[opa-nightly-tests] jam OPA_Daily_Tests_1206Thu_FAILED!!!
Dave Goodell goodell at mcs.anl.gov
Fri Dec 7 14:45:47 CST 2012
FYI, I've just added Kaz to the opa-core@ list.  So if anyone needs to reach him, he should have more default context on OPA stuff in the future.
-Dave
On Dec 7, 2012, at 2:25 PM CST, Dave Goodell wrote:
> OK, thanks Neil.  If you get stumped, we can see if Kaz has any ideas, since he has a good deal of PPC/POWER knowledge.
> -Dave
> On Dec 7, 2012, at 1:36 PM CST, Neil Fortner wrote:
>> Dave,
>> ostrich is a linux/POWER7 machine.  It seems to occasionally fail when I run it by hand both from the svn and git repos.  I don't know why it wasn't failing before the change to git.  The failure is in the LL/SC ABA test (2 threads), and the message is "Unexpected success of OPA_SC_int" (often multiple times).  I will look into this further.
>> Thanks,
>> -Neil
>> On 12/07/2012 11:29 AM, Dave Goodell wrote:
>>> What sort of host is ostrich?  The source code should not have changed (besides adding a ".gitignore" file), and the tests are passing on my x86_64 laptop when run by hand.
>>> The log output is missing the actual failure message too, so it's hard to diagnose what's going on here.
>>> -Dave
>>> On Dec 6, 2012, at 7:01 PM PST, Larry Knox wrote:
>>>> This is the first run using the new git repository.  1 test failed on
>>>> ostrich.  This will give us a good test of the git update assuming a code
>>>> change is necessary to fix the problem.
>>>> There was another test message just before this one from the previous
>>>> night's test.  The machines freedom and loyalty are not responding to ssh
>>>> due to hdfgroup changes, pending a reboot by Quincey when he returns.  I
>>>> have removed them from the test machine list until that happens.
>>>> Larry
>>>> -----Original Message-----
>>>> From: opa-nightly-tests-bounces at lists.mcs.anl.gov
>>>> [mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
>>>> Sent: Thursday, December 06, 2012 8:43 PM
>>>> To: opa-nightly-tests at lists.mcs.anl.gov
>>>> Subject: [opa-nightly-tests] jam OPA_Daily_Tests_1206Thu_FAILED!!!
>>>> *** OPA Tests on 1206Thu ***
>>>>  Tests Summary
>>>> ****FAILED ostrich: standard****
>>>> PASSED jam: standard
>>>> PASSED koala: standard
>>>> PASSED linew: standard
>>>>  Tests Time Summary
>>>> koala: Ran 1(1/0/0) tests, Grand total test time =  0m 32s
>>>> jam: Ran 1(1/0/0) tests, Grand total test time =  1m 1s
>>>> ostrich: Ran 1(0/1/0) tests, Grand total test time =  1m 40s
>>>> linew: Ran 1(1/0/0) tests, Grand total test time =  2m 47s
>>>> jam: Ran 6(0/0/0) hosts, Grand total test time =  191m 58s
>>>> jam: Ran 6(0/0/0) hosts, Grand total test time =  197m 10s
>>>> jam: Ran 6(0/0/0) hosts, Grand total test time =  153m 39s
>>>>  Timekeeper log
>>>> Timekeeper started at Thu Dec  6 18:09:52 CST 2012 Timekeeper sleeping for
>>>> 720 seconds Timekeeper woke up at Thu Dec  6 18:21:52 CST 2012, looking for
>>>> processes to terminate...
>>>> Timekeeper ended at Thu Dec  6 18:21:52 CST 2012
>>>>  Tests Failures
>>>> Dumping logfile of ostrich: standard
>>>> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1206Thu_1810
>>>> Testing integer compare-and-swap fairness with 100 threads
>>>> PASSED
>>>> Testing pointer compare-and-swap fairness with 100 threads
>>>> PASSED
>>>> Testing integer swap with 100 threads
>>>> PASSED
>>>> Testing pointer swap with 100 threads
>>>> PASSED
>>>> Testing integer LL/SC stack with 100 threads
>>>> PASSED
>>>> Testing pointer LL/SC stack with 100 threads
>>>> PASSED
>>>> ***** 1 PRIMITIVES TEST FAILED! *****
>>>> FAIL: test_primitives
>>>> Testing memory barrier sanity
>>>> PASSED
>>>> Testing memory barriers with linear array with 2 threads
>>>> PASSED
>>>> Testing memory barriers with local variables with 2 threads
>>>> PASSED
>>>> Testing memory barriers with scattered array with 2 threads
>>>> PASSED
>>>> Testing memory barriers with linear array with 4 threads
>>>> PASSED
>>>> Testing memory barriers with local variables with 4 threads
>>>> PASSED
>>>> Testing memory barriers with scattered array with 4 threads
>>>> PASSED
>>>> Testing memory barriers with linear array with 10 threads
>>>> PASSED
>>>> Testing memory barriers with local variables with 10 threads
>>>> PASSED
>>>> Testing memory barriers with scattered array with 10 threads
>>>> PASSED
>>>> Testing memory barriers with linear array with 100 threads
>>>> PASSED
>>>> Testing memory barriers with local variables with 100 threads
>>>> PASSED
>>>> Testing memory barriers with scattered array with 100 threads
>>>> PASSED
>>>> All barriers tests passed.
>>>> PASS: test_barriers
>>>> Testing queue sanity
>>>> PASSED
>>>> Testing multithreaded queue with 2 threads
>>>> PASSED
>>>> Testing multithreaded queue (empty queue) with 2 threads
>>>> PASSED
>>>> Testing multithreaded queue (full queue) with 2 threads
>>>> PASSED
>>>> Testing multithreaded queue with 4 threads
>>>> PASSED
>>>> Testing multithreaded queue (empty queue) with 4 threads
>>>> PASSED
>>>> Testing multithreaded queue (full queue) with 4 threads
>>>> PASSED
>>>> Testing multithreaded queue with 10 threads
>>>> PASSED
>>>> Testing multithreaded queue (empty queue) with 10 threads
>>>> PASSED
>>>> Testing multithreaded queue (full queue) with 10 threads
>>>> PASSED
>>>> Testing multithreaded queue with 100 threads
>>>> PASSED
>>>> Testing multithreaded queue (empty queue) with 100 threads
>>>> PASSED
>>>> Testing multithreaded queue (full queue) with 100 threads
>>>> PASSED
>>>> All queue tests passed.
>>>> PASS: test_queue
>>>> 1 of 4 tests failed
>>>> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
>>>> gmake[2]: *** [check-TESTS] Error 1
>>>> gmake[2]: Leaving directory
>>>> `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
>>>> gmake[1]: *** [check-am] Error 2
>>>> gmake[1]: Leaving directory
>>>> gmake: *** [check-recursive] Error 1
>>>> Failed running make check
>>>> ===== Exit bin/snapshot with status=2: Thu Dec  6 18:11:55 CST 2012 =====
>>>> Thu Dec  6 18:11:55 CST 2012 ========================= Dumping done
>>>> Runtest did not exit normally.
>>>>  Watchers List
>>>> OPA Daily test features/platforms watchers and procedure
>>>> Procedure:
>>>> The watcher will investigate and report the cause of failure by 11am.
>>>> The developer who checked in the error code may report so by then too.
>>>> The watcher or the developer should get the failure fixed and report it by
>>>> 3pm.
>>>> Watcher for OPA:	 	Neil
>>>> updated: 2009/05/05
>>>>  Tests Details
>>>> 18:09:33 up 1 day,  9:03, 18 users,  load average: 0.06, 0.26, 0.43
>>>> Filesystem           1K-blocks      Used Available Use% Mounted on
>>>> /dev/sda3             31738420   3798708  26301484  13% /
>>>> /dev/sda1               101086     23185     72682  25% /boot
>>>> /dev/sda2             31738420    365712  29734480   2% /tmp
>>>> /dev/sda6             31738392   9891148  20209020  33% /var
>>>> /dev/sda7             31738392  14854308  15245860  50% /usr
>>>> /dev/sda8            124991068   1133300 117406068   1% /var/tmp
>>>> /dev/mapper/VolGroup00-home
>>>>                    198351840  17664644 170448836  10% /home
>>>> /dev/sde1            565688764 407775828 128714000  77% /scr
>>>> /dev/sdc1            961432072 816721756  95872316  90% /mnt/scr1
>>>> /dev/sdd1            961432072 759854124 152739948  84% /mnt/hdf
>>>> tmpfs                  8313628         0   8313628   0% /dev/shm
>>>> gumund:/data/ftp     480719104 361001344  95298560  80% /mnt/ftp
>>>> gumund:/data/web     480719104 361001344  95298560  80% /mnt/web
>>>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall TEST_TYPES=standard
>>>> Running source repository checkout with output saved in
>>>>  /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1206Thu
>>>> Checking MANIFEST file ...
>>>> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1206Thu.18700: No such
>>>> file or directory
>>>> rm: cannot remove
>>>> `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1206Thu.18700': No such file
>>>> or directory
>>>> *** launching tests from jam ***
>>>> TESTHOST is linew
>>>> jam
>>>> koala
>>>> ostrich
>>>> loyalty
>>>> freedom
>>>>   Fork off timekeeper 12
>>>> Killed
>>>> cannot remote command with loyalty
>>>> Killed
>>>> cannot remote command with freedom
>>>> cat: #linew_linew.out: No such file or directory
>>>> tail: cannot open `#linew_linew.out' for reading: No such file or directory
>>>> 	Thu Dec  6 20:43:22 CST 2012
>>>> 	****INCOMPLETE linew: snaptest did not complete****
>>>> cat: #jam_jam.out: No such file or directory
>>>> tail: cannot open `#jam_jam.out' for reading: No such file or directory
>>>> 	****INCOMPLETE jam: snaptest did not complete****
>>>> cat: #koala_koala.out: No such file or directory
>>>> tail: cannot open `#koala_koala.out' for reading: No such file or directory
>>>> 	****INCOMPLETE koala: snaptest did not complete****
>>>> cat: #ostrich_ostrich.out: No such file or directory
>>>> tail: cannot open `#ostrich_ostrich.out' for reading: No such file or
>>>> directory
>>>> directory
>>>> 	****INCOMPLETE ostrich: snaptest did not complete****
>>>> cat: #loyalty_loyalty.out: No such file or directory
>>>> tail: cannot open `#loyalty_loyalty.out' for reading: No such file or
>>>> directory
>>>> directory
>>>> 	****INCOMPLETE loyalty: snaptest did not complete****
>>>> freedom does not accept Remote Command (Thu Dec  6 20:42:52 CST 2012)
>>>> 	****SYSTEM ERROR: freedom does not accept Remote Command (Thu Dec  6
>>>> 20:42:52 CST 2012)
>>>> 20:42:52 CST 2012)
>>>> 	****INCOMPLETE freedom: snaptest did not complete****
>>>> *** finished tests in jam ***
>>>> _______________________________________________
>>>> opa-nightly-tests mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
