[opa-nightly-tests] honest4 OPA_Daily_Tests_0310Wed_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Wed Mar 10 00:46:55 CST 2010
*** OPA Tests on 0310Wed ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 0m 48s
honest4: Ran 1(0/0/0) hosts, Grand total test time = 2m 26s
Timekeeper log
Timekeeper started at Wed Mar 10 00:45:16 CST 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0310Wed_0045
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Wed Mar 10 00:46:24 CST 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:44:19 up 6 days, 14:02, 32 users, load average: 3.32, 4.10, 4.95
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem1:/var/lib/perceus/
138916864 108311968 23548320 83% /var/lib/perceus
10.1.69.1:/usr/src 138916864 108311968 23548320 83% /usr/src
/dev/sda2 63013156 606696 61773660 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 568432988 2644649428 18% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
80761058784 53071352428 26868958308 67% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 17011193732 35779222284 33% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 101458608 3134550484 4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
242279901024 94842336064 139337288176 41% /cfs/scratch
abem5:/var/spool/torque/server_logs
961428816 144070144 768520848 16% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 57893360 11884432 83% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 53740808 13232152 81% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/CVS_LOG_0310Wed
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0310Wed.16748: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0310Wed.16748': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
00:45:26 up 44 days, 4:00, 48 users, load average: 2.87, 3.08, 3.09
abem2:/var/lib/perceus/
74763440 58942784 12022848 84% /var/lib/perceus
/dev/sda2 63013156 811312 61569044 2% /tmp
80761058784 53074491512 26865758856 67% /cfs/projects
55567516032 17011222256 35779266136 33% /u
3385032528 101458328 3134550648 4% /usr/local
242279901024 94847699736 139328465376 41% /cfs/scratch
961428816 144070480 768520496 16% /var/spool/torque/server_logs
73575600 57894368 11883424 83% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 53740880 13232080 81% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
363327960768 257800289068 103265911668 72% /WAN/IU
TEST_TYPES=standard
Running standard
Wed Mar 10 00:45:37 CST 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 0m 47s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests
