[opa-nightly-tests] honest1 OPA_Daily_Tests_0514Thu_FAILED!!!
Neil Fortner
nfortne2 at hdfgroup.org
Thu May 14 10:26:25 CDT 2009
Dave,
We looked at this and decided it was probably due to parallel make
running 2 tests at once. honest1 does not allow 200 threads so this
makes sense. Larry has changed the test configuration to force serial make.
-Neil
Dave Goodell wrote:
> Is something wrong with our "can we run 100 threads" configure test?
> -Dave
> On May 14, 2009, at 9:31 AM, HDFTEST Community User wrote:
>> *** OPA Tests on 0514Thu ***
>> Tests Summary
>> ****FAILED abe: runtest command failed ****
>> ****FAILED honest1: standard****
>> Tests Time Summary
>> honest1: Ran 1(0/1/0) tests, Grand total test time = 0m 30s
>> honest1: Ran 1(0/0/0) hosts, Grand total test time = 1m 19s
>> Timekeeper log
>> Timekeeper started at Thu May 14 09:30:33 CDT 2009
>> Timekeeper sleeping for 18000 seconds
>> Tests Failures
>> Dumping logfile of honest1: standard
>> Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0514Thu_0930
>> at
>> /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1147 in
>> test_threaded_faa()...
>> Testing fetch and add return values with 100 threads
>> *FAILED*
>> at
>> /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1283 in
>> test_threaded_faa_ret()...
>> Testing fetch and incr/decr with 99 threads
>> *FAILED*
>> at
>> /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1443 in
>> test_threaded_fai_fad()...
>> ***** 8 PRIMITIVES TESTS FAILED! *****
>> FAIL: test_primitives
>> Testing memory barrier
>> sanity PASSED
>> Testing memory barriers with linear array with 2
>> threads PASSED
>> Testing memory barriers with local variables with 2
>> threads PASSED
>> Testing memory barriers with scattered array with 2
>> threads PASSED
>> Testing memory barriers with linear array with 10
>> threads PASSED
>> Testing memory barriers with local variables with 10
>> threads PASSED
>> Testing memory barriers with scattered array with 10
>> threads PASSED
>> Testing memory barriers with linear array with 100 threads
>> *FAILED*
>> at
>> /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in
>> test_barriers_linear_array()...
>> Testing memory barriers with local variables with 100 threads
>> *FAILED*
>> at
>> /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in
>> test_barriers_variables()...
>> Testing memory barriers with scattered array with 100 threads
>> *FAILED*
>> at
>> /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in
>> test_barriers_scattered_array()...
>> ***** 3 BARRIERS TESTS FAILED! *****
>> FAIL: test_barriers
>> 2 of 3 tests failed
>> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
>> make[2]: Leaving directory
>> `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
>> make[1]: Leaving directory
>> ===== Exit bin/snapshot with status=2: Thu May 14 09:31:19 CDT 2009
>> Dumping done
>> Watchers List
>> opa-nightly-tests mailing list
>> opa-nightly-tests at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
