[opa-nightly-tests] jam OPA_Daily_Tests_0423Mon_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Mon Apr 23 00:15:18 CDT 2012
*** OPA Tests on 0423Mon ***
Tests Summary
****FAILED ostrich: standard****
PASSED freedom: standard
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
PASSED loyalty: standard
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
freedom: Ran 1(1/0/0) tests, Grand total test time = 1m 24s
loyalty: Ran 1(1/0/0) tests, Grand total test time = 1m 26s
ostrich: Ran 1(0/1/0) tests, Grand total test time = 2m 36s
linew: Ran 1(1/0/0) tests, Grand total test time = 3m 47s
jam: Ran 6(0/0/0) hosts, Grand total test time = 4m 47s
Timekeeper log
Timekeeper started at Mon Apr 23 00:10:46 CDT 2012
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of ostrich: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0423Mon_0011
Testing integer swap with 100 threads PASSED
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack with 100 threads *WARNING*
Only 969996/970000 pushes succeeded. There may be an issue with fairness.
Testing pointer LL/SC stack with 100 threads *WARNING*
***** 1 PRIMITIVES TEST FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads PASSED
All queue tests passed.
PASS: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Mon Apr 23 00:13:44 CDT 2012 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:21 up 32 days, 15:18, 96 users, load average: 2.15, 1.79, 1.40
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4014012 26086180 14% /
/dev/sda1 101086 34394 61473 36% /boot
/dev/sda2 31738420 180648 29919544 1% /tmp
/dev/sda6 31738392 3983132 26117036 14% /var
/dev/sda7 31738392 26976908 3123260 90% /usr
/dev/sda8 124991068 343896 118195472 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 14951516 173161964 8% /home
/dev/sde1 565688764 429320064 107169764 81% /scr
/dev/sdc1 961432072 678358756 234235316 75% /mnt/scr1
/dev/sdd1 961432072 784958516 127635556 87% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719104 330136576 126163328 73% /mnt/ftp
gumund:/data/web 480719104 330136576 126163328 73% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0423Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0423Mon.27083: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0423Mon.27083': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
koala
ostrich
loyalty
freedom
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 3 day(s), 12:10, 0 users, load average: 0.02, 0.02, 0.03
/ (/dev/dsk/c1t0d0s0 ):50754410 blocks 8221246 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483605 files
/proc (proc ): 0 blocks 29945 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):21102816 blocks 1180602 files
/system/object (objfs ): 0 blocks 2147483490 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):50754410 blocks 8221246 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):50754410 blocks 8221246 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):21102512 blocks 1180602 files
/var/run (swap ):21102512 blocks 1180602 files
/scr (/dev/dsk/c1t1d0s0 ):861210130 blocks 226682796 files
/home (jam:/home ):366800648 blocks 50905395 files
/mnt/hdf (jam:/mnt/hdf ):352947112 blocks 113564784 files
/mnt/scr1 (jam:/mnt/scr1 ):566144752 blocks 118638406 files
/mnt/web (gumund:/mnt/web ):301164808 blocks 60877640 files
/mnt/ftp (gumund:/mnt/ftp ):301164808 blocks 60877640 files
TEST_TYPES=standard
Mon Apr 23 00:11:02 CDT 2012
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_147440-15 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0423Mon_0011
*** finished standard tests for linew ***
Mon Apr 23 00:14:48 CDT 2012
Total time = 3m 46s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:53 up 32 days, 15:18, 96 users, load average: 2.30, 1.85, 1.43
/dev/sda3 31738420 4014016 26086176 14% /
/dev/sda2 31738420 180768 29919424 1% /tmp
/dev/sda6 31738392 3983136 26117032 14% /var
/dev/sdc1 961432072 678359720 234234352 75% /mnt/scr1
TEST_TYPES=standard
Mon Apr 23 00:11:03 CDT 2012
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0423Mon_0011
*** finished standard tests for jam ***
Mon Apr 23 00:12:24 CDT 2012
Total time = 1m 21s
*** finished tests in jam ***
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:10:55 up 2 days, 11:17, 2 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 17537616 3603784 83% /
/dev/sda5 12192608 498988 11064276 5% /tmp
/dev/sda3 12192636 1293772 10269520 12% /var
/dev/sda1 101086 37243 58624 39% /boot
tmpfs 6149560 0 6149560 0% /dev/shm
/dev/sdd1 41279536 22244100 16938556 57% /usr
/dev/md0 48091528 37300400 8348200 82% /scr
jam:/home 198351840 14951488 173161984 8% /home
jam:/mnt/hdf 961432096 784958528 127635584 87% /mnt/hdf
jam:/mnt/scr1 961432096 678359872 234234240 75% /mnt/scr1
TEST_TYPES=standard
Mon Apr 23 00:11:05 CDT 2012
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-308.4.1.el5 #1 SMP Tue Apr 17 17:08:00 EDT 2012 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0423Mon_0011
*** finished standard tests for koala ***
Mon Apr 23 00:11:49 CDT 2012
Total time = 0m 44s
*** finished tests in koala ***
Testing ostrich
ssh ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
00:10:58 up 45 days, 12:09, 2 users, load average: 0.00, 0.00, 0.00
/dev/mapper/vg_ostrich-lv_root
140610456 9054328 124417084 7% /
tmpfs 7821760 0 7821760 0% /dev/shm
/dev/sda2 495844 130766 339478 28% /boot
/dev/sdb2 124608436 1490984 116787700 2% /scr
jam:/mnt/scr1 961432096 678359904 234234208 75% /mnt/scr1
gumund:/data/ftp 480719072 330136640 126163232 73% /mnt/ftp
gumund:/data/web 480719072 330136640 126163232 73% /mnt/web
TEST_TYPES=standard
Mon Apr 23 00:11:08 CDT 2012
*** starting standard tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-220.7.1.el6.ppc64 #1 SMP Fri Feb 10 15:24:28 EST 2012 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard tests for ostrich ***
Total time = 2m 36s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
****SYSTEM ERROR ostrich: runtest command failed ****
Testing loyalty
ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
grep: /proc/cpuinfo: No such file or directory
12:11AM up 45 days, 10:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/da0s1a 507630 103648 363372 22% /
devfs 1 1 0 100% /dev
/dev/da0s1g 58896528 31170704 23014102 58% /local_home
/dev/da0s1f 16244334 4862524 10082264 33% /usr
/dev/da0s1d 1012974 203388 728550 22% /var
/dev/da0s1e 507630 16732 450288 4% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 14951516 173161964 8% /home
jam:/mnt/hdf 961432072 784958516 127635556 86% /mnt/hdf
jam:/mnt/scr1 961432072 678359968 234234104 74% /mnt/scr1
gumund:/data/web 480719056 330136652 126163204 72% /mnt/web
gumund:/data/ftp 480719056 330136652 126163204 72% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 26 116540 0% /tmp
TEST_TYPES=standard
Mon Apr 23 00:11:11 CDT 2012
*** starting standard tests in loyalty ***
Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May 3 22:23:36 CDT 2011 sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY i386
/mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0423Mon_0011
*** finished standard tests for loyalty ***
Mon Apr 23 00:12:37 CDT 2012
Total time = 1m 26s
*** finished tests in loyalty ***
Testing freedom
ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
12:11AM up 45 days, 10:25, 2 users, load averages: 0.00, 0.00, 0.00
/dev/da0s1a 507630 116218 350802 25% /
/dev/da0s1g 45184754 28993502 12576472 70% /local_home
/dev/da0s1f 24372460 5411794 17010870 24% /usr
/dev/da0s1d 2026030 201314 1662634 11% /var
/dev/da0s1e 1012974 542144 389794 58% /var/tmp
jam:/home 198351840 14951516 173161964 8% /usr/home
jam:/mnt/scr1 961432072 678360072 234234000 74% /mnt/scr1
/dev/md0 126702 136 116430 0% /tmp
TEST_TYPES=standard
Mon Apr 23 00:11:13 CDT 2012
*** starting standard tests in freedom ***
Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May 3 22:26:37 CDT 2011 sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM amd64
/mnt/scr1/SnapTest/snapshots-opa/log/freedom_0423Mon_0011
*** finished standard tests for freedom ***
Total time = 1m 24s
*** finished tests in freedom ***
More information about the opa-nightly-tests
