[opa-nightly-tests] honest4 OPA_Daily_Tests_0310Wed_FAILED!!!
Larry Knox lrknox at hdfgroup.org
Wed Mar 10 14:02:55 CST 2010
I ran this again on honest2 and all tests passed.  I don't know what the
problem was.
Larry
-----Original Message-----
From: opa-nightly-tests-bounces at lists.mcs.anl.gov
[mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDFTEST
Community User
Sent: Wednesday, March 10, 2010 12:47 AM
To: opa-nightly-tests at lists.mcs.anl.gov
Subject: [opa-nightly-tests] honest4 OPA_Daily_Tests_0310Wed_FAILED!!!
*** OPA Tests on 0310Wed ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 48s
honest4: Ran 1(0/0/0) hosts, Grand total test time =  2m 26s
   Timekeeper log
Timekeeper started at Wed Mar 10 00:45:16 CST 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0310Wed_0045
Testing memory barrier sanity
PASSED
Testing memory barriers with linear array with 2 threads
PASSED
Testing memory barriers with local variables with 2 threads
PASSED
Testing memory barriers with scattered array with 2 threads
PASSED
Testing memory barriers with linear array with 4 threads
PASSED
Testing memory barriers with local variables with 4 threads
PASSED
Testing memory barriers with scattered array with 4 threads
PASSED
Testing memory barriers with linear array with 10 threads
PASSED
Testing memory barriers with local variables with 10 threads
PASSED
Testing memory barriers with scattered array with 10 threads
PASSED
Testing memory barriers with linear array with 100 threads
*FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in
test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads
*FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in
test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads
*FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in
test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory
`/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Wed Mar 10 00:46:24 CST 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:44:19 up 6 days, 14:02, 32 users,  load average: 3.32, 4.10, 4.95
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem1:/var/lib/perceus/
                     138916864 108311968  23548320  83% /var/lib/perceus
10.1.69.1:/usr/src   138916864 108311968  23548320  83% /usr/src
/dev/sda2             63013156    606696  61773660   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 568432988 2644649428  18% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     80761058784 53071352428 26868958308  67% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 17011193732 35779222284  33% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 101458608 3134550484   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     242279901024 94842336064 139337288176  41% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 144070144 768520848  16%
abem5:/var/spool/torque/server_priv/accounting
                      73575600  57893360  11884432  83%
pop:/var/forward      70557056  53740808  13232152  81% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_0310Wed
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0310Wed.16748: No such file or
directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0310Wed.16748':
No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd
/u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff
-nocvs -configname honest1
Using configname option for -configname
opa
 00:45:26 up 44 days,  4:00, 48 users,  load average: 2.87, 3.08, 3.09
abem2:/var/lib/perceus/
                      74763440  58942784  12022848  84% /var/lib/perceus
/dev/sda2             63013156    811312  61569044   2% /tmp
                     80761058784 53074491512 26865758856  67% /cfs/projects
                     55567516032 17011222256 35779266136  33% /u
                     3385032528 101458328 3134550648   4% /usr/local
                     242279901024 94847699736 139328465376  41% /cfs/scratch
                     961428816 144070480 768520496  16%
                      73575600  57894368  11883424  83%
pop:/var/forward      70557056  53740880  13232080  81% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
                     363327960768 257800289068 103265911668  72% /WAN/IU
TEST_TYPES=standard
Running standard
Wed Mar 10 00:45:37 CST 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu
2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST
2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 0m 47s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	Wed Mar 10 00:46:55 CST 2010
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
opa-nightly-tests mailing list
https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
