[mpich2-dev] [PATCH] Make the VCR API independent of the nature of the VCR list
Joe Ratterman
jratt0 at gmail.com
Wed Oct 6 08:22:53 CDT 2010
I guess I should have sent it out earlier. Thanks for taking a look at it,
and let me know if you have any questions for future use.
Joe Ratterman
On Wed, Oct 6, 2010 at 7:25 AM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> I sent a longer response to Joe's mail last night, but it appears to have
> gotten clogged in the pipes somewhere...
> Basically, this patch appears to be a dup of a ticket (#1061?). I tried
> applying it but it causes a lot of problems in ch3 that aren't easy to
> solve. We should integrate this sort of functionality, but we might need to
> do it slightly differently. I just haven't had the time recently.
> We should not attempt to slip this in at this late stage for 1.3.
> -Dave
> On Oct 6, 2010, at 7:44 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> > Thanks Joe. This looks good, though we'll need to port it to CH3 as well.
> > mpich2-core: Should this go into 1.3? This is an ADI change (though
> fairly minor). But we are already at 1.3rc2, so I don't know if we want to
> make such a change at this point.
> > -- Pavan
> > On 10/05/2010 04:40 PM, Joe Ratterman wrote:
> >> From: Joe Ratterman<jratt at us.ibm.com>
> >> Currently, all implementations of a communicator rank list must
> >> contain an actual list at least as long as the number of ranks in
> >> the communicator. This is because "comm_ptr->local_vcr[i]" is
> >> assumed to work.
> >> To avoid the list, it is possible to change the MPID_VCR API.
> >> Basically, all places that were previously passed
> >> "comm_ptr->local_vcr[i]" now contain "comm_ptr->local_vcr, i". This
> >> means that the VCR table can be something other than a list, and
> >> that callers are requesting some processing on the "i"th value
> >> instead of actually passing the "i"th value into the function.
> >> This patch makes the necessary changes to the core of MPICH2 1.3rc2,
> >> as well as changing an alternative version of the "dcmf" device.
> >> Signed-off-by: Joe Ratterman<jratt at us.ibm.com>
> >> mpich2/src/include/mpiimpl.h | 4 ++--
> >> mpich2/src/mpi/comm/comm_create.c | 4 ++--
> >> mpich2/src/mpi/comm/comm_group.c | 2 +-
> >> mpich2/src/mpi/comm/comm_remote_group.c | 2 +-
> >> mpich2/src/mpi/comm/comm_split.c | 12 ++++++------
> >> mpich2/src/mpi/comm/commutil.c | 10 +++++-----
> >> mpich2/src/mpi/comm/intercomm_create.c | 10 +++++-----
> >> mpich2/src/mpi/comm/intercomm_merge.c | 8 ++++----
> >> mpich2/src/mpi/group/grouputil.c | 2 +-
> >> mpich2/src/mpid/dcmfd/include/mpidi_hooks.h | 3 ++-
> >> mpich2/src/mpid/dcmfd/include/mpidi_macros.h | 2 +-
> >> mpich2/src/mpid/dcmfd/src/mpid_init.c | 4 ++--
> >> mpich2/src/mpid/dcmfd/src/mpid_vc.c | 16 ++++++++--------
> >> 13 files changed, 40 insertions(+), 39 deletions(-)
> >> diff --git a/mpich2/src/include/mpiimpl.h b/mpich2/src/include/mpiimpl.h
> >> index 013b4fe..6fd86fd 100644
> >> --- a/mpich2/src/include/mpiimpl.h
> >> +++ b/mpich2/src/include/mpiimpl.h
> >> @@ -3116,7 +3116,7 @@ int MPID_VCRT_Get_ptr(MPID_VCRT vcrt, MPID_VCR
> **vc_pptr);
> >> MPID_VCR_Dup - Create a duplicate reference to a virtual connection
> >> -int MPID_VCR_Dup(MPID_VCR orig_vcr, MPID_VCR * new_vcr);
> >> +int MPID_VCR_Dup(const MPID_VCR *orig_vcr, unsigned origin_index,
> MPID_VCR *new_vcr, unsigned new_index);
> >> MPID_VCR_Get_lpid - Get the local process id that corresponds to a
> >> @@ -3129,7 +3129,7 @@ int MPID_VCR_Dup(MPID_VCR orig_vcr, MPID_VCR *
> new_vcr);
> >> processes may use different ids to identify the same target process
> >> /* We macro-ized this at the device. */
> >> -int MPID_VCR_Get_lpid(MPID_VCR vcr, int * lpid_ptr);
> >> +int MPID_VCR_Get_lpid(MPID_VCR *vcr, unsigned index, int * lpid_ptr);
> >> /* Define a macro to allow us to select between statically selected
> functions
> >> diff --git a/mpich2/src/mpi/comm/comm_create.c
> b/mpich2/src/mpi/comm/comm_create.c
> >> index 33bab93..0241f49 100644
> >> --- a/mpich2/src/mpi/comm/comm_create.c
> >> +++ b/mpich2/src/mpi/comm/comm_create.c
> >> @@ -154,7 +154,7 @@ PMPI_LOCAL int
> MPIR_Comm_create_calculate_mapping(MPID_Group *group_ptr,
> >> mapping[i] = -1;
> >> for (j=0; j<vcr_size; j++) {
> >> int comm_lpid;
> >> - MPID_VCR_Get_lpid( vcr[j],&comm_lpid );
> >> + MPID_VCR_Get_lpid( vcr, j,&comm_lpid );
> >> if (comm_lpid == group_ptr->lrank_to_lpid[i].lpid) {
> >> mapping[i] = j;
> >> break;
> >> @@ -207,7 +207,7 @@ PMPI_LOCAL int
> MPIR_Comm_create_create_and_map_vcrt(int n,
> >> MPIU_DBG_MSG_FMT(COMM,VERBOSE,
> >> (MPIU_DBG_FDEST, "dupping from mapping_vcr=%p
> rank=%d into new_rank=%d/%d in new_vcr=%p",
> >> mapping_vcr, mapping[i], i, n, vcr));
> >> - mpi_errno = MPID_VCR_Dup(mapping_vcr[mapping[i]],&vcr[i]);
> >> + mpi_errno = MPID_VCR_Dup(mapping_vcr, mapping[i], vcr, i);
> >> if (mpi_errno) MPIU_ERR_POP(mpi_errno);
> >> diff --git a/mpich2/src/mpi/comm/comm_group.c
> b/mpich2/src/mpi/comm/comm_group.c
> >> index 7835307..d0700ae 100644
> >> --- a/mpich2/src/mpi/comm/comm_group.c
> >> +++ b/mpich2/src/mpi/comm/comm_group.c
> >> @@ -49,7 +49,7 @@ int MPIR_Comm_group_impl(MPID_Comm *comm_ptr,
> MPID_Group **group_ptr)
> >> local_vcr = comm_ptr->vcr;
> >> for (i=0; i<n; i++) {
> >> - (void) MPID_VCR_Get_lpid( local_vcr[i],&lpid );
> >> + (void) MPID_VCR_Get_lpid( local_vcr, i,&lpid );
> >> (*group_ptr)->lrank_to_lpid[i].lrank = i;
> >> (*group_ptr)->lrank_to_lpid[i].lpid = lpid;
> >> diff --git a/mpich2/src/mpi/comm/comm_remote_group.c
> b/mpich2/src/mpi/comm/comm_remote_group.c
> >> index a331bd0..5792df7 100644
> >> --- a/mpich2/src/mpi/comm/comm_remote_group.c
> >> +++ b/mpich2/src/mpi/comm/comm_remote_group.c
> >> @@ -41,7 +41,7 @@ int MPIR_Comm_remote_group_impl(MPID_Comm *comm_ptr,
> >> - (void) MPID_VCR_Get_lpid( comm_ptr->vcr[i],&lpid );
> >> + (void) MPID_VCR_Get_lpid( comm_ptr->vcr, i,&lpid );
> >> (*group_ptr)->size = n;
> >> diff --git a/mpich2/src/mpi/comm/comm_split.c
> b/mpich2/src/mpi/comm/comm_split.c
> >> index 964f241..603ee78 100644
> >> --- a/mpich2/src/mpi/comm/comm_split.c
> >> +++ b/mpich2/src/mpi/comm/comm_split.c
> >> @@ -236,8 +236,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int
> color, int key, MPID_Comm **ne
> >> MPID_VCRT_Get_ptr( (*newcomm_ptr)->local_vcrt,
> >> &(*newcomm_ptr)->local_vcr );
> >> for (i=0; i<new_size; i++) {
> >> - MPID_VCR_Dup( comm_ptr->local_vcr[keytable[i].color],
> >> - &(*newcomm_ptr)->local_vcr[i] );
> >> + MPID_VCR_Dup( comm_ptr->local_vcr, keytable[i].color,
> >> + (*newcomm_ptr)->local_vcr, i );
> >> if (keytable[i].color == comm_ptr->rank) {
> >> (*newcomm_ptr)->rank = i;
> >> @@ -261,8 +261,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int
> >> MPID_VCRT_Create( new_remote_size,&(*newcomm_ptr)->vcrt );
> >> MPID_VCRT_Get_ptr( (*newcomm_ptr)->vcrt,&(*newcomm_ptr)->vcr );
> >> for (i=0; i<new_remote_size; i++) {
> >> - MPID_VCR_Dup( comm_ptr->vcr[remotekeytable[i].color],
> >> - &(*newcomm_ptr)->vcr[i] );
> >> + MPID_VCR_Dup( comm_ptr->vcr, remotekeytable[i].color,
> >> + (*newcomm_ptr)->vcr, i );
> >> (*newcomm_ptr)->context_id = remote_context_id;
> >> @@ -278,8 +278,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int
> >> MPID_VCRT_Create( new_size,&(*newcomm_ptr)->vcrt );
> >> - MPID_VCR_Dup( comm_ptr->vcr[keytable[i].color],
> >> + MPID_VCR_Dup( comm_ptr->vcr, keytable[i].color,
> >> diff --git a/mpich2/src/mpi/comm/commutil.c
> b/mpich2/src/mpi/comm/commutil.c
> >> index 1eeaedc..fb7108d 100644
> >> --- a/mpich2/src/mpi/comm/commutil.c
> >> +++ b/mpich2/src/mpi/comm/commutil.c
> >> @@ -269,8 +269,8 @@ int MPIR_Comm_commit(MPID_Comm *comm)
> >> for (i = 0; i< num_local; ++i) {
> >> /* For rank i in the new communicator, find the
> corresponding
> >> rank in the input communicator */
> >> - MPID_VCR_Dup( comm->vcr[local_procs[i]],
> >> -&comm->node_comm->vcr[i] );
> >> + MPID_VCR_Dup( comm->vcr, local_procs[i],
> >> + comm->node_comm->vcr, i );
> >> MPID_Dev_comm_create_hook( comm->node_comm );
> >> @@ -297,8 +297,8 @@ int MPIR_Comm_commit(MPID_Comm *comm)
> >> for (i = 0; i< num_external; ++i) {
> corresponding
> >> - MPID_VCR_Dup( comm->vcr[external_procs[i]],
> >> -&comm->node_roots_comm->vcr[i] );
> >> + MPID_VCR_Dup( comm->vcr, external_procs[i],
> >> + comm->node_roots_comm->vcr, i );
> >> MPID_Dev_comm_create_hook( comm->node_roots_comm );
> >> @@ -1006,7 +1006,7 @@ int MPIR_Comm_copy( MPID_Comm *comm_ptr, int size,
> MPID_Comm **outcomm_ptr )
> >> for (i=0; i<size; i++) {
> >> /* For rank i in the new communicator, find the corresponding
> >> - MPID_VCR_Dup( comm_ptr->vcr[i],&newcomm_ptr->vcr[i] );
> >> + MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->vcr, i );
> >> diff --git a/mpich2/src/mpi/comm/intercomm_create.c
> b/mpich2/src/mpi/comm/intercomm_create.c
> >> index e713830..0cb5c1e 100644
> >> --- a/mpich2/src/mpi/comm/intercomm_create.c
> >> +++ b/mpich2/src/mpi/comm/intercomm_create.c
> >> @@ -105,7 +105,7 @@ PMPI_LOCAL int MPID_GPID_GetAllInComm( MPID_Comm
> *comm_ptr, int local_size,
> >> for (i=0; i<comm_ptr->local_size; i++) {
> >> *gpid++ = 0;
> >> - (void)MPID_VCR_Get_lpid( comm_ptr->vcr[i], gpid );
> >> + (void)MPID_VCR_Get_lpid( comm_ptr->vcr, i, gpid );
> >> gpid++;
> >> *singlePG = 1;
> >> @@ -140,8 +140,8 @@ PMPI_LOCAL int MPID_VCR_CommFromLpids( MPID_Comm
> *newcomm_ptr,
> >> /* printf( "[%d] Remote rank %d has lpid %d\n",
> >> MPIR_Process.comm_world->rank, i, lpids[i] ); */
> >> if (lpids[i]< commworld_ptr->remote_size) {
> >> - MPID_VCR_Dup( commworld_ptr->vcr[lpids[i]],
> >> - &newcomm_ptr->vcr[i] );
> >> + MPID_VCR_Dup( commworld_ptr->vcr, lpids[i],
> >> + newcomm_ptr->vcr, i );
> >> else {
> >> /* We must find the corresponding vcr for a given lpid */
> >> @@ -163,7 +163,7 @@ PMPI_LOCAL int MPID_LPID_GetAllInComm( MPID_Comm
> >> /* FIXME: Should be using the local_size argument */
> >> MPIU_Assert( comm_ptr->local_size == local_size );
> >> - (void)MPID_VCR_Get_lpid( comm_ptr->vcr[i],&local_lpids[i] );
> >> + (void)MPID_VCR_Get_lpid( comm_ptr->vcr, i,&local_lpids[i] );
> >> return 0;
> >> @@ -539,7 +539,7 @@ int MPI_Intercomm_create(MPI_Comm local_comm, int
> local_leader,
> >> MPID_VCRT_Create( comm_ptr->local_size,&newcomm_ptr->local_vcrt );
> >> MPID_VCRT_Get_ptr( newcomm_ptr->local_vcrt,&newcomm_ptr->local_vcr
> >> - MPID_VCR_Dup( comm_ptr->vcr[i],&newcomm_ptr->local_vcr[i] );
> >> + MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->local_vcr, i );
> >> /* Inherit the error handler (if any) */
> >> diff --git a/mpich2/src/mpi/comm/intercomm_merge.c
> b/mpich2/src/mpi/comm/intercomm_merge.c
> >> index 8fae687..b672767 100644
> >> --- a/mpich2/src/mpi/comm/intercomm_merge.c
> >> +++ b/mpich2/src/mpi/comm/intercomm_merge.c
> >> @@ -227,11 +227,11 @@ int MPI_Intercomm_merge(MPI_Comm intercomm, int
> high, MPI_Comm *newintracomm)
> >> /* remote group first */
> >> j = 0;
> >> for (i=0; i<comm_ptr->remote_size; i++) {
> >> - MPID_VCR_Dup( comm_ptr->vcr[i],&newcomm_ptr->vcr[j++] );
> >> + MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->vcr, j++ );
> >> if (i == comm_ptr->rank) newcomm_ptr->rank = j;
> >> - MPID_VCR_Dup( comm_ptr->local_vcr[i],&newcomm_ptr->vcr[j++] );
> >> + MPID_VCR_Dup( comm_ptr->local_vcr, i, newcomm_ptr->vcr, j++ );
> >> else {
> >> @@ -239,10 +239,10 @@ int MPI_Intercomm_merge(MPI_Comm intercomm, int
> >> j = 0;
> >> diff --git a/mpich2/src/mpi/group/grouputil.c
> b/mpich2/src/mpi/group/grouputil.c
> >> index dda81b3..963bad4 100644
> >> --- a/mpich2/src/mpi/group/grouputil.c
> >> +++ b/mpich2/src/mpi/group/grouputil.c
> >> @@ -383,7 +383,7 @@ int MPIR_GroupCheckVCRSubset( MPID_Group *group_ptr,
> int vsize, MPID_VCR *vcr,
> >> vsize*sizeof(MPID_Group_pmap_t),mpi_errno, "" );
> >> /* Initialize the vmap */
> >> for (i=0; i<vsize; i++) {
> >> - MPID_VCR_Get_lpid( vcr[i],&vmap[i].lpid );
> >> + MPID_VCR_Get_lpid( vcr, i,&vmap[i].lpid );
> >> vmap[i].lrank = i;
> >> vmap[i].next_lpid = 0;
> >> vmap[i].flag = 0;
> >> diff --git a/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
> b/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
> >> index d7db400..9081a4a 100644
> >> --- a/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
> >> +++ b/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
> >> @@ -13,7 +13,8 @@
> >> #define __include_mpidi_hooks_h__
> >> -typedef dcmf_task_t MPID_VCR;
> >> +typedef void MPID_VCR;
> >> +typedef dcmf_task_t MPIDI_VCR;
> >> typedef struct MPIDI_VCRT * MPID_VCRT;
> >> typedef size_t MPIDI_msg_sz_t;
> >> diff --git a/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
> b/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
> >> index 3acd105..73f1be9 100644
> >> --- a/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
> >> +++ b/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
> >> @@ -232,7 +232,7 @@ MPIDI_Context_local(MPID_Request * req)
> >> #define MPID_VCR_GET_LPID(vcr, index) \
> >> - vcr[index]; \
> >> + ((MPIDI_VCR*)vcr)[index]; \
> >> #define MPID_GPID_Get(comm_ptr, rank, gpid) \
> >> diff --git a/mpich2/src/mpid/dcmfd/src/mpid_init.c
> b/mpich2/src/mpid/dcmfd/src/mpid_init.c
> >> index 1a31681..4acdb13 100644
> >> --- a/mpich2/src/mpid/dcmfd/src/mpid_init.c
> >> +++ b/mpich2/src/mpid/dcmfd/src/mpid_init.c
> >> @@ -277,7 +277,7 @@ int MPID_Init(int * argc,
> >> rc = MPID_VCRT_Get_ptr(comm->vcrt,&comm->vcr);
> >> MPID_assert(rc == MPI_SUCCESS);
> >> - comm->vcr[i] = i;
> >> + ((MPIDI_VCR*)comm->vcr)[i] = i;
> >> /* basically a noop for now */
> >> MPIDI_Comm_create(comm);
> >> @@ -295,7 +295,7 @@ int MPID_Init(int * argc,
> >> - comm->vcr[0] = rank;
> >> + ((MPIDI_VCR*)comm->vcr)[0] = rank;
> >> diff --git a/mpich2/src/mpid/dcmfd/src/mpid_vc.c
> b/mpich2/src/mpid/dcmfd/src/mpid_vc.c
> >> index a106fc0..2fb4769 100644
> >> --- a/mpich2/src/mpid/dcmfd/src/mpid_vc.c
> >> +++ b/mpich2/src/mpid/dcmfd/src/mpid_vc.c
> >> @@ -17,20 +17,20 @@ struct MPIDI_VCRT
> >> MPIU_OBJECT_HEADER;
> >> unsigned size; /**< Number of entries in the table */
> >> - MPID_VCR vcr_table[0]; /**< Array of virtual connection references
> >> + MPIDI_VCR vcr_table[0]; /**< Array of virtual connection references
> >> - *new_vcr = orig_vcr;
> >> - return MPI_SUCCESS;
> >> + ((MPIDI_VCR*)new_vcr)[new_index] = MPID_VCR_GET_LPID(orig_vcr,
> origin_index);
> >> + return MPI_SUCCESS;
> >> - *lpid_ptr = (int)vcr;
> >> + *lpid_ptr = MPID_VCR_GET_LPID(vcr, index);
> >> int MPID_VCRT_Create(int size, MPID_VCRT *vcrt_ptr)
> >> @@ -38,7 +38,7 @@ int MPID_VCRT_Create(int size, MPID_VCRT *vcrt_ptr)
> >> struct MPIDI_VCRT * vcrt;
> >> int result;
> >> - vcrt = MPIU_Malloc(sizeof(struct MPIDI_VCRT) +
> size*sizeof(MPID_VCR));
> >> + vcrt = MPIU_Malloc(sizeof(struct MPIDI_VCRT) +
> size*sizeof(MPIDI_VCR));
> >> if (vcrt != NULL)
> >> MPIU_Object_set_ref(vcrt, 1);
> > Pavan Balaji
> > http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20101006/cfa36b2c/attachment-0001.htm>
More information about the mpich2-dev
