[opa-nightly-tests] jam OPA_Daily_Tests_1207Fri_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Fri Dec 7 20:24:06 CST 2012
*** OPA Tests on 1207Fri ***
   Tests Summary
****FAILED ostrich: standard****
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
ostrich: Ran 1(0/1/0) tests, Grand total test time =  1m 33s
linew: Ran 1(1/0/0) tests, Grand total test time =  2m 47s
jam: Ran 4(0/0/0) hosts, Grand total test time =  3m 43s
   Timekeeper log
Timekeeper started at Fri Dec  7 20:20:33 CST 2012
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of ostrich: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1207Fri_2020
Testing integer compare-and-swap fairness with 100 threads             PASSED
Testing pointer compare-and-swap fairness with 100 threads             PASSED
Testing integer swap with 100 threads                                  PASSED
Testing pointer swap with 100 threads                                  PASSED
Testing integer LL/SC stack with 100 threads                           PASSED
Testing pointer LL/SC stack with 100 threads                           PASSED
***** 1 PRIMITIVES TEST FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads             PASSED
Testing memory barriers with local variables with 100 threads          PASSED
Testing memory barriers with scattered array with 100 threads          PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                           PASSED
Testing multithreaded queue (empty queue) with 100 threads             PASSED
Testing multithreaded queue (full queue) with 100 threads              PASSED
All queue tests passed.
PASS: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Fri Dec  7 20:22:28 CST 2012 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 20:20:12 up 2 days, 11:14, 34 users,  load average: 0.05, 0.28, 0.44
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3798208  26301984  13% /
/dev/sda1               101086     23185     72682  25% /boot
/dev/sda2             31738420    425904  29674288   2% /tmp
/dev/sda6             31738392  10442904  19657264  35% /var
/dev/sda7             31738392  14857212  15242956  50% /usr
/dev/sda8            124991068   1133296 117406072   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  17665684 170447796  10% /home
/dev/sde1            565688764 408008200 128481628  77% /scr
/dev/sdc1            961432072 818575464  94018608  90% /mnt/scr1
/dev/sdd1            961432072 759935696 152658376  84% /mnt/hdf
tmpfs                  8313628        16   8313612   1% /dev/shm
gumund:/data/ftp     480719104 361001344  95298560  80% /mnt/ftp
gumund:/data/web     480719104 361001344  95298560  80% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1207Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1207Fri.15472: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1207Fri.15472': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
koala
ostrich
    Fork off timekeeper 12
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
  8:20pm  up 2 day(s),  3:52,  0 users,  load average: 0.64, 1.18, 1.46
/                  (/dev/dsk/c1t0d0s0 ):40910736 blocks  8210847 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483605 files
/proc              (proc              ):       0 blocks    29943 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20997024 blocks  1180601 files
/system/object     (objfs             ):       0 blocks 2147483491 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):40910736 blocks  8210847 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):40910736 blocks  8210847 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20997024 blocks  1180601 files
/var/run           (swap              ):20997024 blocks  1180601 files
/scr               (/dev/dsk/c1t1d0s0 ):850131654 blocks 226656152 files
/home              (jam:/home         ):361372312 blocks 50834196 files
/mnt/hdf           (jam:/mnt/hdf      ):402992752 blocks 114380679 files
/mnt/scr1          (jam:/mnt/scr1     ):288239312 blocks 118413597 files
/mnt/web           (gumund:/mnt/web   ):239435280 blocks 60869934 files
/mnt/ftp           (gumund:/mnt/ftp   ):239435280 blocks 60869934 files
TEST_TYPES=standard
Fri Dec  7 20:20:49 CST 2012
*** starting standard tests in linew ***
Uname -a: SunOS linew.hdfgroup.uiuc.edu 5.10 Generic_147440-27 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_1207Fri_2020
*** finished standard tests for linew ***
Fri Dec  7 20:23:35 CST 2012
Total time = 2m 46s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 20:20:41 up 2 days, 11:14, 34 users,  load average: 0.51, 0.37, 0.47
/dev/sda2             31738420    426168  29674024   2% /tmp
/dev/sda6             31738392  10443248  19656920  35% /var
/dev/sdc1            961432072 817313368  95280704  90% /mnt/scr1
TEST_TYPES=standard
Fri Dec  7 20:20:51 CST 2012
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1207Fri_2020
*** finished standard tests for jam ***
Fri Dec  7 20:21:46 CST 2012
Total time = 0m 55s
*** finished tests in jam ***
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 20:20:43 up 2 days, 11:29,  0 users,  load average: 0.00, 0.03, 0.13
/dev/sda7             22292052   1684992  19456408   8% /
/dev/sda5             12192608    516380  11046884   5% /tmp
/dev/sda3             12192636   5332616   6230676  47% /var
/dev/sda1               101086     24789     71078  26% /boot
/dev/sdb1             41279536  24772656  14410000  64% /usr
/dev/sdc1             76581768  51850384  20841220  72% /scr
tmpfs                  6149560         0   6149560   0% /dev/shm
jam:/home            198351872  17665024 170447872  10% /home
jam:/mnt/hdf         961432576 759936000 152658944  84% /mnt/hdf
jam:/mnt/scr1        961432576 817324032  95270912  90% /mnt/scr1
TEST_TYPES=standard
Fri Dec  7 20:20:53 CST 2012
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-308.20.1.el5 #1 SMP Tue Nov 13 10:15:12 EST 2012 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1207Fri_2020
*** finished standard tests for koala ***
Fri Dec  7 20:21:26 CST 2012
Total time = 0m 33s
*** finished tests in koala ***
Testing ostrich
ssh ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 20:20:45 up 2 days, 10:21,  1 user,  load average: 0.16, 0.22, 0.21
/dev/mapper/vg_ostrich-lv_root
                     140610456  11035616 122435796   9% /
tmpfs                  7821696         0   7821696   0% /dev/shm
/dev/sda2               495844    132234    338010  29% /boot
/dev/sdb2            124608436  11961632 106317052  11% /scr
TEST_TYPES=standard
Fri Dec  7 20:20:56 CST 2012
*** starting standard tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-279.14.1.el6.ppc64 #1 SMP Mon Oct 15 13:45:24 EDT 2012 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard tests for ostrich ***
Total time = 1m 32s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
	Fri Dec  7 20:24:05 CST 2012
	****SYSTEM ERROR ostrich: runtest command failed ****
More information about the opa-nightly-tests mailing list
