[mpich2-dev] Problem building mvapich2-1.7
Mike Heinz michael.heinz at qlogic.com
Tue Oct 11 11:12:47 CDT 2011
When building the version of mvapich2 shipped with OFED 1.5.4-rc1, I'm getting the following error message:
/bin/sh ../libtool --finish /usr/mpi/gcc/mvapich2-1.7/lib/trace_rlog
libtool: finish: invalid argument `/usr/mpi/gcc/mvapich2-1.7/lib/trace_rlog'
make[2]: *** [INSTALL_LIBSO] Error 1
Any ideas what might be causing this?
This message and any attached documents contain information from QLogic Corporation or its wholly-owned subsidiaries that may be confidential. If you are not the intended recipient, you may not read, copy, distribute, or use this information. If you have received this transmission in error, please notify the sender immediately by reply e-mail and then delete this message.
More information about the mpich2-dev mailing list
