1 SMP Wed Aug 21 04:00:25 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1106Wed_2239
*** finished standard tests for koala ***
Wed Nov 6 22:40:29 CST 2013
Total time = 0m 34s
*** finished tests in koala ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
22:39:48 up 56 days, 11:46, 2 users, load average: 0.16, 0.48, 0.41
/dev/mapper/vg_ostrich-lv_root
140610456 11297176 122174236 9% /
tmpfs 7821696 0 7821696 0% /dev/shm
/dev/sda2 495844 92936 377308 20% /boot
/dev/sdb2 124608436 36188860 82089824 31% /scr
TEST_TYPES=standard
Wed Nov 6 22:39:58 CST 2013
*** starting standard tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-358.18.1.el6.ppc64 #1 SMP Fri Aug 2 17:07:40 EDT 2013 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1106Wed_2239
*** finished standard tests for ostrich ***
Wed Nov 6 22:41:30 CST 2013
Total time = 1m 32s
*** finished tests in ostrich ***
Testing wren
ssh -o ConnectTimeout=60 wren -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname wren
/home/hdftest/snapshots-opa: Operation timed out.
****SYSTEM ERROR wren: Abnormal exit from runtest ****
****SYSTEM ERROR wren: runtest command failed ****
More information about the opa-nightly-tests
