[mpich2-dev] is there a gforker equivalent to the Windows mpich2?
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Feb 23 20:13:57 CST 2011
You can run smpd in the debug mode as a standalone process and suppress the debug messages by specifying 0 level debugging (Type "smpd -d 0" at the command prompt). If you are not installing MPICH2 on the system you will have to manually copy the MPICH2 dlls to the directory containing the MPI program (dir c:\windows\system32\mpich*.dll, dir c:\windows\system32\fmpich*.dll, dir c:\windows\system32\mpe*.dll - on a system with MPICH2 installed and you will see the dlls related to MPICH2).
Let us know if it works for you.
Jayesh
----- Original Message -----
To: mpich2-dev at mcs.anl.gov
Sent: Wednesday, February 23, 2011 5:06:05 PM
Subject: [mpich2-dev] is there a gforker equivalent to the Windows mpich2?
Hi, I work on the BOINC volunteer/distributed computing platform (as seen on
SETI at home & IBM World Community Grid :-). We are trying to make it
'mpich2-compatible' for MPI-enabled science apps to run locally on volunteer
host machines.
So far it has been good using the gforker process management on Linux & Mac for
running locally, i.e. we just need to send out mpiexec & hydra_pmi_proxy. But
it seems there's no such local, non-service/daemon option on Windows. This
would make our projects a little tricky on Windows, as volunteers on science
projects would need the installation .msi & smpd service running etc, before
attaching to our projects. But the nature of our "business" is volunteers get a
URL of a project to try and connect/attach to it assuming that the applications
are "self-contained".
Ideally we would like to just run an mpiexec (built a la the gforker/hydra which
is working for us locally) on Windows, or possibly distribute an smpd that would
just run locally in the background for the session (and not require a Windows
service installation etc).
Thanks in advance for any suggestions.
More information about the mpich2-dev
