[mpich2-dev] want to cross compile mpich2
郭沐Sn4+
maxgreg13625 at gmail.com
Sun Oct 17 12:56:06 CDT 2010
Dear all
I downloaded a tool chain from this website
http://www.codesourcery.com/sgpp/lite/arm/portal/subscription?@template=lite
I have try the follow steps to configure mpich2
$export CC=/home/sn/multiARM/arm-2010q1/bin/arm-none-linux-gnueabi-gcc
$export AR=/home/sn/multiARM/arm-2010q1/bin/arm-none-linux-gnueabi-ar
$export
RANLIB=/home/sn/multiARM/arm-2010q1/bin/arm-none-linux-gnueabi-ranlib
$export AS=/home/sn/multiARM/arm-2010q1/bin/arm-none-linux-gnueabi-as
$export LD=/home/sn/multiARM/arm-2010q1/bin/arm-none-linux-gnueabi-ld
$export NM=/home/sn/multiARM/arm-2010q1/bin/arm-none-linux-gnueabi-nm
$/home/sn/mpich2/libraries/mpich2-1.2.1p1/configure --disable-f77
--disable-f90 --disable-cxx --disable-sharedlibs
--prefix=/home/sn/mpich2/mpich2-install --build=i686-pc-linux-gnu
--host=arm-none-linux-gnueabi 2>&1 | tee c.txt
However the terminal will generate this error message as follow
configure: WARNING: Could not define Fortran MPI datatypes for C
checking the sizeof MPI_Offset…
/home/sn/mpich2/libraries/mpich2-1.2.1p1/configure: line 41544: ./conftest:
cannot execute binary file
configure: WARNING: Unable to run the program to determine the size of
MPI_Offset
unknown
configure: error: Unable to convert MPI_SIZEOF_OFFSET to a hex string. This
is either because we are building on a very strange platform or there is a
bug some in configure.
Is there any steps I tried was wrong!?
I don’t why the terminal generate this message.
Thanks a lot
Best Regards
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20101018/2dd9575f/attachment.htm>
More information about the mpich2-dev
