[opa-nightly-tests] jam OPA_Daily_Tests_0423Mon_FAILED!!!
Dave Goodell goodell at mcs.anl.gov
Mon Apr 23 09:12:02 CDT 2012
Looks like a failure on pcc64.  Maybe some missing memory barriers in the LL/SC stack test?
-Dave
On Apr 23, 2012, at 12:15 AM CDT, HDF Tester wrote:
> *** OPA Tests on 0423Mon ***
>   Tests Summary
> ****FAILED ostrich: standard****
> PASSED freedom: standard
> PASSED jam: standard
> PASSED koala: standard
> PASSED linew: standard
> PASSED loyalty: standard
>   Tests Time Summary
> koala: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
> jam: Ran 1(1/0/0) tests, Grand total test time =  1m 21s
> freedom: Ran 1(1/0/0) tests, Grand total test time =  1m 24s
> loyalty: Ran 1(1/0/0) tests, Grand total test time =  1m 26s
> ostrich: Ran 1(0/1/0) tests, Grand total test time =  2m 36s
> linew: Ran 1(1/0/0) tests, Grand total test time =  3m 47s
> jam: Ran 6(0/0/0) hosts, Grand total test time =  4m 47s
>   Timekeeper log
> Timekeeper started at Mon Apr 23 00:10:46 CDT 2012
> Timekeeper sleeping for 1800 seconds
>   Tests Failures
> Dumping logfile of ostrich: standard
> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0423Mon_0011
> Testing integer swap with 100 threads                                  PASSED
> Testing pointer swap with 100 threads                                  PASSED
> Testing integer LL/SC stack with 100 threads                          *WARNING*
>    Only 969996/970000 pushes succeeded.  There may be an issue with fairness.
> Testing pointer LL/SC stack with 100 threads                          *WARNING*
> ***** 1 PRIMITIVES TEST FAILED! *****
> FAIL: test_primitives
> Testing memory barrier sanity                                          PASSED
> Testing memory barriers with linear array with 2 threads               PASSED
> Testing memory barriers with local variables with 2 threads            PASSED
> Testing memory barriers with scattered array with 2 threads            PASSED
> Testing memory barriers with linear array with 4 threads               PASSED
> Testing memory barriers with local variables with 4 threads            PASSED
> Testing memory barriers with scattered array with 4 threads            PASSED
> Testing memory barriers with linear array with 10 threads              PASSED
> Testing memory barriers with local variables with 10 threads           PASSED
> Testing memory barriers with scattered array with 10 threads           PASSED
> Testing memory barriers with linear array with 100 threads             PASSED
> Testing memory barriers with local variables with 100 threads          PASSED
> Testing memory barriers with scattered array with 100 threads          PASSED
> All barriers tests passed.
> PASS: test_barriers
> Testing queue sanity                                                   PASSED
> Testing multithreaded queue with 2 threads                             PASSED
> Testing multithreaded queue (empty queue) with 2 threads               PASSED
> Testing multithreaded queue (full queue) with 2 threads                PASSED
> Testing multithreaded queue with 4 threads                             PASSED
> Testing multithreaded queue (empty queue) with 4 threads               PASSED
> Testing multithreaded queue (full queue) with 4 threads                PASSED
> Testing multithreaded queue with 10 threads                            PASSED
> Testing multithreaded queue (empty queue) with 10 threads              PASSED
> Testing multithreaded queue (full queue) with 10 threads               PASSED
> Testing multithreaded queue with 100 threads                           PASSED
> Testing multithreaded queue (empty queue) with 100 threads             PASSED
> Testing multithreaded queue (full queue) with 100 threads              PASSED
> All queue tests passed.
> PASS: test_queue
> 1 of 4 tests failed
> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
> gmake[2]: *** [check-TESTS] Error 1
> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
> gmake[1]: *** [check-am] Error 2
> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
> gmake: *** [check-recursive] Error 1
> Failed running make check
> ===== Exit bin/snapshot with status=2: Mon Apr 23 00:13:44 CDT 2012 =====
> Dumping done
> Runtest did not exit normally.
>   Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report it
> by 3pm.
> Watcher for OPA:	 	Neil
> updated: 2009/05/05
>   Tests Details
> 00:10:21 up 32 days, 15:18, 96 users,  load average: 2.15, 1.79, 1.40
> Filesystem           1K-blocks      Used Available Use% Mounted on
> /dev/sda3             31738420   4014012  26086180  14% /
> /dev/sda1               101086     34394     61473  36% /boot
> /dev/sda2             31738420    180648  29919544   1% /tmp
> /dev/sda6             31738392   3983132  26117036  14% /var
> /dev/sda7             31738392  26976908   3123260  90% /usr
> /dev/sda8            124991068    343896 118195472   1% /var/tmp
> /dev/mapper/VolGroup00-home
>                     198351840  14951516 173161964   8% /home
> /dev/sde1            565688764 429320064 107169764  81% /scr
> /dev/sdc1            961432072 678358756 234235316  75% /mnt/scr1
> /dev/sdd1            961432072 784958516 127635556  87% /mnt/hdf
> tmpfs                  8313848         0   8313848   0% /dev/shm
> gumund:/data/ftp     480719104 330136576 126163328  73% /mnt/ftp
> gumund:/data/web     480719104 330136576 126163328  73% /mnt/web
> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
> TEST_TYPES=standard
> Running source repository checkout with output saved in
>   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0423Mon
> Checking MANIFEST file ...
> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0423Mon.27083: No such file or directory
> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0423Mon.27083': No such file or directory
> *** launching tests from jam ***
> TESTHOST is linew
> jam
> koala
> ostrich
> loyalty
> freedom
>    Fork off timekeeper 30
> Testing linew
> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
> 12:10am  up 3 day(s), 12:10,  0 users,  load average: 0.02, 0.02, 0.03
> /                  (/dev/dsk/c1t0d0s0 ):50754410 blocks  8221246 files
> /devices           (/devices          ):       0 blocks        0 files
> /system/contract   (ctfs              ):       0 blocks 2147483605 files
> /proc              (proc              ):       0 blocks    29945 files
> /etc/mnttab        (mnttab            ):       0 blocks        0 files
> /etc/svc/volatile  (swap              ):21102816 blocks  1180602 files
> /system/object     (objfs             ):       0 blocks 2147483490 files
> /etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):50754410 blocks  8221246 files
> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):50754410 blocks  8221246 files
> /dev/fd            (fd                ):       0 blocks        0 files
> /tmp               (swap              ):21102512 blocks  1180602 files
> /var/run           (swap              ):21102512 blocks  1180602 files
> /scr               (/dev/dsk/c1t1d0s0 ):861210130 blocks 226682796 files
> /home              (jam:/home         ):366800648 blocks 50905395 files
> /mnt/hdf           (jam:/mnt/hdf      ):352947112 blocks 113564784 files
> /mnt/scr1          (jam:/mnt/scr1     ):566144752 blocks 118638406 files
> /mnt/web           (gumund:/mnt/web   ):301164808 blocks 60877640 files
> /mnt/ftp           (gumund:/mnt/ftp   ):301164808 blocks 60877640 files
> TEST_TYPES=standard
> Mon Apr 23 00:11:02 CDT 2012
> *** starting standard tests in linew ***
> Uname -a: SunOS linew 5.10 Generic_147440-15 sun4u sparc SUNW,A70
> Running snapshot with output saved in
>   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0423Mon_0011
> *** finished standard tests for linew ***
> Mon Apr 23 00:14:48 CDT 2012
> Total time = 3m 46s
> *** finished tests in linew ***
> Testing jam
> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
> 00:10:53 up 32 days, 15:18, 96 users,  load average: 2.30, 1.85, 1.43
> /dev/sda3             31738420   4014016  26086176  14% /
> /dev/sda2             31738420    180768  29919424   1% /tmp
> /dev/sda6             31738392   3983136  26117032  14% /var
> /dev/sdc1            961432072 678359720 234234352  75% /mnt/scr1
> TEST_TYPES=standard
> Mon Apr 23 00:11:03 CDT 2012
> *** starting standard tests in jam ***
> Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
>   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0423Mon_0011
> *** finished standard tests for jam ***
> Mon Apr 23 00:12:24 CDT 2012
> Total time = 1m 21s
> *** finished tests in jam ***
> Testing koala
> ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
> 00:10:55 up 2 days, 11:17,  2 users,  load average: 0.00, 0.00, 0.00
> /dev/sda7             22292052  17537616   3603784  83% /
> /dev/sda5             12192608    498988  11064276   5% /tmp
> /dev/sda3             12192636   1293772  10269520  12% /var
> /dev/sda1               101086     37243     58624  39% /boot
> tmpfs                  6149560         0   6149560   0% /dev/shm
> /dev/sdd1             41279536  22244100  16938556  57% /usr
> /dev/md0              48091528  37300400   8348200  82% /scr
> jam:/home            198351840  14951488 173161984   8% /home
> jam:/mnt/hdf         961432096 784958528 127635584  87% /mnt/hdf
> jam:/mnt/scr1        961432096 678359872 234234240  75% /mnt/scr1
> TEST_TYPES=standard
> Mon Apr 23 00:11:05 CDT 2012
> *** starting standard tests in koala ***
> Uname -a: Linux koala 2.6.18-308.4.1.el5 #1 SMP Tue Apr 17 17:08:00 EDT 2012 x86_64 x86_64 x86_64 GNU/Linux
>   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0423Mon_0011
> *** finished standard tests for koala ***
> Mon Apr 23 00:11:49 CDT 2012
> Total time = 0m 44s
> *** finished tests in koala ***
> Testing ostrich
> ssh ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
> 00:10:58 up 45 days, 12:09,  2 users,  load average: 0.00, 0.00, 0.00
> /dev/mapper/vg_ostrich-lv_root
>                     140610456   9054328 124417084   7% /
> tmpfs                  7821760         0   7821760   0% /dev/shm
> /dev/sda2               495844    130766    339478  28% /boot
> /dev/sdb2            124608436   1490984 116787700   2% /scr
> jam:/mnt/scr1        961432096 678359904 234234208  75% /mnt/scr1
> gumund:/data/ftp     480719072 330136640 126163232  73% /mnt/ftp
> gumund:/data/web     480719072 330136640 126163232  73% /mnt/web
> TEST_TYPES=standard
> Mon Apr 23 00:11:08 CDT 2012
> *** starting standard tests in ostrich ***
> Uname -a: Linux ostrich 2.6.32-220.7.1.el6.ppc64 #1 SMP Fri Feb 10 15:24:28 EST 2012 ppc64 ppc64 ppc64 GNU/Linux
> *** finished standard tests for ostrich ***
> Total time = 2m 36s
> *** finished tests in ostrich ***
> ****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
> 	Mon Apr 23 00:15:18 CDT 2012
> 	****SYSTEM ERROR ostrich: runtest command failed ****
> Testing loyalty
> ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
> grep: /proc/cpuinfo: No such file or directory
> 12:11AM  up 45 days, 10:25, 0 users, load averages: 0.00, 0.00, 0.00
> Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
> /dev/da0s1a         507630    103648    363372    22%    /
> devfs                    1         1         0   100%    /dev
> /dev/da0s1g       58896528  31170704  23014102    58%    /local_home
> /dev/da0s1f       16244334   4862524  10082264    33%    /usr
> /dev/da0s1d        1012974    203388    728550    22%    /var
> /dev/da0s1e         507630     16732    450288     4%    /var/tmp
> procfs                   4         4         0   100%    /proc
> jam:/home        198351840  14951516 173161964     8%    /home
> jam:/mnt/hdf     961432072 784958516 127635556    86%    /mnt/hdf
> jam:/mnt/scr1    961432072 678359968 234234104    74%    /mnt/scr1
> gumund:/data/web 480719056 330136652 126163204    72%    /mnt/web
> gumund:/data/ftp 480719056 330136652 126163204    72%    /mnt/ftp
> devfs                    1         1         0   100%    /var/named/dev
> /dev/md0            126702        26    116540     0%    /tmp
> TEST_TYPES=standard
> Mon Apr 23 00:11:11 CDT 2012
> *** starting standard tests in loyalty ***
> Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May  3 22:23:36 CDT 2011     sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY  i386
>   /mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0423Mon_0011
> *** finished standard tests for loyalty ***
> Mon Apr 23 00:12:37 CDT 2012
> Total time = 1m 26s
> *** finished tests in loyalty ***
> Testing freedom
> ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
> 12:11AM  up 45 days, 10:25, 2 users, load averages: 0.00, 0.00, 0.00
> /dev/da0s1a         507630    116218    350802    25%    /
> /dev/da0s1g       45184754  28993502  12576472    70%    /local_home
> /dev/da0s1f       24372460   5411794  17010870    24%    /usr
> /dev/da0s1d        2026030    201314   1662634    11%    /var
> /dev/da0s1e        1012974    542144    389794    58%    /var/tmp
> jam:/home        198351840  14951516 173161964     8%    /usr/home
> jam:/mnt/scr1    961432072 678360072 234234000    74%    /mnt/scr1
> /dev/md0            126702       136    116430     0%    /tmp
> TEST_TYPES=standard
> Mon Apr 23 00:11:13 CDT 2012
> *** starting standard tests in freedom ***
> Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May  3 22:26:37 CDT 2011     sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM  amd64
>   /mnt/scr1/SnapTest/snapshots-opa/log/freedom_0423Mon_0011
> *** finished standard tests for freedom ***
> Total time = 1m 24s
> *** finished tests in freedom ***
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
