[opa-nightly-tests] jam OPA_Daily_Tests_1206Thu_FAILED!!!
Dave Goodell
goodell at mcs.anl.gov
Fri Dec 7 11:29:25 CST 2012
What sort of host is ostrich? The source code should not have changed (besides adding a ".gitignore" file), and the tests are passing on my x86_64 laptop when run by hand.
The log output is missing the actual failure message too, so it's hard to diagnose what's going on here.
-Dave
On Dec 6, 2012, at 7:01 PM PST, Larry Knox wrote:
> This is the first run using the new git repository. 1 test failed on
> ostrich. This will give us a good test of the git update assuming a code
> change is necessary to fix the problem.
> There was another test message just before this one from the previous
> night's test. The machines freedom and loyalty are not responding to ssh
> due to hdfgroup changes, pending a reboot by Quincey when he returns. I
> have removed them from the test machine list until that happens.
> Larry
> -----Original Message-----
> From: opa-nightly-tests-bounces at lists.mcs.anl.gov
> [mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
> Sent: Thursday, December 06, 2012 8:43 PM
> To: opa-nightly-tests at lists.mcs.anl.gov
> Subject: [opa-nightly-tests] jam OPA_Daily_Tests_1206Thu_FAILED!!!
> *** OPA Tests on 1206Thu ***
> Tests Summary
> ****FAILED ostrich: standard****
> PASSED jam: standard
> PASSED koala: standard
> PASSED linew: standard
> Tests Time Summary
> koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
> jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
> ostrich: Ran 1(0/1/0) tests, Grand total test time = 1m 40s
> linew: Ran 1(1/0/0) tests, Grand total test time = 2m 47s
> jam: Ran 6(0/0/0) hosts, Grand total test time = 191m 58s
> jam: Ran 6(0/0/0) hosts, Grand total test time = 197m 10s
> jam: Ran 6(0/0/0) hosts, Grand total test time = 153m 39s
> Timekeeper log
> Timekeeper started at Thu Dec 6 18:09:52 CST 2012 Timekeeper sleeping for
> 720 seconds Timekeeper woke up at Thu Dec 6 18:21:52 CST 2012, looking for
> processes to terminate...
> Timekeeper ended at Thu Dec 6 18:21:52 CST 2012
> Tests Failures
> Dumping logfile of ostrich: standard
> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1206Thu_1810
> Testing integer compare-and-swap fairness with 100 threads
> PASSED
> Testing pointer compare-and-swap fairness with 100 threads
> PASSED
> Testing integer swap with 100 threads
> PASSED
> Testing pointer swap with 100 threads
> PASSED
> Testing integer LL/SC stack with 100 threads
> PASSED
> Testing pointer LL/SC stack with 100 threads
> PASSED
> ***** 1 PRIMITIVES TEST FAILED! *****
> FAIL: test_primitives
> Testing memory barrier sanity
> PASSED
> Testing memory barriers with linear array with 2 threads
> PASSED
> Testing memory barriers with local variables with 2 threads
> PASSED
> Testing memory barriers with scattered array with 2 threads
> PASSED
> Testing memory barriers with linear array with 4 threads
> PASSED
> Testing memory barriers with local variables with 4 threads
> PASSED
> Testing memory barriers with scattered array with 4 threads
> PASSED
> Testing memory barriers with linear array with 10 threads
> PASSED
> Testing memory barriers with local variables with 10 threads
> PASSED
> Testing memory barriers with scattered array with 10 threads
> PASSED
> Testing memory barriers with linear array with 100 threads
> PASSED
> Testing memory barriers with local variables with 100 threads
> PASSED
> Testing memory barriers with scattered array with 100 threads
> PASSED
> All barriers tests passed.
> PASS: test_barriers
> Testing queue sanity
> PASSED
> Testing multithreaded queue with 2 threads
> PASSED
> Testing multithreaded queue (empty queue) with 2 threads
> PASSED
> Testing multithreaded queue (full queue) with 2 threads
> PASSED
> Testing multithreaded queue with 4 threads
> PASSED
> Testing multithreaded queue (empty queue) with 4 threads
> PASSED
> Testing multithreaded queue (full queue) with 4 threads
> PASSED
> Testing multithreaded queue with 10 threads
> PASSED
> Testing multithreaded queue (empty queue) with 10 threads
> PASSED
> Testing multithreaded queue (full queue) with 10 threads
> PASSED
> Testing multithreaded queue with 100 threads
> PASSED
> Testing multithreaded queue (empty queue) with 100 threads
> PASSED
> Testing multithreaded queue (full queue) with 100 threads
> PASSED
> All queue tests passed.
> PASS: test_queue
> 1 of 4 tests failed
> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
> gmake[2]: *** [check-TESTS] Error 1
> gmake[2]: Leaving directory
> `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
> gmake[1]: *** [check-am] Error 2
> gmake[1]: Leaving directory
> gmake: *** [check-recursive] Error 1
> Failed running make check
> ===== Exit bin/snapshot with status=2: Thu Dec 6 18:11:55 CST 2012 =====
> Thu Dec 6 18:11:55 CST 2012 ========================= Dumping done
> Runtest did not exit normally.
> Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report it by
> 3pm.
> Watcher for OPA: Neil
> updated: 2009/05/05
> Tests Details
> 18:09:33 up 1 day, 9:03, 18 users, load average: 0.06, 0.26, 0.43
> Filesystem 1K-blocks Used Available Use% Mounted on
> /dev/sda3 31738420 3798708 26301484 13% /
> /dev/sda1 101086 23185 72682 25% /boot
> /dev/sda2 31738420 365712 29734480 2% /tmp
> /dev/sda6 31738392 9891148 20209020 33% /var
> /dev/sda7 31738392 14854308 15245860 50% /usr
> /dev/sda8 124991068 1133300 117406068 1% /var/tmp
> /dev/mapper/VolGroup00-home
> 198351840 17664644 170448836 10% /home
> /dev/sde1 565688764 407775828 128714000 77% /scr
> /dev/sdc1 961432072 816721756 95872316 90% /mnt/scr1
> /dev/sdd1 961432072 759854124 152739948 84% /mnt/hdf
> tmpfs 8313628 0 8313628 0% /dev/shm
> gumund:/data/ftp 480719104 361001344 95298560 80% /mnt/ftp
> gumund:/data/web 480719104 361001344 95298560 80% /mnt/web
> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall TEST_TYPES=standard
> Running source repository checkout with output saved in
> /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1206Thu
> Checking MANIFEST file ...
> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1206Thu.18700: No such
> file or directory
> rm: cannot remove
> `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1206Thu.18700': No such file
> or directory
> *** launching tests from jam ***
> TESTHOST is linew
> jam
> koala
> ostrich
> loyalty
> freedom
> Fork off timekeeper 12
> Killed
> cannot remote command with loyalty
> Killed
> cannot remote command with freedom
> cat: #linew_linew.out: No such file or directory
> tail: cannot open `#linew_linew.out' for reading: No such file or directory
> Thu Dec 6 20:43:22 CST 2012
> ****INCOMPLETE linew: snaptest did not complete****
> cat: #jam_jam.out: No such file or directory
> tail: cannot open `#jam_jam.out' for reading: No such file or directory
> ****INCOMPLETE jam: snaptest did not complete****
> cat: #koala_koala.out: No such file or directory
> tail: cannot open `#koala_koala.out' for reading: No such file or directory
> ****INCOMPLETE koala: snaptest did not complete****
> cat: #ostrich_ostrich.out: No such file or directory
> tail: cannot open `#ostrich_ostrich.out' for reading: No such file or
> directory
> directory
> ****INCOMPLETE ostrich: snaptest did not complete****
> cat: #loyalty_loyalty.out: No such file or directory
> tail: cannot open `#loyalty_loyalty.out' for reading: No such file or
> directory
> directory
> ****INCOMPLETE loyalty: snaptest did not complete****
> freedom does not accept Remote Command (Thu Dec 6 20:42:52 CST 2012)
> ****SYSTEM ERROR: freedom does not accept Remote Command (Thu Dec 6
> 20:42:52 CST 2012)
> 20:42:52 CST 2012)
> ****INCOMPLETE freedom: snaptest did not complete****
> *** finished tests in jam ***
> opa-nightly-tests mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
