[opa-nightly-tests] honest1 OPA_Daily_Tests_0514Thu_FAILED!!!
Dave Goodell goodell at mcs.anl.gov
Thu May 14 10:18:14 CDT 2009
Is something wrong with our "can we run 100 threads" configure test?
-Dave
On May 14, 2009, at 9:31 AM, HDFTEST Community User wrote:
> *** OPA Tests on 0514Thu ***
>   Tests Summary
> ****FAILED abe: runtest command failed ****
> ****FAILED honest1: standard****
>   Tests Time Summary
> honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 30s
> honest1: Ran 1(0/0/0) hosts, Grand total test time =  1m 19s
>   Timekeeper log
> Timekeeper started at Thu May 14 09:30:33 CDT 2009
> Timekeeper sleeping for 18000 seconds
>   Tests Failures
> Dumping logfile of honest1: standard
> Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0514Thu_0930
>        at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:
> 1147 in test_threaded_faa()...
> Testing fetch and add return values with 100
> threads                  *FAILED*
> 1283 in test_threaded_faa_ret()...
> Testing fetch and incr/decr with 99
> threads                           *FAILED*
> 1443 in test_threaded_fai_fad()...
> ***** 8 PRIMITIVES TESTS FAILED! *****
> FAIL: test_primitives
> Testing memory barrier
> sanity                                          PASSED
> Testing memory barriers with linear array with 2
> threads               PASSED
> Testing memory barriers with local variables with 2
> threads            PASSED
> Testing memory barriers with scattered array with 2
> threads            PASSED
> Testing memory barriers with linear array with 10
> threads              PASSED
> Testing memory barriers with local variables with 10
> threads           PASSED
> Testing memory barriers with scattered array with 10
> threads           PASSED
> Testing memory barriers with linear array with 100
> threads            *FAILED*
>        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:
> 304 in test_barriers_linear_array()...
> Testing memory barriers with local variables with 100
> threads         *FAILED*
> 558 in test_barriers_variables()...
> Testing memory barriers with scattered array with 100
> threads         *FAILED*
> 660 in test_barriers_scattered_array()...
> ***** 3 BARRIERS TESTS FAILED! *****
> FAIL: test_barriers
> 2 of 3 tests failed
> Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
> make[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/
> honest1/test'
> make[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/
> honest1/test'
> ===== Exit bin/snapshot with status=2: Thu May 14 09:31:19 CDT 2009
> Dumping done
>   Watchers List
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
