[opa-nightly-tests] jam OPA_Daily_Tests_0211Fri_FAILED!!!
Larry Knox lrknox at hdfgroup.org
Fri Feb 11 10:43:39 CST 2011
-----Original Message-----
From: opa-nightly-tests-bounces at lists.mcs.anl.gov
[mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of Dave
Goodell
Sent: Friday, February 11, 2011 10:04 AM
To: HDF Tester
Cc: opa-nightly-tests at lists.mcs.anl.gov
Subject: Re: [opa-nightly-tests] jam OPA_Daily_Tests_0211Fri_FAILED!!!
I updated configure.in in r113, which probably caused this directly or
indirectly.  Does the nightly test script still not run "autoreconf -vif"
before running the tests?  Or did I actually manage to break something this
time?
	I couldn't remember, so I looked it up.  The nightly test script
does in fact run "autoreconf -vif" before running the tests.
	Larry
-Dave
On Feb 11, 2011, at 12:15 AM CST, HDF Tester wrote:
> *** OPA Tests on 0211Fri ***
>   Tests Summary
> ****FAILED duty: standard****
> ****FAILED jam: standard****
> ****FAILED liberty: standard****
> ****FAILED linew: standard****
>   Tests Time Summary
> jam: Ran 1(0/1/0) tests, Grand total test time =  0m 7s
> liberty: Ran 1(0/1/0) tests, Grand total test time =  0m 12s
> duty: Ran 1(0/1/0) tests, Grand total test time =  0m 29s
> linew: Ran 1(0/1/0) tests, Grand total test time =  4m 8s
> jam: Ran 4(0/0/0) hosts, Grand total test time =  5m 5s
>   Timekeeper log
> Timekeeper started at Fri Feb 11 00:10:30 CST 2011
> Timekeeper sleeping for 1800 seconds
>   Tests Failures
> Dumping logfile of jam: standard
> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jam_0211Fri_0010
> /bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.
-I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF
.deps/opa_queue.Tpo -c -o opa_queue.lo
/home/hdftest/snapshots-opa/current/src/opa_queue.c
> libtool: compile:  gcc -DHAVE_CONFIG_H -I.
-I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF
.deps/opa_primitives.Tpo -c
/home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
.deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c
-o opa_queue.o
> In file included from
/home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
>                 from
/home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
> /home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: error:
#error no primitives implementation specified
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: expected
specifier-qualifier-list before 'OPA_ptr_t'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function
'OPA_Shm_rel_to_abs':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error:
'OPA_Shm_rel_addr_t' has no member named 'offset'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning:
initialization makes pointer from integer without a cast
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: 'size_t'
undeclared (first use in this function)
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each
undeclared identifier is reported only once
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each
function it appears in.)
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: expected
')' before 'offset'
'OPA_Shm_abs_to_rel':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error:
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: 'size_t'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: expected
')' before 'a'
'OPA_Shm_swap_rel':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error:
'OPA_Shm_cas_rel_null':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error:
'OPA_Queue_is_empty':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error:
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error:
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error:
'OPA_Queue_peek_head':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error:
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: 'NULL'
> /home/hdftest/snapshots-opa/current/src/opa_queue.c: In function
'OPA_Queue_init':
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error:
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error:
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error:
'OPA_Queue_header_init':
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error:
> gmake[2]: *** [opa_queue.lo] Error 1
> gmake[2]: *** Waiting for unfinished jobs....
> mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jam/src'
> gmake[1]: *** [all] Error 2
> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jam/src'
> gmake: *** [all-recursive] Error 1
> Failed running make
> ===== Exit bin/snapshot with status=2: Fri Feb 11 00:10:54 CST 2011 =====
> Dumping done
> Dumping logfile of liberty: standard
> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0211Fri_0010
-MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo
-o opa_queue.o
>                 from
> /home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax
error before "OPA_ptr_t"
`OPA_Shm_rel_to_abs':mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure
has no member named `offset'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax
error before "offset"
`OPA_Shm_abs_to_rel':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax
error before "a"
`OPA_Shm_swap_rel':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure
`OPA_Shm_cas_rel_null':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure
`OPA_Queue_is_empty':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure
`OPA_Queue_peek_head':
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL'
`OPA_Queue_init':
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure
`OPA_Queue_header_init':
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure
`/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
> Failed running make
> ===== Exit bin/snapshot with status=0: Fri Feb 11 00:11:04 CST 2011 =====
> Dumping done
> Dumping logfile of duty: standard
> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0211Fri_0010
-o opa_queue.o
>                 from
initialization makes pointer from integer without a castmv -f
error before "a"
`OPA_Shm_swap_rel':
`OPA_Queue_init':
`/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
> Failed running make
> ===== Exit bin/snapshot with status=0: Fri Feb 11 00:11:19 CST 2011 =====
> Dumping done
> Dumping logfile of linew: standard
> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0211Fri_0010
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `oldv'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `addr'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `newv'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h: At top level:
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:90: error: syntax
error before "OPA_Shm_cas_rel_null"
error before '*' token
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:91: error: syntax
error before "prev"
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `prev'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `addr'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `oldv'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:140: error: syntax
error before "OPA_Shm_rel_addr_t"
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:140: warning: no
semicolon at end of struct or union
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:141: warning: data
definition has no type or storage class
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:143: error: syntax
error before "shadow_head"
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:143: warning: data
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:145: error: syntax
error before '}' token
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:145: warning: data
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:151: error: syntax
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:151: warning: no
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:152: warning: data
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:156: error: syntax
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:159: error: syntax
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:162: error: syntax
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: `qhead'
> /home/hdftest/snapshots-opa/current/src/opa_queue.h:192: error: syntax
`qhead_ptr' undeclared (first use in this function)
> /home/hdftest/snapshots-opa/current/src/opa_queue.c: At top level:
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:29: error: syntax
`OPA_Queue_init':
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: `qhead'
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:36: error: syntax
> /home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: `hdr'
> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
> Failed running make
> ===== Exit bin/snapshot with status=0: Fri Feb 11 00:14:52 CST 2011 =====
> Dumping done
> Runtest did not exit normally.
>   Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report it
> by 3pm.
> Watcher for OPA:	 	Neil
> updated: 2009/05/05
>   Tests Details
> 00:10:09 up 7 days, 15:42, 42 users,  load average: 2.09, 2.07, 2.06
> Filesystem           1K-blocks      Used Available Use% Mounted on
> /dev/sda3             31738420   3980308  26119884  14% /
> /dev/sda1               101086     22885     72982  24% /boot
> /dev/sda2             31738420    249136  29851056   1% /tmp
> /dev/sda6             31738392   5897308  24202860  20% /var
> /dev/sda7             31738392  28756148   1344020  96% /usr
> /dev/sda8            124991068    326748 118212620   1% /var/tmp
> /dev/mapper/VolGroup00-home
>                     198351840  14880880 173232600   8% /home
> /dev/sde1            565688764 374907084 161582744  70% /scr
> /dev/sdc1            961432072 718721912 193872160  79% /mnt/scr1
> /dev/sdd1            961432072 803554532 109039540  89% /mnt/hdf
> tmpfs                  8313848         0   8313848   0% /dev/shm
> gumund:/data/ftp     480719072 273486976 182812896  60% /mnt/ftp
> gumund:/data/web     480719072 273486976 182812896  60% /mnt/web
> pegdub:/mnt/rw-src   288451232 179417888  94380864  66% /mnt/ro-src
> pegdub:/mnt/rw-src   288451232 179417888  94380864  66% /mnt/rw-src
> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
> TEST_TYPES=standard
> Running source repository checkout with output saved in
>   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0211Fri
> Checking MANIFEST file ...
> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0211Fri.17488: No such
file or directory
> rm: cannot remove
`/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0211Fri.17488': No such file
or directory
> *** launching tests from jam ***
> TESTHOST is linew
> jam
> duty
> liberty
>    Fork off timekeeper 30
> Testing linew
> ssh linew -n cd
/home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest
-nodiff -norepo -configname linew
> 12:10am  up 17 day(s), 11:33,  0 users,  load average: 1.09, 0.99, 0.55
> /                  (/dev/dsk/c1t0d0s0 ):62409962 blocks  8253990 files
> /devices           (/devices          ):       0 blocks        0 files
> /system/contract   (ctfs              ):       0 blocks 2147483610 files
> /proc              (proc              ):       0 blocks    29939 files
> /etc/mnttab        (mnttab            ):       0 blocks        0 files
> /etc/svc/volatile  (swap              ):20649424 blocks  1182273 files
> /system/object     (objfs             ):       0 blocks 2147483500 files
> /etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_
psr_hwcap1.so.1):62409962 blocks  8253990 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv
9/libc_psr/libc_psr_hwcap1.so.1):62409962 blocks  8253990 files
> /dev/fd            (fd                ):       0 blocks        0 files
> /tmp               (swap              ):20649424 blocks  1182273 files
> /var/run           (swap              ):20649424 blocks  1182273 files
> /home              (jam:/home         ):366941920 blocks 50919326 files
> /mnt/hdf           (jam:/mnt/hdf      ):315755080 blocks 114854318 files
> /mnt/scr1          (jam:/mnt/scr1     ):485418776 blocks 117160712 files
> /mnt/web           (gumund:/mnt/web   ):414464152 blocks 60891512 files
> /mnt/ftp           (gumund:/mnt/ftp   ):414464152 blocks 60891512 files
> TEST_TYPES=standard
> Fri Feb 11 00:10:57 CST 2011
> *** starting standard tests in linew ***
> Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
> Running snapshot with output saved in
> *** finished standard tests for linew ***
> Total time = 3m 56s
> *** finished tests in linew ***
> Fri Feb 11 00:14:53 CST 2011
> ****SYSTEM ERROR linew: Abnormal exit from runtest ****
> 	Fri Feb 11 00:15:24 CST 2011
> 	****SYSTEM ERROR linew: runtest command failed ****
> Testing jam
> ssh jam -n cd
-nodiff -norepo -configname jam
> 00:10:37 up 7 days, 15:42, 42 users,  load average: 2.27, 2.11, 2.08
> /dev/sda2             31738420    249260  29850932   1% /tmp
> /dev/sda6             31738392   5897312  24202856  20% /var
> /dev/sdc1            961432072 718722744 193871328  79% /mnt/scr1
> TEST_TYPES=standard
> Fri Feb 11 00:10:47 CST 2011
> *** starting standard tests in jam ***
> Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT
2010 i686 i686 i386 GNU/Linux
> *** finished standard tests for jam ***
> Total time = 0m 7s
> *** finished tests in jam ***
> ****SYSTEM ERROR jam: Abnormal exit from runtest ****
> 	****SYSTEM ERROR jam: runtest command failed ****
> Testing duty
> ssh duty -n cd
-nodiff -norepo -configname duty
> 12:10AM  up 43 days,  9:25, 0 users, load averages: 0.00, 0.00, 0.00
> Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
> /dev/aacd0s1a       507630     60990    406030    13%    /
> devfs                    1         1         0   100%    /dev
> /dev/aacd0s1h    188433016 123604522  49753854    71%    /data
> /dev/aacd0s1g     32494668  25345144   4549952    85%    /local_home
> /dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
> /dev/aacd0s1d       507630     50460    416560    11%    /var
> /dev/aacd0s1e       253678       178    233206     0%    /var/tmp
> procfs                   4         4         0   100%    /proc
> jam:/home        198351840  14880880 173232600     8%    /home
> jam:/mnt/hdf     961432072 803554532 109039540    88%    /mnt/hdf
> jam:/mnt/scr1    961432072 718722812 193871260    79%    /mnt/scr1
> gumund:/data/web 480719056 273486980 182812876    60%    /mnt/web
> gumund:/data/ftp 480719056 273486980 182812876    60%    /mnt/ftp
> devfs                    1         1         0   100%    /var/named/dev
> /dev/md0            126702        76    116490     0%    /tmp
> TEST_TYPES=standard
> Fri Feb 11 00:10:50 CST 2011
> *** starting standard tests in duty ***
> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1:
Fri Jul 25 17:10:59 CDT 2008
sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
> *** finished standard tests for duty ***
> Total time = 0m 29s
> *** finished tests in duty ***
> ****SYSTEM ERROR duty: Abnormal exit from runtest ****
> 	****SYSTEM ERROR duty: runtest command failed ****
> Testing liberty
> ssh liberty -n cd
-nodiff -norepo -configname liberty
> 12:10AM  up 56 days, 13:18, 2 users, load averages: 0.00, 0.00, 0.00
> /dev/aacd0s1a       507630     86918    380102    19%    /
> /dev/aacd0s1g     47047830  31099734  12184270    72%    /local_home
> /dev/aacd0s1f     12186190   7420280   3791016    66%    /usr
> /dev/aacd0s1d      1012974    104166    827772    11%    /var
> /dev/aacd0s1e       507630     62724    404296    13%    /var/tmp
> jam:/mnt/scr1    961432072 718722884 193871188    79%    /mnt/scr1
> /dev/md0            126702        20    116546     0%    /tmp
> TEST_TYPES=standard
> Fri Feb 11 00:10:53 CST 2011
> *** starting standard tests in liberty ***
> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE
#1: Fri Jul 25 17:21:46 CDT 2008
sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
> *** finished standard tests for liberty ***
> Total time = 0m 11s
> *** finished tests in liberty ***
> ****SYSTEM ERROR liberty: Abnormal exit from runtest ****
> 	****SYSTEM ERROR liberty: runtest command failed ****
> opa-nightly-tests mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
