[mpich2-dev] Problem building mvapich2-1.7
Dave Goodell
goodell at mcs.anl.gov
Tue Oct 11 11:15:51 CDT 2011
You should contact the MVAPICH2 team for support for MVAPICH2:
http://mail.cse.ohio-state.edu/mailman/listinfo/mvapich-discuss/
mvapich-discuss at cse.ohio-state.edu
-Dave
On Oct 11, 2011, at 11:12 AM CDT, Mike Heinz wrote:
> When building the version of mvapich2 shipped with OFED 1.5.4-rc1, I'm getting the following error message:
> /bin/sh ../libtool --finish /usr/mpi/gcc/mvapich2-1.7/lib/trace_rlog
> libtool: finish: invalid argument `/usr/mpi/gcc/mvapich2-1.7/lib/trace_rlog'
> make[2]: *** [INSTALL_LIBSO] Error 1
> Any ideas what might be causing this?
> This message and any attached documents contain information from QLogic Corporation or its wholly-owned subsidiaries that may be confidential. If you are not the intended recipient, you may not read, copy, distribute, or use this information. If you have received this transmission in error, please notify the sender immediately by reply e-mail and then delete this message.
More information about the mpich2-dev
