[opa-nightly-tests] honest4 OPA_Daily_Tests_1201Tue_FAILED!!!
Neil Fortner nfortne2 at hdfgroup.org
Tue Dec 1 13:43:59 CST 2009
On second glance it looks like autoconf wasn't run.  I'll talk to Larry
about it.
-Neil
On 12/01/2009 01:35 PM, Neil Fortner wrote:
> Hi all,
>  I assume this failure is related to one of the check-ins yesterday.
> honest4 appears to be an x86-64 machine running linux:
> [nfortner at honest4 honest4]$ uname -a
> Linux honest4.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr
> #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
> [nfortner at honest4 honest4]$ gcc --version
> gcc (GCC) 3.4.6 20060404 (Red Hat 3.4.6-3)
> Here are the relevant lines from config.log:
> configure:5567: checking for support for gcc x86/x86_64 bit primitives
> configure:5630: gcc -o conftest -g -O2
> -I/u/ac/hdftest/snapshots-opa/current/src   conftest.c -lpthread >&5
> In file included from
> /u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64.h:10,
>                  from conftest.c:42:
> /u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:32:
> error: syntax error before "OPA_int_t"
> In function `OPA_load_int':
> /u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:34:
> error: `ptr' undeclared (first use in this function)
> error: (Each undeclared identifier is reported only once
> error: for each function it appears in.)
> At top level:
> /u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:44:
> error: syntax error before "OPA_ptr_t"
> In function `OPA_load_ptr':
> /u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:46:
> configure:5637: $? = 1
> Let me know if you have any other questions.
> Thanks,
> -Neil
> On 12/01/2009 01:00 AM, HDFTEST Community User wrote:
>> *** OPA Tests on 1201Tue ***
>>     Tests Summary
>> ****FAILED abe: runtest command failed ****
>> ****FAILED honest4: standard****
>>     Tests Time Summary
>> honest4: Ran 1(0/1/0) tests, Grand total test time =  0m 12s
>> honest4: Ran 1(0/0/0) hosts, Grand total test time =  1m 1s
>>     Timekeeper log
>> Timekeeper started at Tue Dec  1 01:00:00 CST 2009
>> Timekeeper sleeping for 18000 seconds
>>     Tests Failures
>> Dumping logfile of honest4: standard
>> Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest4_1201Tue_0100
>> checking for intrin.h... no
>> checking for inttypes.h... (cached) yes
>> checking for stdint.h... (cached) yes
>> checking for C/C++ restrict keyword... __restrict
>> checking for inline... inline
>> checking for pthread_create in -lpthread... yes
>> checking if 100 threads can be run at once... no
>> checking size of void *... 8
>> checking size of int... 4
>> checking whether __attribute__ allowed... yes
>> checking whether __attribute__((format)) allowed... yes
>> checking if compiler rejects bogus asm statements... yes
>> checking for support for gcc x86/x86_64 bit primitives... no
>> checking for support for gcc ia64 primitives... no
>> checking for support for gcc PowerPC atomics... no
>> checking for support for gcc SiCortex atomics... no
>> checking for support for gcc atomic intrinsics... no
>> checking for support for Windows NT atomic intrinsics... no
>> checking for support for Sun atomic operations library... no
>> configure: error:
>> No native supported atomic primitives were detected.
>> You can use "--with-atomic-primitives=no" to emulate
>> the atomic primitives using locks, but note that doing
>> this will result in a substantial performance
>> penalty.
>> Failed running configure
>> ===== Exit bin/snapshot with status=1: Tue Dec  1 01:00:27 CST 2009
>> Dumping done
>>     Watchers List
>> opa-nightly-tests mailing list
>> opa-nightly-tests at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
