[opa-nightly-tests] jam OPA_Daily_Tests_0321Sun_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Sun Mar 21 00:19:10 CDT 2010
*** OPA Tests on 0321Sun ***
   Tests Summary
****FAILED colonelk: standard****
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED linew: standard
   Tests Time Summary
colonelk: Ran 1(0/1/0) tests, Grand total test time =  0m 3s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 51s
liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 56s
duty: Ran 1(1/0/0) tests, Grand total test time =  2m 8s
linew: Ran 1(1/0/0) tests, Grand total test time =  7m 48s
jam: Ran 5(0/0/0) hosts, Grand total test time =  8m 43s
   Timekeeper log
Timekeeper started at Sun Mar 21 00:10:34 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of colonelk: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0321Sun_0010
/home/hdftest/snapshots-opa/current/configure: line 2754: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2792: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2795: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2798: printf: write error: No space left on device
configure: error: in `/home/hdftest/snapshots-opa/TestDir/colonelk':
/home/hdftest/snapshots-opa/current/configure: line 2801: printf: write error: No space left on device
configure: error: C compiler cannot create executables
See `config.log' for more details.
/home/hdftest/snapshots-opa/current/configure: line 2807: echo: write error: No space left on device
cat: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2814: echo: write error: No space left on device
sort: fflush failed: standard output: No space left on device
sort: write error
/home/hdftest/snapshots-opa/current/configure: line 2845: echo: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2852: echo: write error: No space left on device
sort: write error
/home/hdftest/snapshots-opa/current/configure: line 2861: echo: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2893: printf: write error: No space left on device
gmake: *** [config.status] Error 77
CURRENT is /home/hdftest/snapshots-opa/current
TESTDIR is /home/hdftest/snapshots-opa/TestDir/colonelk
snapshot is yes
===== configure: Sun Mar 21 00:10:57 CDT 2010 =====
bin/snapshot: line 558: echo: write error: No space left on device
Failed running
===== Exit bin/snapshot with status=1: Sun Mar 21 00:10:57 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:10:17 up 38 days, 14:45, 17 users,  load average: 1.60, 1.41, 0.85
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   4113516  25986676  14% /
/dev/sda1               101086     39130     56737  41% /boot
/dev/sda2             31738420    329828  29770364   2% /tmp
/dev/sda6             31738392   4204916  25895252  14% /var
/dev/sda7             31738392  22239912   7860256  74% /usr
/dev/sda8            124991068   6829260 111710108   6% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840   7313796 180799684   4% /home
/dev/sde1            565688764  55320120 481169708  11% /scr
/dev/sdc1            961432072 588917928 323676144  65% /mnt/scr1
/dev/sdd1            961432072 348674528 563919544  39% /mnt/hdf
tmpfs                  8313860         0   8313860   0% /dev/shm
gumund:/data/ftp     480719072 269544672 186755200  60% /mnt/ftp
gumund:/data/web     480719072 269544672 186755200  60% /mnt/web
pegdub:/mnt/rw-src   288451232  92378624 181420128  34% /mnt/ro-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0321Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0321Sun.26356: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0321Sun.26356': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
colonelk
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
 12:10am  up 4 day(s), 13:08,  3 users,  load average: 1.11, 0.97, 0.55
/                  (/dev/dsk/c1t0d0s0 ):81078112 blocks  8287765 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483610 files
/proc              (proc              ):       0 blocks    29920 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):19794224 blocks  1180490 files
/system/object     (objfs             ):       0 blocks 2147483484 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):81078112 blocks  8287765 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):81078112 blocks  8287765 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):19794224 blocks  1180490 files
/var/run           (swap              ):19794224 blocks  1180490 files
/scr               (/dev/dsk/c1t1d0s0 ):266113684 blocks 18243874 files
/home              (jam:/home         ):382076088 blocks 51061598 files
/mnt/hdf           (jam:/mnt/hdf      ):1225515088 blocks 116380429 files
/mnt/scr1          (jam:/mnt/scr1     ):745028240 blocks 119526269 files
/mnt/web           (gumund:/mnt/web   ):422348792 blocks 60563481 files
/mnt/ftp           (gumund:/mnt/ftp   ):422348792 blocks 60563481 files
TEST_TYPES=standard
Running standard
Sun Mar 21 00:11:03 CDT 2010
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_142900-06 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0321Sun_0011
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Sun Mar 21 00:18:38 CDT 2010
Total time = 7m 36s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
 00:10:41 up 38 days, 14:45, 17 users,  load average: 1.54, 1.41, 0.86
/dev/sda2             31738420    329872  29770320   2% /tmp
/dev/sda6             31738392   4204920  25895248  14% /var
/dev/sdc1            961432072 588917960 323676112  65% /mnt/scr1
TEST_TYPES=standard
Running standard
Sun Mar 21 00:10:51 CDT 2010
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-164.11.1.el5PAE #1 SMP Wed Jan 20 08:16:13 EST 2010 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0321Sun_0010
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Sun Mar 21 00:11:42 CDT 2010
Total time = 0m 51s
*** finished tests in jam ***
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
 00:10:44 up 50 days,  7:25,  3 users,  load average: 0.00, 0.00, 0.00
/dev/hda3             29753588   3351968  24865808  12% /
/dev/hda2             49961020   1947784  45434404   5% /tmp
/dev/hda6              9920592   1544036   7864488  17% /var
/dev/hda5             19840892  18816920         0 100% /scr
/dev/hda1               101086     33698     62169  36% /boot
tmpfs                   517588         0    517588   0% /dev/shm
jam:/mnt/hdf         961432096 348674528 563919552  39% /mnt/hdf
jam:/mnt/scr1        961432096 588917984 323676128  65% /mnt/scr1
jam:/home            198351840   7313792 180799712   4% /home
TEST_TYPES=standard
Running standard
Sun Mar 21 00:10:54 CDT 2010
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-164.11.1.el5 #1 SMP Wed Jan 20 07:39:04 EST 2010 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Total time = 0m 3s
*** finished tests in colonelk ***
****SYSTEM ERROR colonelk: Abnormal exit from runtest ****
	Sun Mar 21 00:19:09 CDT 2010
	****SYSTEM ERROR colonelk: runtest command failed ****
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
12:10AM  up 45 days, 14:09, 2 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60994    406026    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 121440504  51917872    70%    /data
/dev/aacd0s1g     32494668  23017820   6877276    77%    /local_home
/dev/aacd0s1f     12186190   3383466   7827830    30%    /usr
/dev/aacd0s1d       507630     47688    419332    10%    /var
/dev/aacd0s1e       253678       180    233204     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840   7313796 180799684     4%    /home
jam:/mnt/hdf     961432072 348674528 563919544    38%    /mnt/hdf
jam:/mnt/scr1    961432072 588917976 323676096    65%    /mnt/scr1
gumund:/data/web 480719056 269544660 186755196    59%    /mnt/web
gumund:/data/ftp 480719056 269544660 186755196    59%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702     20020     96546    17%    /tmp
TEST_TYPES=standard
Running standard
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
SRCDIRNAME is duty
   /mnt/scr1/SnapTest/snapshots-opa/log/duty_0321Sun_0010
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Sun Mar 21 00:13:05 CDT 2010
Total time = 2m 8s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
12:10AM  up 45 days, 14:07, 3 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86920    380100    19%    /
/dev/aacd0s1g     47047830  28516594  14767410    66%    /local_home
/dev/aacd0s1f     12186190   6403790   4807506    57%    /usr
/dev/aacd0s1d      1012974    101592    830346    11%    /var
/dev/aacd0s1e       507630     62724    404296    13%    /var/tmp
jam:/mnt/scr1    961432072 588917980 323676092    65%    /mnt/scr1
/dev/md0            126702     23844     92722    20%    /tmp
TEST_TYPES=standard
Running standard
Sun Mar 21 00:11:00 CDT 2010
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
SRCDIRNAME is liberty
   /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0321Sun_0011
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Sun Mar 21 00:11:55 CDT 2010
Total time = 0m 55s
*** finished tests in liberty ***
More information about the opa-nightly-tests mailing list
