[opa-nightly-tests] jam OPA_Daily_Tests_0828Fri_FAILED!!!
Neil Fortner
nfortne2 at hdfgroup.org
Fri Aug 28 10:54:48 CDT 2009
It looks like the source isn't being updated for some reason on the test
machines. Larry is looking into it.
-Neil
On 08/28/2009 06:54 AM, HDF Tester wrote:
> *** OPA Tests on 0828Fri ***
> Tests Summary
> ****FAILED linew: runtest command failed ****
> ****FAILED linew: standard****
> PASSED colonelk: standard
> PASSED duty: standard
> PASSED jam: standard
> PASSED liberty: standard
> PASSED smirom: standard
> Tests Time Summary
> linew: Ran 1(0/1/0) tests, Grand total test time = 0m 20s
> jam: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
> liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 47s
> smirom: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
> colonelk: Ran 1(1/0/0) tests, Grand total test time = 1m 24s
> duty: Ran 1(1/0/0) tests, Grand total test time = 1m 49s
> jam: Ran 6(0/0/0) hosts, Grand total test time = 2m 45s
> Timekeeper log
> Timekeeper started at Fri Aug 28 06:51:40 CDT 2009
> Timekeeper sleeping for 1800 seconds
> Tests Failures
> Dumping logfile of linew: standard
> Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0828Fri_0651
> gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
> Making check in test
> gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
> gmake -j 2 sanity test_primitives test_barriers
> gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
> gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/snapshots-opa/current/test/sanity.c
> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o test_primitives.o /home/hdftest/snapshots-opa/current/test/test_primitives.c
> mv -f .deps/sanity.Tpo .deps/sanity.Po
> gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o test_barriers.o /home/hdftest/snapshots-opa/current/test/test_barriers.c
> mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
> gcc -g -O2 -o sanity sanity.o ../src/libopa.a -lpthread
> gcc -g -O2 -o test_barriers test_barriers.o ../src/libopa.a -lpthread
> mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
> gcc -g -O2 -o test_primitives test_primitives.o ../src/libopa.a -lpthread
> Undefined first referenced
> symbol in file
> pthread_yield test_primitives.o
> ld: fatal: Symbol referencing errors. No output written to test_primitives
> collect2: ld returned 1 exit status
> gmake[2]: *** [test_primitives] Error 1
> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
> gmake[1]: *** [check-am] Error 2
> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
> gmake: *** [check-recursive] Error 1
> Failed running make check
> ===== Exit bin/snapshot with status=0: Fri Aug 28 06:52:15 CDT 2009 =====
> Dumping done
> Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report it
> by 3pm.
> Watcher for OPA: Neil
> updated: 2009/05/05
> Tests Details
> Testing all hosts.
> opa
> 06:51:28 up 56 days, 22:15, 11 users, load average: 0.00, 0.00, 0.05
> Filesystem 1K-blocks Used Available Use% Mounted on
> /dev/sda3 31738420 3086116 27014076 11% /
> /dev/sda1 101086 50879 44988 54% /boot
> /dev/sda2 31738420 261304 29838888 1% /tmp
> /dev/sda6 31738392 3768668 26331500 13% /var
> /dev/sda7 31738392 14156260 15943908 48% /usr
> /dev/sda8 124991068 14243052 104296316 13% /var/tmp
> /dev/mapper/VolGroup00-home
> 198351840 11400652 176712828 7% /home
> /dev/sde1 565688764 24524568 511965260 5% /scr
> /dev/sdc1 961432072 373060868 539533204 41% /mnt/scr1
> /dev/sdd1 961432072 228321036 684273036 26% /mnt/hdf
> tmpfs 1551408 0 1551408 0% /dev/shm
> gumund:/data/ftp 480719072 179002752 277297120 40% /mnt/ftp
> gumund:/data/web 480719072 179002752 277297120 40% /mnt/web
> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
> TEST_TYPES=standard
> FTP flag is
> Running CVS checkout with output saved in
> /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0828Fri
> Checking MANIFEST file ...
> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0828Fri.25426: No such file or directory
> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0828Fri.25426': No such file or directory
> *** launching tests from jam ***
> TESTHOST is linew
> jam
> smirom
> colonelk
> duty
> liberty
> Fork off timekeeper 30
> Testing linew
> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
> Using configname option for -configname
> opa
> 6:51am up 8 day(s), 18:51, 7 users, load average: 0.53, 1.01, 1.10
> / (/dev/dsk/c1t0d0s0 ):55780418 blocks 8043928 files
> /devices (/devices ): 0 blocks 0 files
> /system/contract (ctfs ): 0 blocks 2147483607 files
> /proc (proc ): 0 blocks 29923 files
> /etc/mnttab (mnttab ): 0 blocks 0 files
> /etc/svc/volatile (swap ):16252992 blocks 1181939 files
> /system/object (objfs ): 0 blocks 2147483484 files
> /etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):55780418 blocks 8043928 files
> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):55780418 blocks 8043928 files
> /dev/fd (fd ): 0 blocks 0 files
> /tmp (swap ):16252992 blocks 1181939 files
> /var/run (swap ):16252992 blocks 1181939 files
> /home (jam:/home ):373902376 blocks 51013065 files
> /mnt/hdf (jam:/mnt/hdf ):1466222072 blocks 118056650 files
> /mnt/scr1 (jam:/mnt/scr1 ):1176742360 blocks 118420739 files
> /mnt/web (gumund:/mnt/web ):603432592 blocks 60658918 files
> /mnt/ftp (gumund:/mnt/ftp ):603432592 blocks 60658918 files
> TEST_TYPES=standard
> Running standard
> Fri Aug 28 06:51:55 CDT 2009
> *** starting standard tests in linew ***
> Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
> /mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
> SRCDIRNAME is linew
> Running snapshot with output saved in
> SNAPCMD is srcdir test clean
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
> *** finished standard tests for linew ***
> Total time = 0m 20s
> *** finished tests in linew ***
> ****FAILED linew: Abnormal exit from runtest ****
> Fri Aug 28 06:54:23 CDT 2009
> Testing jam
> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
> opa
> 06:51:47 up 56 days, 22:15, 11 users, load average: 0.00, 0.00, 0.05
> /dev/sda2 31738420 261308 29838884 1% /tmp
> /dev/sda6 31738392 3768664 26331504 13% /var
> /dev/sdc1 961432072 373060900 539533172 41% /mnt/scr1
> TEST_TYPES=standard
> Running standard
> Fri Aug 28 06:51:57 CDT 2009
> *** starting standard tests in jam ***
> Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28 EDT 2009 i686 i686 i386 GNU/Linux
> SRCDIRNAME is jam
> /mnt/scr1/SnapTest/snapshots-opa/log/jam_0828Fri_0651
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
> *** finished standard tests for jam ***
> Fri Aug 28 06:52:42 CDT 2009
> Total time = 0m 45s
> *** finished tests in jam ***
> Testing smirom
> ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
> opa
> 6:51am up 7 days 14:44, 8 users, load average: 0.00, 0.01, 0.08
> /dev/hdb1 76920416 10065672 62947336 14% /
> udev 1991252 116 1991136 1% /dev
> /dev/sda2 129736964 30511264 99225700 24% /scr
> /dev/sdb1 76920416 29633816 43379192 41% /usr
> jam:/home 198351840 11400640 176712832 7% /home
> jam:/mnt/hdf 961432096 228321056 684273056 26% /mnt/hdf
> jam:/mnt/scr1 961432096 373060928 539533184 41% /mnt/scr1
> TEST_TYPES=standard
> Running standard
> Fri Aug 28 06:52:00 CDT 2009
> *** starting standard tests in smirom ***
> Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
> SRCDIRNAME is smirom
> /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0828Fri_0652
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
> *** finished standard tests for smirom ***
> Fri Aug 28 06:52:54 CDT 2009
> Total time = 0m 54s
> *** finished tests in smirom ***
> Testing colonelk
> ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
> opa
> 06:51:52 up 2 days, 14:58, 0 users, load average: 0.00, 0.00, 0.00
> /dev/hda3 29753588 3596904 24620872 13% /
> /dev/hda2 49961020 2145940 45236248 5% /tmp
> /dev/hda6 9920592 675172 8733352 8% /var
> /dev/hda5 19840892 9690256 9126496 52% /scr
> /dev/hda1 101086 33319 62548 35% /boot
> tmpfs 517644 0 517644 0% /dev/shm
> TEST_TYPES=standard
> Running standard
> Fri Aug 28 06:52:02 CDT 2009
> *** starting standard tests in colonelk ***
> Uname -a: Linux colonelk 2.6.18-128.7.1.el5 #1 SMP Mon Aug 24 08:20:55 EDT 2009 i686 i686 i386 GNU/Linux
> SRCDIRNAME is colonelk
> /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0828Fri_0652
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
> *** finished standard tests for colonelk ***
> Fri Aug 28 06:53:26 CDT 2009
> Total time = 1m 24s
> *** finished tests in colonelk ***
> Testing duty
> ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
> opa
> 6:51AM up 93 days, 18:47, 0 users, load averages: 0.08, 0.02, 0.01
> Filesystem 1K-blocks Used Avail Capacity Mounted on
> /dev/aacd0s1a 507630 60994 406026 13% /
> devfs 1 1 0 100% /dev
> /dev/aacd0s1h 188433016 120649130 52709246 70% /data
> /dev/aacd0s1g 32494668 22762680 7132416 76% /local_home
> /dev/aacd0s1f 12186190 2777952 8433344 25% /usr
> /dev/aacd0s1d 507630 46242 420778 10% /var
> /dev/aacd0s1e 253678 334 233050 0% /var/tmp
> procfs 4 4 0 100% /proc
> jam:/home 198351840 11400652 176712828 6% /home
> jam:/mnt/scr1 961432072 373060924 539533148 41% /mnt/scr1
> gumund:/data/web 480719056 179002760 277297096 39% /mnt/web
> gumund:/data/ftp 480719056 179002760 277297096 39% /mnt/ftp
> devfs 1 1 0 100% /var/named/dev
> /dev/md0 126702 52 116514 0% /tmp
> jam:/mnt/hdf 961432072 228321036 684273036 25% /mnt/hdf
> TEST_TYPES=standard
> Running standard
> Fri Aug 28 06:52:04 CDT 2009
> *** starting standard tests in duty ***
> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
> SRCDIRNAME is duty
> /mnt/scr1/SnapTest/snapshots-opa/log/duty_0828Fri_0652
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
> *** finished standard tests for duty ***
> Fri Aug 28 06:53:53 CDT 2009
> Total time = 1m 49s
> *** finished tests in duty ***
> Testing liberty
> ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
> opa
> 6:51AM up 93 days, 18:49, 8 users, load averages: 0.00, 0.00, 0.00
> /dev/aacd0s1a 507630 86918 380102 19% /
> /dev/aacd0s1g 47047830 19507956 23776048 45% /local_home
> /dev/aacd0s1f 12186190 4198264 7013032 37% /usr
> /dev/aacd0s1d 1012974 99440 832498 11% /var
> /dev/aacd0s1e 507630 336490 130530 72% /var/tmp
> jam:/mnt/scr1 961432072 373060932 539533140 41% /mnt/scr1
> /dev/md0 126702 48 116518 0% /tmp
> TEST_TYPES=standard
> Running standard
> Fri Aug 28 06:52:07 CDT 2009
> *** starting standard tests in liberty ***
> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
> SRCDIRNAME is liberty
> /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0828Fri_0652
> SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
> *** finished standard tests for liberty ***
> Total time = 0m 47s
> *** finished tests in liberty ***
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
