[opa-nightly-tests] jam OPA_Daily_Tests_0321Sun_FAILED!!!
Larry Knox
lrknox at hdfgroup.org
Mon Mar 22 07:51:46 CDT 2010
A drive was full on colonelk. This has been corrected; today's test
passed.
Larry
-----Original Message-----
From: opa-nightly-tests-bounces at lists.mcs.anl.gov
[mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
Sent: Sunday, March 21, 2010 12:19 AM
To: opa-nightly-tests at lists.mcs.anl.gov
Subject: [opa-nightly-tests] jam OPA_Daily_Tests_0321Sun_FAILED!!!
*** OPA Tests on 0321Sun ***
Tests Summary
****FAILED colonelk: standard****
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED linew: standard
Tests Time Summary
colonelk: Ran 1(0/1/0) tests, Grand total test time = 0m 3s
jam: Ran 1(1/0/0) tests, Grand total test time = 0m 51s
liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
duty: Ran 1(1/0/0) tests, Grand total test time = 2m 8s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 48s
jam: Ran 5(0/0/0) hosts, Grand total test time = 8m 43s
Timekeeper log
Timekeeper started at Sun Mar 21 00:10:34 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of colonelk: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0321Sun_0010
/home/hdftest/snapshots-opa/current/configure: line 2754: printf: write
error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2792: printf: write
/home/hdftest/snapshots-opa/current/configure: line 2795: printf: write
/home/hdftest/snapshots-opa/current/configure: line 2798: printf: write
configure: error: in `/home/hdftest/snapshots-opa/TestDir/colonelk':
/home/hdftest/snapshots-opa/current/configure: line 2801: printf: write
configure: error: C compiler cannot create executables
See `config.log' for more details.
/home/hdftest/snapshots-opa/current/configure: line 2807: echo: write error:
cat: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2814: echo: write error:
sort: fflush failed: standard output: No space left on device
sort: write error
/home/hdftest/snapshots-opa/current/configure: line 2845: echo: write error:
/home/hdftest/snapshots-opa/current/configure: line 2852: echo: write error:
sort: write error
/home/hdftest/snapshots-opa/current/configure: line 2861: echo: write error:
/home/hdftest/snapshots-opa/current/configure: line 2893: printf: write
gmake: *** [config.status] Error 77
CURRENT is /home/hdftest/snapshots-opa/current
TESTDIR is /home/hdftest/snapshots-opa/TestDir/colonelk
snapshot is yes
===== configure: Sun Mar 21 00:10:57 CDT 2010 =====
bin/snapshot: line 558: echo: write error: No space left on device
Failed running
===== Exit bin/snapshot with status=1: Sun Mar 21 00:10:57 CDT 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:10:17 up 38 days, 14:45, 17 users, load average: 1.60, 1.41, 0.85
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4113516 25986676 14% /
/dev/sda1 101086 39130 56737 41% /boot
/dev/sda2 31738420 329828 29770364 2% /tmp
/dev/sda6 31738392 4204916 25895252 14% /var
/dev/sda7 31738392 22239912 7860256 74% /usr
/dev/sda8 124991068 6829260 111710108 6% /var/tmp
/dev/mapper/VolGroup00-home
198351840 7313796 180799684 4% /home
/dev/sde1 565688764 55320120 481169708 11% /scr
/dev/sdc1 961432072 588917928 323676144 65% /mnt/scr1
/dev/sdd1 961432072 348674528 563919544 39% /mnt/hdf
tmpfs 8313860 0 8313860 0% /dev/shm
gumund:/data/ftp 480719072 269544672 186755200 60% /mnt/ftp
gumund:/data/web 480719072 269544672 186755200 60% /mnt/web
pegdub:/mnt/rw-src 288451232 92378624 181420128 34% /mnt/ro-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0321Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0321Sun.26356: No such
file or directory
rm: cannot remove
`/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0321Sun.26356': No such file
or directory
*** launching tests from jam ***
TESTHOST is linew
jam
colonelk
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd
/home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest
-nodiff -nocvs -configname linew
Using configname option for -configname
opa
12:10am up 4 day(s), 13:08, 3 users, load average: 1.11, 0.97, 0.55
/ (/dev/dsk/c1t0d0s0 ):81078112 blocks 8287765 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483610 files
/proc (proc ): 0 blocks 29920 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):19794224 blocks 1180490 files
/system/object (objfs ): 0 blocks 2147483484 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_
psr_hwcap1.so.1):81078112 blocks 8287765 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv
9/libc_psr/libc_psr_hwcap1.so.1):81078112 blocks 8287765 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):19794224 blocks 1180490 files
/var/run (swap ):19794224 blocks 1180490 files
/scr (/dev/dsk/c1t1d0s0 ):266113684 blocks 18243874 files
/home (jam:/home ):382076088 blocks 51061598 files
/mnt/hdf (jam:/mnt/hdf ):1225515088 blocks 116380429 files
/mnt/scr1 (jam:/mnt/scr1 ):745028240 blocks 119526269 files
/mnt/web (gumund:/mnt/web ):422348792 blocks 60563481 files
/mnt/ftp (gumund:/mnt/ftp ):422348792 blocks 60563481 files
TEST_TYPES=standard
Running standard
Sun Mar 21 00:11:03 CDT 2010
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_142900-06 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0321Sun_0011
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib
/usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Sun Mar 21 00:18:38 CDT 2010
Total time = 7m 36s
*** finished tests in linew ***
Testing jam
ssh jam -n cd
-nodiff -nocvs -configname jam
opa
00:10:41 up 38 days, 14:45, 17 users, load average: 1.54, 1.41, 0.86
/dev/sda2 31738420 329872 29770320 2% /tmp
/dev/sda6 31738392 4204920 25895248 14% /var
/dev/sdc1 961432072 588917960 323676112 65% /mnt/scr1
TEST_TYPES=standard
Running standard
Sun Mar 21 00:10:51 CDT 2010
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-164.11.1.el5PAE #1 SMP Wed Jan 20 08:16:13 EST
2010 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0321Sun_0010
/usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Sun Mar 21 00:11:42 CDT 2010
Total time = 0m 51s
*** finished tests in jam ***
Testing colonelk
ssh colonelk -n cd
-nodiff -nocvs -configname colonelk
opa
00:10:44 up 50 days, 7:25, 3 users, load average: 0.00, 0.00, 0.00
/dev/hda3 29753588 3351968 24865808 12% /
/dev/hda2 49961020 1947784 45434404 5% /tmp
/dev/hda6 9920592 1544036 7864488 17% /var
/dev/hda5 19840892 18816920 0 100% /scr
/dev/hda1 101086 33698 62169 36% /boot
tmpfs 517588 0 517588 0% /dev/shm
jam:/mnt/hdf 961432096 348674528 563919552 39% /mnt/hdf
jam:/mnt/scr1 961432096 588917984 323676128 65% /mnt/scr1
jam:/home 198351840 7313792 180799712 4% /home
TEST_TYPES=standard
Running standard
Sun Mar 21 00:10:54 CDT 2010
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-164.11.1.el5 #1 SMP Wed Jan 20 07:39:04 EST
SRCDIRNAME is colonelk
/usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Total time = 0m 3s
*** finished tests in colonelk ***
****SYSTEM ERROR colonelk: Abnormal exit from runtest ****
Sun Mar 21 00:19:09 CDT 2010
****SYSTEM ERROR colonelk: runtest command failed ****
Testing duty
ssh duty -n cd
-nodiff -nocvs -configname duty
opa
12:10AM up 45 days, 14:09, 2 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60994 406026 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 121440504 51917872 70% /data
/dev/aacd0s1g 32494668 23017820 6877276 77% /local_home
/dev/aacd0s1f 12186190 3383466 7827830 30% /usr
/dev/aacd0s1d 507630 47688 419332 10% /var
/dev/aacd0s1e 253678 180 233204 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 7313796 180799684 4% /home
jam:/mnt/hdf 961432072 348674528 563919544 38% /mnt/hdf
jam:/mnt/scr1 961432072 588917976 323676096 65% /mnt/scr1
gumund:/data/web 480719056 269544660 186755196 59% /mnt/web
gumund:/data/ftp 480719056 269544660 186755196 59% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 20020 96546 17% /tmp
TEST_TYPES=standard
Running standard
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1:
Fri Jul 25 17:10:59 CDT 2008
sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
SRCDIRNAME is duty
/mnt/scr1/SnapTest/snapshots-opa/log/duty_0321Sun_0010
/usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Sun Mar 21 00:13:05 CDT 2010
Total time = 2m 8s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd
-nodiff -nocvs -configname liberty
opa
12:10AM up 45 days, 14:07, 3 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86920 380100 19% /
/dev/aacd0s1g 47047830 28516594 14767410 66% /local_home
/dev/aacd0s1f 12186190 6403790 4807506 57% /usr
/dev/aacd0s1d 1012974 101592 830346 11% /var
/dev/aacd0s1e 507630 62724 404296 13% /var/tmp
jam:/mnt/scr1 961432072 588917980 323676092 65% /mnt/scr1
/dev/md0 126702 23844 92722 20% /tmp
TEST_TYPES=standard
Running standard
Sun Mar 21 00:11:00 CDT 2010
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE
#1: Fri Jul 25 17:21:46 CDT 2008
sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
SRCDIRNAME is liberty
/mnt/scr1/SnapTest/snapshots-opa/log/liberty_0321Sun_0011
/usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Sun Mar 21 00:11:55 CDT 2010
Total time = 0m 55s
*** finished tests in liberty ***
Sun Mar 21 00:19:10 CDT 2010
opa-nightly-tests mailing list
https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
