[opa-nightly-tests] honest1 OPA_Daily_Tests_0514Thu_FAILED!!!
Dave Goodell goodell at mcs.anl.gov
Thu May 14 10:34:09 CDT 2009
Sounds good.  Thanks for fixing it.
-Dave
On May 14, 2009, at 10:26 AM, Neil Fortner wrote:
> Dave,
> We looked at this and decided it was probably due to parallel make
> running 2 tests at once.  honest1 does not allow 200 threads so this
> makes sense.  Larry has changed the test configuration to force
> serial make.
> Thanks,
> -Neil
> Dave Goodell wrote:
>> Is something wrong with our "can we run 100 threads" configure test?
>> -Dave
>> On May 14, 2009, at 9:31 AM, HDFTEST Community User wrote:
>>> *** OPA Tests on 0514Thu ***
>>>  Tests Summary
>>> ****FAILED abe: runtest command failed ****
>>> ****FAILED honest1: standard****
>>>  Tests Time Summary
>>> honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 30s
>>> honest1: Ran 1(0/0/0) hosts, Grand total test time =  1m 19s
>>>  Timekeeper log
>>> Timekeeper started at Thu May 14 09:30:33 CDT 2009
>>> Timekeeper sleeping for 18000 seconds
>>>  Tests Failures
>>> Dumping logfile of honest1: standard
>>> Last 30 lines of /u/ac/hdftest/snapshots-opa/log/
>>> honest1_0514Thu_0930
>>>       at /u/ac/hdftest/snapshots-opa/current/test/
>>> test_primitives.c:1147 in test_threaded_faa()...
>>> Testing fetch and add return values with 100
>>> threads                  *FAILED*
>>> test_primitives.c:1283 in test_threaded_faa_ret()...
>>> Testing fetch and incr/decr with 99
>>> threads                           *FAILED*
>>> test_primitives.c:1443 in test_threaded_fai_fad()...
>>> ***** 8 PRIMITIVES TESTS FAILED! *****
>>> FAIL: test_primitives
>>> Testing memory barrier
>>> sanity                                          PASSED
>>> Testing memory barriers with linear array with 2
>>> threads               PASSED
>>> Testing memory barriers with local variables with 2
>>> threads            PASSED
>>> Testing memory barriers with scattered array with 2
>>> threads            PASSED
>>> Testing memory barriers with linear array with 10
>>> threads              PASSED
>>> Testing memory barriers with local variables with 10
>>> threads           PASSED
>>> Testing memory barriers with scattered array with 10
>>> threads           PASSED
>>> Testing memory barriers with linear array with 100
>>> threads            *FAILED*
>>>       at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:
>>> 304 in test_barriers_linear_array()...
>>> Testing memory barriers with local variables with 100
>>> threads         *FAILED*
>>> 558 in test_barriers_variables()...
>>> Testing memory barriers with scattered array with 100
>>> threads         *FAILED*
>>> 660 in test_barriers_scattered_array()...
>>> ***** 3 BARRIERS TESTS FAILED! *****
>>> FAIL: test_barriers
>>> 2 of 3 tests failed
>>> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
>>> make[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/
>>> honest1/test'
>>> make[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/
>>> honest1/test'
>>> ===== Exit bin/snapshot with status=2: Thu May 14 09:31:19 CDT
>>> 2009 =====
>>> Thu May 14 09:31:19 CDT 2009
>>> Dumping done
>>>  Watchers List
>>> _______________________________________________
>>> opa-nightly-tests mailing list
>>> opa-nightly-tests at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
