[opa-nightly-tests] jam OPA_Daily_Tests_0828Fri_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Fri Aug 28 06:54:23 CDT 2009
*** OPA Tests on 0828Fri ***
Tests Summary
****FAILED linew: runtest command failed ****
****FAILED linew: standard****
PASSED colonelk: standard
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED smirom: standard
Tests Time Summary
linew: Ran 1(0/1/0) tests, Grand total test time = 0m 20s
jam: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 47s
smirom: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
colonelk: Ran 1(1/0/0) tests, Grand total test time = 1m 24s
duty: Ran 1(1/0/0) tests, Grand total test time = 1m 49s
jam: Ran 6(0/0/0) hosts, Grand total test time = 2m 45s
Timekeeper log
Timekeeper started at Fri Aug 28 06:51:40 CDT 2009
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of linew: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0828Fri_0651
gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
Making check in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake -j 2 sanity test_primitives test_barriers
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/snapshots-opa/current/test/sanity.c
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o test_primitives.o /home/hdftest/snapshots-opa/current/test/test_primitives.c
mv -f .deps/sanity.Tpo .deps/sanity.Po
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o test_barriers.o /home/hdftest/snapshots-opa/current/test/test_barriers.c
mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
gcc -g -O2 -o sanity sanity.o ../src/libopa.a -lpthread
gcc -g -O2 -o test_barriers test_barriers.o ../src/libopa.a -lpthread
mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
gcc -g -O2 -o test_primitives test_primitives.o ../src/libopa.a -lpthread
Undefined first referenced
symbol in file
pthread_yield test_primitives.o
ld: fatal: Symbol referencing errors. No output written to test_primitives
collect2: ld returned 1 exit status
gmake[2]: *** [test_primitives] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=0: Fri Aug 28 06:52:15 CDT 2009 =====
Dumping done
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
06:51:28 up 56 days, 22:15, 11 users, load average: 0.00, 0.00, 0.05
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3086116 27014076 11% /
/dev/sda1 101086 50879 44988 54% /boot
/dev/sda2 31738420 261304 29838888 1% /tmp
/dev/sda6 31738392 3768668 26331500 13% /var
/dev/sda7 31738392 14156260 15943908 48% /usr
/dev/sda8 124991068 14243052 104296316 13% /var/tmp
/dev/mapper/VolGroup00-home
198351840 11400652 176712828 7% /home
/dev/sde1 565688764 24524568 511965260 5% /scr
/dev/sdc1 961432072 373060868 539533204 41% /mnt/scr1
/dev/sdd1 961432072 228321036 684273036 26% /mnt/hdf
tmpfs 1551408 0 1551408 0% /dev/shm
gumund:/data/ftp 480719072 179002752 277297120 40% /mnt/ftp
gumund:/data/web 480719072 179002752 277297120 40% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0828Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0828Fri.25426: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0828Fri.25426': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
6:51am up 8 day(s), 18:51, 7 users, load average: 0.53, 1.01, 1.10
/ (/dev/dsk/c1t0d0s0 ):55780418 blocks 8043928 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483607 files
/proc (proc ): 0 blocks 29923 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):16252992 blocks 1181939 files
/system/object (objfs ): 0 blocks 2147483484 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):55780418 blocks 8043928 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):55780418 blocks 8043928 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):16252992 blocks 1181939 files
/var/run (swap ):16252992 blocks 1181939 files
/home (jam:/home ):373902376 blocks 51013065 files
/mnt/hdf (jam:/mnt/hdf ):1466222072 blocks 118056650 files
/mnt/scr1 (jam:/mnt/scr1 ):1176742360 blocks 118420739 files
/mnt/web (gumund:/mnt/web ):603432592 blocks 60658918 files
/mnt/ftp (gumund:/mnt/ftp ):603432592 blocks 60658918 files
TEST_TYPES=standard
Running standard
Fri Aug 28 06:51:55 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Total time = 0m 20s
*** finished tests in linew ***
****FAILED linew: Abnormal exit from runtest ****
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
06:51:47 up 56 days, 22:15, 11 users, load average: 0.00, 0.00, 0.05
/dev/sda2 31738420 261308 29838884 1% /tmp
/dev/sda6 31738392 3768664 26331504 13% /var
/dev/sdc1 961432072 373060900 539533172 41% /mnt/scr1
TEST_TYPES=standard
Running standard
Fri Aug 28 06:51:57 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0828Fri_0651
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Fri Aug 28 06:52:42 CDT 2009
Total time = 0m 45s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
6:51am up 7 days 14:44, 8 users, load average: 0.00, 0.01, 0.08
/dev/hdb1 76920416 10065672 62947336 14% /
udev 1991252 116 1991136 1% /dev
/dev/sda2 129736964 30511264 99225700 24% /scr
/dev/sdb1 76920416 29633816 43379192 41% /usr
jam:/home 198351840 11400640 176712832 7% /home
jam:/mnt/hdf 961432096 228321056 684273056 26% /mnt/hdf
jam:/mnt/scr1 961432096 373060928 539533184 41% /mnt/scr1
TEST_TYPES=standard
Running standard
Fri Aug 28 06:52:00 CDT 2009
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
/mnt/scr1/SnapTest/snapshots-opa/log/smirom_0828Fri_0652
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Fri Aug 28 06:52:54 CDT 2009
Total time = 0m 54s
*** finished tests in smirom ***
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
06:51:52 up 2 days, 14:58, 0 users, load average: 0.00, 0.00, 0.00
/dev/hda3 29753588 3596904 24620872 13% /
/dev/hda2 49961020 2145940 45236248 5% /tmp
/dev/hda6 9920592 675172 8733352 8% /var
/dev/hda5 19840892 9690256 9126496 52% /scr
/dev/hda1 101086 33319 62548 35% /boot
tmpfs 517644 0 517644 0% /dev/shm
TEST_TYPES=standard
Running standard
Fri Aug 28 06:52:02 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.7.1.el5 #1 SMP Mon Aug 24 08:20:55 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
/mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0828Fri_0652
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Fri Aug 28 06:53:26 CDT 2009
Total time = 1m 24s
*** finished tests in colonelk ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
6:51AM up 93 days, 18:47, 0 users, load averages: 0.08, 0.02, 0.01
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60994 406026 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 120649130 52709246 70% /data
/dev/aacd0s1g 32494668 22762680 7132416 76% /local_home
/dev/aacd0s1f 12186190 2777952 8433344 25% /usr
/dev/aacd0s1d 507630 46242 420778 10% /var
/dev/aacd0s1e 253678 334 233050 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 11400652 176712828 6% /home
jam:/mnt/scr1 961432072 373060924 539533148 41% /mnt/scr1
gumund:/data/web 480719056 179002760 277297096 39% /mnt/web
gumund:/data/ftp 480719056 179002760 277297096 39% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 52 116514 0% /tmp
jam:/mnt/hdf 961432072 228321036 684273036 25% /mnt/hdf
TEST_TYPES=standard
Running standard
Fri Aug 28 06:52:04 CDT 2009
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
SRCDIRNAME is duty
/mnt/scr1/SnapTest/snapshots-opa/log/duty_0828Fri_0652
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Fri Aug 28 06:53:53 CDT 2009
Total time = 1m 49s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
6:51AM up 93 days, 18:49, 8 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86918 380102 19% /
/dev/aacd0s1g 47047830 19507956 23776048 45% /local_home
/dev/aacd0s1f 12186190 4198264 7013032 37% /usr
/dev/aacd0s1d 1012974 99440 832498 11% /var
/dev/aacd0s1e 507630 336490 130530 72% /var/tmp
jam:/mnt/scr1 961432072 373060932 539533140 41% /mnt/scr1
/dev/md0 126702 48 116518 0% /tmp
TEST_TYPES=standard
Running standard
Fri Aug 28 06:52:07 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
SRCDIRNAME is liberty
/mnt/scr1/SnapTest/snapshots-opa/log/liberty_0828Fri_0652
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Total time = 0m 47s
*** finished tests in liberty ***
More information about the opa-nightly-tests
