[opa-nightly-tests] honest4 OPA_Daily_Tests_1201Tue_FAILED!!!
Neil Fortner nfortne2 at hdfgroup.org
Tue Dec 1 13:35:08 CST 2009
Hi all,
  I assume this failure is related to one of the check-ins yesterday.
honest4 appears to be an x86-64 machine running linux:
[nfortner at honest4 honest4]$ uname -a
Linux honest4.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr
#7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
[nfortner at honest4 honest4]$ gcc --version
gcc (GCC) 3.4.6 20060404 (Red Hat 3.4.6-3)
Here are the relevant lines from config.log:
configure:5567: checking for support for gcc x86/x86_64 bit primitives
configure:5630: gcc -o conftest -g -O2
-I/u/ac/hdftest/snapshots-opa/current/src   conftest.c -lpthread >&5
In file included from
/u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64.h:10,
                  from conftest.c:42:
/u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:32:
error: syntax error before "OPA_int_t"
In function `OPA_load_int':
/u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:34:
error: `ptr' undeclared (first use in this function)
error: (Each undeclared identifier is reported only once
error: for each function it appears in.)
At top level:
/u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:44:
error: syntax error before "OPA_ptr_t"
In function `OPA_load_ptr':
/u/ac/hdftest/snapshots-opa/current/src/primitives/opa_gcc_intel_32_64_ops.h:46:
configure:5637: $? = 1
Let me know if you have any other questions.
-Neil
On 12/01/2009 01:00 AM, HDFTEST Community User wrote:
> *** OPA Tests on 1201Tue ***
>     Tests Summary
> ****FAILED abe: runtest command failed ****
> ****FAILED honest4: standard****
>     Tests Time Summary
> honest4: Ran 1(0/1/0) tests, Grand total test time =  0m 12s
> honest4: Ran 1(0/0/0) hosts, Grand total test time =  1m 1s
>     Timekeeper log
> Timekeeper started at Tue Dec  1 01:00:00 CST 2009
> Timekeeper sleeping for 18000 seconds
>     Tests Failures
> Dumping logfile of honest4: standard
> Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest4_1201Tue_0100
> checking for intrin.h... no
> checking for inttypes.h... (cached) yes
> checking for stdint.h... (cached) yes
> checking for C/C++ restrict keyword... __restrict
> checking for inline... inline
> checking for pthread_create in -lpthread... yes
> checking if 100 threads can be run at once... no
> checking size of void *... 8
> checking size of int... 4
> checking whether __attribute__ allowed... yes
> checking whether __attribute__((format)) allowed... yes
> checking if compiler rejects bogus asm statements... yes
> checking for support for gcc x86/x86_64 bit primitives... no
> checking for support for gcc ia64 primitives... no
> checking for support for gcc PowerPC atomics... no
> checking for support for gcc SiCortex atomics... no
> checking for support for gcc atomic intrinsics... no
> checking for support for Windows NT atomic intrinsics... no
> checking for support for Sun atomic operations library... no
> configure: error:
> No native supported atomic primitives were detected.
> You can use "--with-atomic-primitives=no" to emulate
> the atomic primitives using locks, but note that doing
> this will result in a substantial performance
> penalty.
> Failed running configure
> ===== Exit bin/snapshot with status=1: Tue Dec  1 01:00:27 CST 2009 =====
> Dumping done
>     Watchers List
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
