[opa-nightly-tests] jam OPA_Daily_Tests_1206Thu_FAILED!!!
Larry Knox
lrknox at hdfgroup.org
Thu Dec 6 21:01:13 CST 2012
This is the first run using the new git repository. 1 test failed on
ostrich. This will give us a good test of the git update assuming a code
change is necessary to fix the problem.
There was another test message just before this one from the previous
night's test. The machines freedom and loyalty are not responding to ssh
due to hdfgroup changes, pending a reboot by Quincey when he returns. I
have removed them from the test machine list until that happens.
Larry
-----Original Message-----
From: opa-nightly-tests-bounces at lists.mcs.anl.gov
[mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
Sent: Thursday, December 06, 2012 8:43 PM
To: opa-nightly-tests at lists.mcs.anl.gov
Subject: [opa-nightly-tests] jam OPA_Daily_Tests_1206Thu_FAILED!!!
*** OPA Tests on 1206Thu ***
Tests Summary
****FAILED ostrich: standard****
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
ostrich: Ran 1(0/1/0) tests, Grand total test time = 1m 40s
linew: Ran 1(1/0/0) tests, Grand total test time = 2m 47s
jam: Ran 6(0/0/0) hosts, Grand total test time = 191m 58s
jam: Ran 6(0/0/0) hosts, Grand total test time = 197m 10s
jam: Ran 6(0/0/0) hosts, Grand total test time = 153m 39s
Timekeeper log
Timekeeper started at Thu Dec 6 18:09:52 CST 2012 Timekeeper sleeping for
720 seconds Timekeeper woke up at Thu Dec 6 18:21:52 CST 2012, looking for
processes to terminate...
Timekeeper ended at Thu Dec 6 18:21:52 CST 2012
Tests Failures
Dumping logfile of ostrich: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1206Thu_1810
Testing integer compare-and-swap fairness with 100 threads
PASSED
Testing pointer compare-and-swap fairness with 100 threads
PASSED
Testing integer swap with 100 threads
PASSED
Testing pointer swap with 100 threads
PASSED
Testing integer LL/SC stack with 100 threads
PASSED
Testing pointer LL/SC stack with 100 threads
PASSED
***** 1 PRIMITIVES TEST FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity
PASSED
Testing memory barriers with linear array with 2 threads
PASSED
Testing memory barriers with local variables with 2 threads
PASSED
Testing memory barriers with scattered array with 2 threads
PASSED
Testing memory barriers with linear array with 4 threads
PASSED
Testing memory barriers with local variables with 4 threads
PASSED
Testing memory barriers with scattered array with 4 threads
PASSED
Testing memory barriers with linear array with 10 threads
PASSED
Testing memory barriers with local variables with 10 threads
PASSED
Testing memory barriers with scattered array with 10 threads
PASSED
Testing memory barriers with linear array with 100 threads
PASSED
Testing memory barriers with local variables with 100 threads
PASSED
Testing memory barriers with scattered array with 100 threads
PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity
PASSED
Testing multithreaded queue with 2 threads
PASSED
Testing multithreaded queue (empty queue) with 2 threads
PASSED
Testing multithreaded queue (full queue) with 2 threads
PASSED
Testing multithreaded queue with 4 threads
PASSED
Testing multithreaded queue (empty queue) with 4 threads
PASSED
Testing multithreaded queue (full queue) with 4 threads
PASSED
Testing multithreaded queue with 10 threads
PASSED
Testing multithreaded queue (empty queue) with 10 threads
PASSED
Testing multithreaded queue (full queue) with 10 threads
PASSED
Testing multithreaded queue with 100 threads
PASSED
Testing multithreaded queue (empty queue) with 100 threads
PASSED
Testing multithreaded queue (full queue) with 100 threads
PASSED
All queue tests passed.
PASS: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory
`/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Thu Dec 6 18:11:55 CST 2012 =====
Thu Dec 6 18:11:55 CST 2012 ========================= Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it by
3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
18:09:33 up 1 day, 9:03, 18 users, load average: 0.06, 0.26, 0.43
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3798708 26301484 13% /
/dev/sda1 101086 23185 72682 25% /boot
/dev/sda2 31738420 365712 29734480 2% /tmp
/dev/sda6 31738392 9891148 20209020 33% /var
/dev/sda7 31738392 14854308 15245860 50% /usr
/dev/sda8 124991068 1133300 117406068 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 17664644 170448836 10% /home
/dev/sde1 565688764 407775828 128714000 77% /scr
/dev/sdc1 961432072 816721756 95872316 90% /mnt/scr1
/dev/sdd1 961432072 759854124 152739948 84% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 361001344 95298560 80% /mnt/ftp
gumund:/data/web 480719104 361001344 95298560 80% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1206Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1206Thu.18700: No such
file or directory
rm: cannot remove
`/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1206Thu.18700': No such file
or directory
*** launching tests from jam ***
TESTHOST is linew
jam
koala
ostrich
loyalty
freedom
Fork off timekeeper 12
Killed
cannot remote command with loyalty
Killed
cannot remote command with freedom
cat: #linew_linew.out: No such file or directory
tail: cannot open `#linew_linew.out' for reading: No such file or directory
Thu Dec 6 20:43:22 CST 2012
****INCOMPLETE linew: snaptest did not complete****
cat: #jam_jam.out: No such file or directory
tail: cannot open `#jam_jam.out' for reading: No such file or directory
****INCOMPLETE jam: snaptest did not complete****
cat: #koala_koala.out: No such file or directory
tail: cannot open `#koala_koala.out' for reading: No such file or directory
****INCOMPLETE koala: snaptest did not complete****
cat: #ostrich_ostrich.out: No such file or directory
tail: cannot open `#ostrich_ostrich.out' for reading: No such file or
directory
directory
****INCOMPLETE ostrich: snaptest did not complete****
cat: #loyalty_loyalty.out: No such file or directory
tail: cannot open `#loyalty_loyalty.out' for reading: No such file or
directory
directory
****INCOMPLETE loyalty: snaptest did not complete****
freedom does not accept Remote Command (Thu Dec 6 20:42:52 CST 2012)
****SYSTEM ERROR: freedom does not accept Remote Command (Thu Dec 6
20:42:52 CST 2012)
20:42:52 CST 2012)
****INCOMPLETE freedom: snaptest did not complete****
*** finished tests in jam ***
opa-nightly-tests mailing list
https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
