[opa-nightly-tests] honest1 OPA_Daily_Tests_0514Thu_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Thu May 14 09:31:49 CDT 2009
*** OPA Tests on 0514Thu ***
   Tests Summary
****FAILED abe: runtest command failed ****
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 30s
honest1: Ran 1(0/0/0) hosts, Grand total test time =  1m 19s
   Timekeeper log
Timekeeper started at Thu May 14 09:30:33 CDT 2009
Timekeeper sleeping for 18000 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0514Thu_0930
        at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1147 in test_threaded_faa()...
Testing fetch and add return values with 100 threads                  *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1283 in test_threaded_faa_ret()...
Testing fetch and incr/decr with 99 threads                           *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1443 in test_threaded_fai_fad()...
***** 8 PRIMITIVES TESTS FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
make[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
make[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
===== Exit bin/snapshot with status=2: Thu May 14 09:31:19 CDT 2009 =====
Dumping done
   Watchers List
More information about the opa-nightly-tests mailing list
