[mpich2-dev] 0 byte derived types
Jeff Hammond
jhammond at alcf.anl.gov
Mon Apr 23 10:22:14 CDT 2012
If you read Brian's email, he indicates that there is a problem with
PAMI, but this is also a problem at the MPI level, if one is to
believe the comment in BLACS. Lee noted that he had to workaround
this problem with NEC-MPI as well, so it appears to be a corner case
that is overlooked in multiple implementations (for good reason; this
use case is ridiculous).
Jeff
On Mon, Apr 23, 2012 at 10:19 AM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> The assert you quote in the oldest email in the thread is in PAMI code, so I don't think this is directly an MPICH2 bug. I do agree, however, that zero-size, non-zero-count bcast should be tested in our test suite and that we have a coverage gap here.
> I'll add creating a test for this to my TODO list.
> -Dave
> On Apr 23, 2012, at 9:23 AM CDT, Jeff Hammond wrote:
>> A bug appeared when BGP came online and has reappared on BGQ. It
>> relates to MPI_Bcast of a non-zero number of 0-byte derived datatypes.
>> ScaLAPACK is one source of this patter. They have a workaround, but
>> it seems to be that either ScaLAPACK is using MPI in a non-compliant
>> way or there is a bug in MPICH2 that has persisted across many major
>> version releases.
>> Are you guys aware of this? Has it been fixed in 1.5? Is there a
>> test to make sure there is no regression in the future? The ScaLAPACK
>> code and comment noting the problem with MPICH is below, as is a long
>> email lthread with Brian Smith and Lee on this topic.
>> Thanks,
>> Jeff
>> #include "Bdef.h"
>> MPI_Datatype BI_GetMpiGeType(BLACSCONTEXT *ctxt, int m, int n, int lda,
>> MPI_Datatype Dtype, int *N)
>> int info;
>> MPI_Datatype GeType;
>> * Some versions of mpich and its derivitives cannot handle 0 byte typedefs,
>> * so we set type MPI_BYTE as a flag for a 0 byte message
>> #ifdef ZeroByteTypeBug
>> if ( (m < 1) || (n < 1) )
>> *N = 0;
>> return (MPI_BYTE);
>> #endif
>> *N = 1;
>> info=MPI_Type_vector(n, m, lda, Dtype, &GeType);
>> info=MPI_Type_commit(&GeType);
>> return(GeType);
>> ---------- Forwarded message ----------
>> From: Brian Smith <smithbr at us.ibm.com>
>> Date: Mon, Apr 23, 2012 at 8:32 AM
>> Subject: Re: [td-support #113586] PAMI assertions
>> To: Jeff Hammond <jhammond at alcf.anl.gov>
>> Cc: jeff.science at gmail.com, Lee Killough <killough at alcf.anl.gov>,
>> "td-support at alcf.anl.gov" <td-support at alcf.anl.gov>
>> Well, there are 2 different bugs here.
>> (from memory) 1) We found places were SCALAPACK made assumptions about
>> uninitialized variables that caused significant badness in a number of
>> apps. I believe someone reported this to the SCALAPACK maintainers
>> many years ago. In fact, they ran something like valgrind and provided
>> a patch for *all* of the usage of uninitialized variables. The
>> SCALAPACK people did not integrate the changes at the time. Perhaps
>> this new release will have some of them added so we don't have to deal
>> with that again. See
>> http://icl.cs.utk.edu/lapack-forum/viewtopic.php?f=2&t=588&p=1911&hilit=trsm#p1911
>> and
>> http://icl.cs.utk.edu/lapack-forum/viewtopic.php?f=13&t=2625
>> (more recently, based on different glue punt-to-MPICH-logic) 2)
>> SCALAPACK creates zero-length datatypes and then calls bcast with
>> nonzero counts. The glue didn't test for this condition.
>> A test for #2 in the MPICH2 test bucket wouldn't be a bad thing, but
>> #1 is of course beyond the scope of MPICH2. It is possible there is a
>> test for #2 already but because of other circumstances (node count for
>> example) we might not have seen a failure. I'm sure Dave G. or someone
>> could comment on that.
>> Brian Smith (smithbr at us.ibm.com)
>> BlueGene MPI Development/
>> Communications Team Lead
>> IBM Master Inventor
>> IBM Rochester
>> Phone: 507 253 4717
>> From: Jeff Hammond <jhammond at alcf.anl.gov>
>> To: Brian Smith/Rochester/IBM at IBMUS
>> Cc: Lee Killough <killough at alcf.anl.gov>,
>> Date: 04/21/2012 08:51 PM
>> Sent by: jeff.science at gmail.com
>> ________________________________
>> If this showed up on BGP and now on BGQ, why was it not added to the
>> MPICH2 test suite 3+ years ago? This is a bug in MPICH2 according to
>> the comments in ScaLAPACK and the fact that both BGP and BGQ suffered
>> it despite forking vastly different code bases, right?
>> I'm trying to write a standalone test for this, btw, but haven't been
>> successful yet.
>> Jeff
>> On Sat, Apr 21, 2012 at 8:46 PM, Brian Smith <smithbr at us.ibm.com> wrote:
>>> Hi Lee,
>>> It's not actually a user error, what SCALAPACK is doing is (probably, I
>>> didn't look at it too much) valid MPI code. However, it is appears to be a
>>> weird fringe case that none of the test cases that come with MPICH, nor the
>>> gigantic Intel/ANL testbucket found.
>>> Basically, we were missing an if() check in the collectives glue to check
>>> for nonzero counts of zero length datatypes. The optimized protocols don't
>>> deal with things like that which is why there was an assert().
>>> IBM Master Inventor
>>> IBM Rochester
>>> Phone: 507 253 4717
>>> "the scientific community is very A-Buzz with positive reviews of Blue Gene
>>> ..." - Charles Archer - un-sung hero of technology
>>> From: Lee Killough <killough at alcf.anl.gov>
>>> Cc: "td-support at alcf.anl.gov" <td-support at alcf.anl.gov>, Brian
>>> Date: 04/20/2012 11:08 PM
>>> Sorry, a busy evening after 6 pm, fast forwarding to this email, and have
>>> not read previous.
>>> First, if it's a user error, it should never be diagnosed in an assert().
>>> assert() is only intended for catching internal errors, and should be turned
>>> off in production code. It being an assert() immediately threw me off and
>>> made me think it was a configuration issue or mismatched libraries, etc.
>>> A new version of ScaLAPACK is about to be released, maybe even as I send
>>> this email. I have been working closely with the developers for the past
>>> month on several bugs, some of which are only seen on BG, such as illegal
>>> Fortran calls with overlapping arguments.
>>> If we can identify the cause and work on a fix for this bcast problem, I may
>>> be able to get it in before the next release, or maybe not. If you have a
>>> BLACS code fix suggestion, please send it and I'll try to get the fix in the
>>> next version of ScaLAPACK.
>>> Thanks,
>>> Lee
>>> On Apr 20, 2012, at 22:44, Jeff Hammond <jhammond at alcf.anl.gov> wrote:
>>>> IBM says it's a ScaLAPACK problem but that the latest MPI/PAMI has a
>>>> fix anyways.
>>>> See if this makes sense from the BLACS code. We can look through MPI
>>>> standard together next week to see if BLACS violates it. It would be
>>>> the first time Clint Whaley completely screwed up using MPI.
>>>> Jeff
>>>> Date: Fri, Apr 20, 2012 at 8:47 PM
>>>> Subject: Re: Fwd: [td-support #113586] PAMI assertions
>>>> Cc: jeff.science at gmail.com, Michael Blocksome <blocksom at us.ibm.com>
>>>> It's goofy datatype stuff in SCALAPACK. There's a fix in head... I
>>>> didn't/don't feel it was worth efixing.
>>>> I forget if the problem was a nonzero count with a zero-byte
>>>> constructed datatype or a zero count with a non-zero byte constructed
>>>> datatype, something stupid like that, so it's unlikely a real
>>>> application is going to hit it.
>>>> IBM Master Inventor
>>>> IBM Rochester
>>>> Phone: 507 253 4717
>>>> On Fri, Apr 20, 2012 at 7:34 PM, Jeff Hammond <jhammond at alcf.anl.gov>
>>>> wrote:
>>>>> 0-byte bcast is fine with the MPI I always use.
>>>>> Can you print the args at
>>>>> /gpfs/veas-fs0/killough/libs/build/SCALAPACK-xl/BLACS/SRC/dgebr2d_.c:127
>>>>> and see what I need to test?
>>>>> Thanks,
>>>>> Jeff
>>>>> On Fri, Apr 20, 2012 at 7:18 PM, Jeff Hammond <jhammond at alcf.anl.gov>
>>>>> wrote:
>>>>>> Assuming I am looking at the same code (PAMI Git head is V1R1M1
>>>>>> already and I'm too Git-impaired to toggle for V1R1M0, nor do I want
>>>>>> to do this in any case), the assertion that fails indicates a 0-byte
>>>>>> message is being attempted.
>>>>>> I'll write a test of 0-byte MPI_Bcast right now. Which MPI library
>>>>>> are you linking against?
>>>>>> Jeff
>>>>>> pami_result_t postShortCollective (uint32_t opcode,
>>>>>> uint32_t sizeoftype,
>>>>>> uint32_t bytes,
>>>>>> char * src,
>>>>>> PipeWorkQueue * dpwq,
>>>>>> pami_event_function
>>>>>> cb_done,
>>>>>> void * cookie,
>>>>>> unsigned classroute)
>>>>>> TRACE_FN_ENTER();
>>>>>> TRACE_FORMAT("opcode %u, sizeoftype %u, bytes %u, src %p,
>>>>>> dpwq %p, classroute %u", opcode, sizeoftype, bytes, src, dpwq,
>>>>>> classroute);
>>>>>> PAMI_assert (bytes <= _collstate._tempSize);
>>>>>> PAMI_assert(bytes); /*
>>>>>> JEFF: This is line 284 */
>>>>>> _int64Cpy(_collstate._tempBuf, src, bytes);
>>>>>> //memcpy(_collstate._tempBuf, src, bytes);
>>>>>> On Fri, Apr 20, 2012 at 6:06 PM, Lee Killough <killough at alcf.anl.gov>
>>>>>> wrote:
>>>>>>> With the new GA driver, I'm getting a lot of PAMI assertions when
>>>>>>> running
>>>>>>> ScaLAPACK programs. The traceback:
>>>>>>> Program : ./xzsep
>>>>>>> +++ID Rank: 0, TGID: 1, Core: 0, HWTID:0 TID: 1 State: RUN
>>>>>>> 00000000016a3638
>>>>>>> abort
>>>>>>> /bgsys/drivers/V1R1M0/ppc64/toolchain/gnu/glibc-2.12.2/stdlib/abort.c:77
>>>>>>> 000000000169c668
>>>>>>> __assert_fail
>>>>>>> /bgsys/drivers/V1R1M0/ppc64/toolchain/gnu/glibc-2.12.2/assert/assert.c:81
>>>>>>> 000000000149774c
>>>>>>> PAMI::Device::MU::CollectiveDmaModelBase::postShortCollective(unsigned
>>>>>>> int, unsigned int, unsigned int, char*, PAMI::PipeWorkQueue*, void
>>>>>>> (*)(void*, void*, pami_result_t), void*, unsigned int)
>>>>>>> /bgsys/source/srcV1R1M0.5670/comm/sys/buildtools/pami/components/devices/bgq/mu2/model/CollectiveDmaModelBase.h:284
>>>>>>> 0000000001497954
>>>>>>> PAMI::Device::MU::CollectiveMulticastDmaModel::postMulticastImmediate_impl(unsigned
>>>>>>> long, unsigned long, pami_multicast_t*, void*)
>>>>>>> /bgsys/source/srcV1R1M0.5670/comm/sys/buildtools/pami/components/devices/bgq/mu2/model/CollectiveMulticastDmaModel.h:107
>>>>>>> 0000000001394304
>>>>>>> PAMI::Geometry::Algorithm<PAMI::Geometry::Common>::generate(pami_xfer_t*)
>>>>>>> /bgsys/source/srcV1R1M0.5670/comm/sys/buildtools/pami/algorithms/geometry/Algorithm.h:45
>>>>>>> 0000000001359dec
>>>>>>> MPIDO_Bcast
>>>>>>> /bgsys/source/srcV1R1M0.5670/comm/lib/dev/mpich2/src/mpid/pamid/src/coll/bcast/mpido_bcast.c:146
>>>>>>> 00000000012f95cc
>>>>>>> MPIR_Bcast_impl
>>>>>>> /bgsys/source/srcV1R1M0.5670/comm/lib/dev/mpich2/src/mpi/coll/bcast.c:1310
>>>>>>> 00000000012f997c
>>>>>>> PMPI_Bcast
>>>>>>> /bgsys/source/srcV1R1M0.5670/comm/lib/dev/mpich2/src/mpi/coll/bcast.c:1464
>>>>>>> 000000000101b980
>>>>>>> dgebr2d
>>>>>>> 00000000010670f4
>>>>>>> pdlared1d
>>>>>>> /gpfs/veas-fs0/killough/libs/build/SCALAPACK-xl/SRC/pdlared1d.f:156
>>>>>>> 0000000001045350
>>>>>>> pzheevx
>>>>>>> /gpfs/veas-fs0/killough/libs/build/SCALAPACK-xl/SRC/pzheevx.f:839
>>>>>>> 00000000010084e0
>>>>>>> pzsepsubtst
>>>>>>> /gpfs/veas-fs0/killough/libs/build/SCALAPACK-xl/TESTING/EIG/pzsepsubtst.f:396
>>>>>>> 0000000001002874
>>>>>>> pzseptst
>>>>>>> /gpfs/veas-fs0/killough/libs/build/SCALAPACK-xl/TESTING/EIG/pzseptst.f:565
>>>>>>> 00000000010123ec
>>>>>>> pzsepreq
>>>>>>> /gpfs/veas-fs0/killough/libs/build/SCALAPACK-xl/TESTING/EIG/pzsepreq.f:205
>>>>>>> 00000000010112e8
>>>>>>> pzsepdriver
>>>>>>> /gpfs/veas-fs0/killough/libs/build/SCALAPACK-xl/TESTING/EIG/pzsepdriver.f:229
>>>>>>> 0000000001699b08
>>>>>>> generic_start_main
>>>>>>> /bgsys/drivers/V1R1M0/ppc64/toolchain/gnu/glibc-2.12.2/csu/../csu/libc-start.c:226
>>>>>>> 0000000001699e04
>>>>>>> __libc_start_main
>>>>>>> /bgsys/drivers/V1R1M0/ppc64/toolchain/gnu/glibc-2.12.2/csu/../sysdeps/unix/sysv/linux/powerpc/libc-start.c:194
>>>>>>> 0000000000000000
>>>>>>> ??:0
>>>>>>> It looks like an assertion is failing at:
>>>>>>> during a broadcast.
>>>>>>> I don't recall these errors in the previous driver.
>>>>>>> Lee
>>>>>> Jeff Hammond
>>>>>> Argonne Leadership Computing Facility
>>>>>> University of Chicago Computation Institute
>>>>>> jhammond at alcf.anl.gov / (630) 252-5381
>>>>>> http://www.linkedin.com/in/jeffhammond
>>>>>> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond (in-progress)
>>>>>> https://wiki.alcf.anl.gov/old/index.php/User:Jhammond (deprecated)
>>>>>> https://wiki-old.alcf.anl.gov/index.php/User:Jhammond(deprecated)
>>>>> Jeff Hammond
>>>> Jeff Hammond
>> Jeff Hammond
>> Jeff Hammond
Jeff Hammond
More information about the mpich2-dev
