[mpich2-dev] [PATCH] Make the VCR API independent of the nature of the VCR list
Pavan Balaji
balaji at mcs.anl.gov
Wed Oct 6 06:44:02 CDT 2010
Thanks Joe. This looks good, though we'll need to port it to CH3 as well.
mpich2-core: Should this go into 1.3? This is an ADI change (though
fairly minor). But we are already at 1.3rc2, so I don't know if we want
to make such a change at this point.
-- Pavan
On 10/05/2010 04:40 PM, Joe Ratterman wrote:
> From: Joe Ratterman<jratt at us.ibm.com>
> Currently, all implementations of a communicator rank list must
> contain an actual list at least as long as the number of ranks in
> the communicator. This is because "comm_ptr->local_vcr[i]" is
> assumed to work.
> To avoid the list, it is possible to change the MPID_VCR API.
> Basically, all places that were previously passed
> "comm_ptr->local_vcr[i]" now contain "comm_ptr->local_vcr, i". This
> means that the VCR table can be something other than a list, and
> that callers are requesting some processing on the "i"th value
> instead of actually passing the "i"th value into the function.
> This patch makes the necessary changes to the core of MPICH2 1.3rc2,
> as well as changing an alternative version of the "dcmf" device.
> Signed-off-by: Joe Ratterman<jratt at us.ibm.com>
> mpich2/src/include/mpiimpl.h | 4 ++--
> mpich2/src/mpi/comm/comm_create.c | 4 ++--
> mpich2/src/mpi/comm/comm_group.c | 2 +-
> mpich2/src/mpi/comm/comm_remote_group.c | 2 +-
> mpich2/src/mpi/comm/comm_split.c | 12 ++++++------
> mpich2/src/mpi/comm/commutil.c | 10 +++++-----
> mpich2/src/mpi/comm/intercomm_create.c | 10 +++++-----
> mpich2/src/mpi/comm/intercomm_merge.c | 8 ++++----
> mpich2/src/mpi/group/grouputil.c | 2 +-
> mpich2/src/mpid/dcmfd/include/mpidi_hooks.h | 3 ++-
> mpich2/src/mpid/dcmfd/include/mpidi_macros.h | 2 +-
> mpich2/src/mpid/dcmfd/src/mpid_init.c | 4 ++--
> mpich2/src/mpid/dcmfd/src/mpid_vc.c | 16 ++++++++--------
> 13 files changed, 40 insertions(+), 39 deletions(-)
> diff --git a/mpich2/src/include/mpiimpl.h b/mpich2/src/include/mpiimpl.h
> index 013b4fe..6fd86fd 100644
> --- a/mpich2/src/include/mpiimpl.h
> +++ b/mpich2/src/include/mpiimpl.h
> @@ -3116,7 +3116,7 @@ int MPID_VCRT_Get_ptr(MPID_VCRT vcrt, MPID_VCR **vc_pptr);
> MPID_VCR_Dup - Create a duplicate reference to a virtual connection
> -int MPID_VCR_Dup(MPID_VCR orig_vcr, MPID_VCR * new_vcr);
> +int MPID_VCR_Dup(const MPID_VCR *orig_vcr, unsigned origin_index, MPID_VCR *new_vcr, unsigned new_index);
> MPID_VCR_Get_lpid - Get the local process id that corresponds to a
> @@ -3129,7 +3129,7 @@ int MPID_VCR_Dup(MPID_VCR orig_vcr, MPID_VCR * new_vcr);
> processes may use different ids to identify the same target process
> /* We macro-ized this at the device. */
> -int MPID_VCR_Get_lpid(MPID_VCR vcr, int * lpid_ptr);
> +int MPID_VCR_Get_lpid(MPID_VCR *vcr, unsigned index, int * lpid_ptr);
> /* Define a macro to allow us to select between statically selected functions
> diff --git a/mpich2/src/mpi/comm/comm_create.c b/mpich2/src/mpi/comm/comm_create.c
> index 33bab93..0241f49 100644
> --- a/mpich2/src/mpi/comm/comm_create.c
> +++ b/mpich2/src/mpi/comm/comm_create.c
> @@ -154,7 +154,7 @@ PMPI_LOCAL int MPIR_Comm_create_calculate_mapping(MPID_Group *group_ptr,
> mapping[i] = -1;
> for (j=0; j<vcr_size; j++) {
> int comm_lpid;
> - MPID_VCR_Get_lpid( vcr[j],&comm_lpid );
> + MPID_VCR_Get_lpid( vcr, j,&comm_lpid );
> if (comm_lpid == group_ptr->lrank_to_lpid[i].lpid) {
> mapping[i] = j;
> break;
> @@ -207,7 +207,7 @@ PMPI_LOCAL int MPIR_Comm_create_create_and_map_vcrt(int n,
> MPIU_DBG_MSG_FMT(COMM,VERBOSE,
> (MPIU_DBG_FDEST, "dupping from mapping_vcr=%p rank=%d into new_rank=%d/%d in new_vcr=%p",
> mapping_vcr, mapping[i], i, n, vcr));
> - mpi_errno = MPID_VCR_Dup(mapping_vcr[mapping[i]],&vcr[i]);
> + mpi_errno = MPID_VCR_Dup(mapping_vcr, mapping[i], vcr, i);
> if (mpi_errno) MPIU_ERR_POP(mpi_errno);
> diff --git a/mpich2/src/mpi/comm/comm_group.c b/mpich2/src/mpi/comm/comm_group.c
> index 7835307..d0700ae 100644
> --- a/mpich2/src/mpi/comm/comm_group.c
> +++ b/mpich2/src/mpi/comm/comm_group.c
> @@ -49,7 +49,7 @@ int MPIR_Comm_group_impl(MPID_Comm *comm_ptr, MPID_Group **group_ptr)
> local_vcr = comm_ptr->vcr;
> for (i=0; i<n; i++) {
> - (void) MPID_VCR_Get_lpid( local_vcr[i],&lpid );
> + (void) MPID_VCR_Get_lpid( local_vcr, i,&lpid );
> (*group_ptr)->lrank_to_lpid[i].lrank = i;
> (*group_ptr)->lrank_to_lpid[i].lpid = lpid;
> diff --git a/mpich2/src/mpi/comm/comm_remote_group.c b/mpich2/src/mpi/comm/comm_remote_group.c
> index a331bd0..5792df7 100644
> --- a/mpich2/src/mpi/comm/comm_remote_group.c
> +++ b/mpich2/src/mpi/comm/comm_remote_group.c
> @@ -41,7 +41,7 @@ int MPIR_Comm_remote_group_impl(MPID_Comm *comm_ptr, MPID_Group **group_ptr)
> - (void) MPID_VCR_Get_lpid( comm_ptr->vcr[i],&lpid );
> + (void) MPID_VCR_Get_lpid( comm_ptr->vcr, i,&lpid );
> (*group_ptr)->size = n;
> diff --git a/mpich2/src/mpi/comm/comm_split.c b/mpich2/src/mpi/comm/comm_split.c
> index 964f241..603ee78 100644
> --- a/mpich2/src/mpi/comm/comm_split.c
> +++ b/mpich2/src/mpi/comm/comm_split.c
> @@ -236,8 +236,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int color, int key, MPID_Comm **ne
> MPID_VCRT_Get_ptr( (*newcomm_ptr)->local_vcrt,
> &(*newcomm_ptr)->local_vcr );
> for (i=0; i<new_size; i++) {
> - MPID_VCR_Dup( comm_ptr->local_vcr[keytable[i].color],
> - &(*newcomm_ptr)->local_vcr[i] );
> + MPID_VCR_Dup( comm_ptr->local_vcr, keytable[i].color,
> + (*newcomm_ptr)->local_vcr, i );
> if (keytable[i].color == comm_ptr->rank) {
> (*newcomm_ptr)->rank = i;
> @@ -261,8 +261,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int color, int key, MPID_Comm **ne
> MPID_VCRT_Create( new_remote_size,&(*newcomm_ptr)->vcrt );
> MPID_VCRT_Get_ptr( (*newcomm_ptr)->vcrt,&(*newcomm_ptr)->vcr );
> for (i=0; i<new_remote_size; i++) {
> - MPID_VCR_Dup( comm_ptr->vcr[remotekeytable[i].color],
> - &(*newcomm_ptr)->vcr[i] );
> + MPID_VCR_Dup( comm_ptr->vcr, remotekeytable[i].color,
> + (*newcomm_ptr)->vcr, i );
> (*newcomm_ptr)->context_id = remote_context_id;
> @@ -278,8 +278,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int color, int key, MPID_Comm **ne
> MPID_VCRT_Create( new_size,&(*newcomm_ptr)->vcrt );
> - MPID_VCR_Dup( comm_ptr->vcr[keytable[i].color],
> + MPID_VCR_Dup( comm_ptr->vcr, keytable[i].color,
> diff --git a/mpich2/src/mpi/comm/commutil.c b/mpich2/src/mpi/comm/commutil.c
> index 1eeaedc..fb7108d 100644
> --- a/mpich2/src/mpi/comm/commutil.c
> +++ b/mpich2/src/mpi/comm/commutil.c
> @@ -269,8 +269,8 @@ int MPIR_Comm_commit(MPID_Comm *comm)
> for (i = 0; i< num_local; ++i) {
> /* For rank i in the new communicator, find the corresponding
> rank in the input communicator */
> - MPID_VCR_Dup( comm->vcr[local_procs[i]],
> -&comm->node_comm->vcr[i] );
> + MPID_VCR_Dup( comm->vcr, local_procs[i],
> + comm->node_comm->vcr, i );
> MPID_Dev_comm_create_hook( comm->node_comm );
> @@ -297,8 +297,8 @@ int MPIR_Comm_commit(MPID_Comm *comm)
> for (i = 0; i< num_external; ++i) {
> - MPID_VCR_Dup( comm->vcr[external_procs[i]],
> -&comm->node_roots_comm->vcr[i] );
> + MPID_VCR_Dup( comm->vcr, external_procs[i],
> + comm->node_roots_comm->vcr, i );
> MPID_Dev_comm_create_hook( comm->node_roots_comm );
> @@ -1006,7 +1006,7 @@ int MPIR_Comm_copy( MPID_Comm *comm_ptr, int size, MPID_Comm **outcomm_ptr )
> for (i=0; i<size; i++) {
> - MPID_VCR_Dup( comm_ptr->vcr[i],&newcomm_ptr->vcr[i] );
> + MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->vcr, i );
> diff --git a/mpich2/src/mpi/comm/intercomm_create.c b/mpich2/src/mpi/comm/intercomm_create.c
> index e713830..0cb5c1e 100644
> --- a/mpich2/src/mpi/comm/intercomm_create.c
> +++ b/mpich2/src/mpi/comm/intercomm_create.c
> @@ -105,7 +105,7 @@ PMPI_LOCAL int MPID_GPID_GetAllInComm( MPID_Comm *comm_ptr, int local_size,
> for (i=0; i<comm_ptr->local_size; i++) {
> *gpid++ = 0;
> - (void)MPID_VCR_Get_lpid( comm_ptr->vcr[i], gpid );
> + (void)MPID_VCR_Get_lpid( comm_ptr->vcr, i, gpid );
> gpid++;
> *singlePG = 1;
> @@ -140,8 +140,8 @@ PMPI_LOCAL int MPID_VCR_CommFromLpids( MPID_Comm *newcomm_ptr,
> /* printf( "[%d] Remote rank %d has lpid %d\n",
> MPIR_Process.comm_world->rank, i, lpids[i] ); */
> if (lpids[i]< commworld_ptr->remote_size) {
> - MPID_VCR_Dup( commworld_ptr->vcr[lpids[i]],
> - &newcomm_ptr->vcr[i] );
> + MPID_VCR_Dup( commworld_ptr->vcr, lpids[i],
> + newcomm_ptr->vcr, i );
> else {
> /* We must find the corresponding vcr for a given lpid */
> @@ -163,7 +163,7 @@ PMPI_LOCAL int MPID_LPID_GetAllInComm( MPID_Comm *comm_ptr, int local_size,
> /* FIXME: Should be using the local_size argument */
> MPIU_Assert( comm_ptr->local_size == local_size );
> - (void)MPID_VCR_Get_lpid( comm_ptr->vcr[i],&local_lpids[i] );
> + (void)MPID_VCR_Get_lpid( comm_ptr->vcr, i,&local_lpids[i] );
> return 0;
> @@ -539,7 +539,7 @@ int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader,
> MPID_VCRT_Create( comm_ptr->local_size,&newcomm_ptr->local_vcrt );
> MPID_VCRT_Get_ptr( newcomm_ptr->local_vcrt,&newcomm_ptr->local_vcr );
> - MPID_VCR_Dup( comm_ptr->vcr[i],&newcomm_ptr->local_vcr[i] );
> + MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->local_vcr, i );
> /* Inherit the error handler (if any) */
> diff --git a/mpich2/src/mpi/comm/intercomm_merge.c b/mpich2/src/mpi/comm/intercomm_merge.c
> index 8fae687..b672767 100644
> --- a/mpich2/src/mpi/comm/intercomm_merge.c
> +++ b/mpich2/src/mpi/comm/intercomm_merge.c
> @@ -227,11 +227,11 @@ int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm)
> /* remote group first */
> j = 0;
> for (i=0; i<comm_ptr->remote_size; i++) {
> - MPID_VCR_Dup( comm_ptr->vcr[i],&newcomm_ptr->vcr[j++] );
> + MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->vcr, j++ );
> if (i == comm_ptr->rank) newcomm_ptr->rank = j;
> - MPID_VCR_Dup( comm_ptr->local_vcr[i],&newcomm_ptr->vcr[j++] );
> + MPID_VCR_Dup( comm_ptr->local_vcr, i, newcomm_ptr->vcr, j++ );
> else {
> @@ -239,10 +239,10 @@ int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm)
> j = 0;
> diff --git a/mpich2/src/mpi/group/grouputil.c b/mpich2/src/mpi/group/grouputil.c
> index dda81b3..963bad4 100644
> --- a/mpich2/src/mpi/group/grouputil.c
> +++ b/mpich2/src/mpi/group/grouputil.c
> @@ -383,7 +383,7 @@ int MPIR_GroupCheckVCRSubset( MPID_Group *group_ptr, int vsize, MPID_VCR *vcr,
> vsize*sizeof(MPID_Group_pmap_t),mpi_errno, "" );
> /* Initialize the vmap */
> for (i=0; i<vsize; i++) {
> - MPID_VCR_Get_lpid( vcr[i],&vmap[i].lpid );
> + MPID_VCR_Get_lpid( vcr, i,&vmap[i].lpid );
> vmap[i].lrank = i;
> vmap[i].next_lpid = 0;
> vmap[i].flag = 0;
> diff --git a/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h b/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
> index d7db400..9081a4a 100644
> --- a/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
> +++ b/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
> @@ -13,7 +13,8 @@
> #define __include_mpidi_hooks_h__
> -typedef dcmf_task_t MPID_VCR;
> +typedef void MPID_VCR;
> +typedef dcmf_task_t MPIDI_VCR;
> typedef struct MPIDI_VCRT * MPID_VCRT;
> typedef size_t MPIDI_msg_sz_t;
> diff --git a/mpich2/src/mpid/dcmfd/include/mpidi_macros.h b/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
> index 3acd105..73f1be9 100644
> --- a/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
> +++ b/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
> @@ -232,7 +232,7 @@ MPIDI_Context_local(MPID_Request * req)
> #define MPID_VCR_GET_LPID(vcr, index) \
> - vcr[index]; \
> + ((MPIDI_VCR*)vcr)[index]; \
> #define MPID_GPID_Get(comm_ptr, rank, gpid) \
> diff --git a/mpich2/src/mpid/dcmfd/src/mpid_init.c b/mpich2/src/mpid/dcmfd/src/mpid_init.c
> index 1a31681..4acdb13 100644
> --- a/mpich2/src/mpid/dcmfd/src/mpid_init.c
> +++ b/mpich2/src/mpid/dcmfd/src/mpid_init.c
> @@ -277,7 +277,7 @@ int MPID_Init(int * argc,
> rc = MPID_VCRT_Get_ptr(comm->vcrt,&comm->vcr);
> MPID_assert(rc == MPI_SUCCESS);
> - comm->vcr[i] = i;
> + ((MPIDI_VCR*)comm->vcr)[i] = i;
> /* basically a noop for now */
> MPIDI_Comm_create(comm);
> @@ -295,7 +295,7 @@ int MPID_Init(int * argc,
> - comm->vcr[0] = rank;
> + ((MPIDI_VCR*)comm->vcr)[0] = rank;
> diff --git a/mpich2/src/mpid/dcmfd/src/mpid_vc.c b/mpich2/src/mpid/dcmfd/src/mpid_vc.c
> index a106fc0..2fb4769 100644
> --- a/mpich2/src/mpid/dcmfd/src/mpid_vc.c
> +++ b/mpich2/src/mpid/dcmfd/src/mpid_vc.c
> @@ -17,20 +17,20 @@ struct MPIDI_VCRT
> MPIU_OBJECT_HEADER;
> unsigned size; /**< Number of entries in the table */
> - MPID_VCR vcr_table[0]; /**< Array of virtual connection references */
> + MPIDI_VCR vcr_table[0]; /**< Array of virtual connection references */
> - *new_vcr = orig_vcr;
> - return MPI_SUCCESS;
> + ((MPIDI_VCR*)new_vcr)[new_index] = MPID_VCR_GET_LPID(orig_vcr, origin_index);
> + return MPI_SUCCESS;
> - *lpid_ptr = (int)vcr;
> + *lpid_ptr = MPID_VCR_GET_LPID(vcr, index);
> int MPID_VCRT_Create(int size, MPID_VCRT *vcrt_ptr)
> @@ -38,7 +38,7 @@ int MPID_VCRT_Create(int size, MPID_VCRT *vcrt_ptr)
> struct MPIDI_VCRT * vcrt;
> int result;
> - vcrt = MPIU_Malloc(sizeof(struct MPIDI_VCRT) + size*sizeof(MPID_VCR));
> + vcrt = MPIU_Malloc(sizeof(struct MPIDI_VCRT) + size*sizeof(MPIDI_VCR));
> if (vcrt != NULL)
> MPIU_Object_set_ref(vcrt, 1);
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-dev
