[opa-nightly-tests] honest4 OPA_Daily_Tests_0211Fri_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Fri Feb 11 02:16:49 CST 2011
*** OPA Tests on 0211Fri ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 0m 17s
honest4: Ran 1(0/0/0) hosts, Grand total test time = 1m 14s
Timekeeper log
Timekeeper started at Fri Feb 11 02:15:46 CST 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0211Fri_0216
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/u/ac/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /u/ac/hdftest/snapshots-opa/current/src/opa_primitives.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/u/ac/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /u/ac/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/u/ac/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /u/ac/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/u/ac/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /u/ac/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /u/ac/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/u/ac/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: error: #error no primitives implementation specified
In file included from /u/ac/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: expected specifier-qualifier-list before 'OPA_ptr_t'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h: In function 'OPA_Shm_rel_to_abs':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: 'size_t' undeclared (first use in this function)
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: expected ')' before 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h: In function 'OPA_Shm_abs_to_rel':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: 'size_t' undeclared (first use in this function)
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: expected ')' before 'a'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h: In function 'OPA_Shm_swap_rel':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h: In function 'OPA_Shm_cas_rel_null':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h: In function 'OPA_Queue_is_empty':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h: In function 'OPA_Queue_peek_head':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: 'NULL' undeclared (first use in this function)
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.c: In function 'OPA_Queue_init':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.c: In function 'OPA_Queue_header_init':
/u/ac/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: 'OPA_Shm_rel_addr_t' has no member named 'offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=2: Fri Feb 11 02:16:18 CST 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
02:15:24 up 17 days, 14:41, 35 users, load average: 0.61, 1.13, 0.74
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem1:/var/lib/perceus/
138916864 117893216 13967056 90% /var/lib/perceus
10.1.69.1:/usr/src 138916864 117893216 13967072 90% /usr/src
/dev/sda2 63013156 544000 61836356 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 740881224 2472201264 24% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
92298352896 81773394468 9118398184 90% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 27035567652 25754204180 52% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 143779252 3092229744 5% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
276891315456 210788934748 56249038404 79% /cfs/scratch
abem5:/var/spool/torque/server_logs
961428816 38283856 874307120 5% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 62322736 7455056 90% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 59641704 7331256 90% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
363327960768 314570520764 46496097476 88% /WAN/IU
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/REPO_LOG_0211Fri
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0211Fri.23049: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0211Fri.23049': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
02:15:51 up 17 days, 14:41, 33 users, load average: 0.96, 0.90, 0.92
abem2:/var/lib/perceus/
74763440 40295088 30670544 57% /var/lib/perceus
10.1.69.1:/usr/src 138916864 117893568 13966720 90% /usr/src
/dev/sda2 63013156 2833592 59546764 5% /tmp
92298352896 81773441572 9118352104 90% /cfs/projects
55567516032 27035567004 25754195712 52% /u
3385032528 143779548 3092229552 5% /usr/local
276891315456 210789005588 56250002796 79% /cfs/scratch
961428816 38283920 874307072 5% /var/spool/torque/server_logs
73575600 62322752 7455040 90% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 59641880 7331080 90% /var/forward
363327960768 314570519740 46496098564 88% /WAN/IU
TEST_TYPES=standard
Fri Feb 11 02:16:02 CST 2011
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #8 SMP Thu Sep 16 17:22:55 CDT 2010 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
*** finished standard tests for honest1 ***
Total time = 0m 16s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
Fri Feb 11 02:16:48 CST 2011
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests
