[mpich2-dev] [PATCH] Make the VCR API independent of the nature of the VCR list
Joe Ratterman
jratt0 at gmail.com
Tue Oct 5 16:40:48 CDT 2010
Currently, all implementations of a communicator rank list must
contain an actual list at least as long as the number of ranks in
the communicator. This is because "comm_ptr->local_vcr[i]" is
assumed to work.
To avoid the list, it is possible to change the MPID_VCR API.
Basically, all places that were previously passed
"comm_ptr->local_vcr[i]" now contain "comm_ptr->local_vcr, i". This
means that the VCR table can be something other than a list, and
that callers are requesting some processing on the "i"th value
instead of actually passing the "i"th value into the function.
This patch makes the necessary changes to the core of MPICH2 1.3rc2,
as well as changing an alternative version of the "dcmf" device.
Signed-off-by: Joe Ratterman <jratt at us.ibm.com>
mpich2/src/include/mpiimpl.h | 4 ++--
mpich2/src/mpi/comm/comm_create.c | 4 ++--
mpich2/src/mpi/comm/comm_group.c | 2 +-
mpich2/src/mpi/comm/comm_remote_group.c | 2 +-
mpich2/src/mpi/comm/comm_split.c | 12 ++++++------
mpich2/src/mpi/comm/commutil.c | 10 +++++-----
mpich2/src/mpi/comm/intercomm_create.c | 10 +++++-----
mpich2/src/mpi/comm/intercomm_merge.c | 8 ++++----
mpich2/src/mpi/group/grouputil.c | 2 +-
mpich2/src/mpid/dcmfd/include/mpidi_hooks.h | 3 ++-
mpich2/src/mpid/dcmfd/include/mpidi_macros.h | 2 +-
mpich2/src/mpid/dcmfd/src/mpid_init.c | 4 ++--
mpich2/src/mpid/dcmfd/src/mpid_vc.c | 16 ++++++++--------
13 files changed, 40 insertions(+), 39 deletions(-)
diff --git a/mpich2/src/include/mpiimpl.h b/mpich2/src/include/mpiimpl.h
index 013b4fe..6fd86fd 100644
--- a/mpich2/src/include/mpiimpl.h
+++ b/mpich2/src/include/mpiimpl.h
@@ -3116,7 +3116,7 @@ int MPID_VCRT_Get_ptr(MPID_VCRT vcrt, MPID_VCR **vc_pptr);
MPID_VCR_Dup - Create a duplicate reference to a virtual connection
-int MPID_VCR_Dup(MPID_VCR orig_vcr, MPID_VCR * new_vcr);
+int MPID_VCR_Dup(const MPID_VCR *orig_vcr, unsigned origin_index, MPID_VCR *new_vcr, unsigned new_index);
MPID_VCR_Get_lpid - Get the local process id that corresponds to a
@@ -3129,7 +3129,7 @@ int MPID_VCR_Dup(MPID_VCR orig_vcr, MPID_VCR * new_vcr);
processes may use different ids to identify the same target process
/* We macro-ized this at the device. */
-int MPID_VCR_Get_lpid(MPID_VCR vcr, int * lpid_ptr);
+int MPID_VCR_Get_lpid(MPID_VCR *vcr, unsigned index, int * lpid_ptr);
/* Define a macro to allow us to select between statically selected functions
diff --git a/mpich2/src/mpi/comm/comm_create.c b/mpich2/src/mpi/comm/comm_create.c
index 33bab93..0241f49 100644
--- a/mpich2/src/mpi/comm/comm_create.c
+++ b/mpich2/src/mpi/comm/comm_create.c
@@ -154,7 +154,7 @@ PMPI_LOCAL int MPIR_Comm_create_calculate_mapping(MPID_Group *group_ptr,
mapping[i] = -1;
for (j=0; j<vcr_size; j++) {
int comm_lpid;
- MPID_VCR_Get_lpid( vcr[j], &comm_lpid );
+ MPID_VCR_Get_lpid( vcr, j, &comm_lpid );
if (comm_lpid == group_ptr->lrank_to_lpid[i].lpid) {
mapping[i] = j;
break;
@@ -207,7 +207,7 @@ PMPI_LOCAL int MPIR_Comm_create_create_and_map_vcrt(int n,
MPIU_DBG_MSG_FMT(COMM,VERBOSE,
(MPIU_DBG_FDEST, "dupping from mapping_vcr=%p rank=%d into new_rank=%d/%d in new_vcr=%p",
mapping_vcr, mapping[i], i, n, vcr));
- mpi_errno = MPID_VCR_Dup(mapping_vcr[mapping[i]], &vcr[i]);
+ mpi_errno = MPID_VCR_Dup(mapping_vcr, mapping[i], vcr, i);
if (mpi_errno) MPIU_ERR_POP(mpi_errno);
diff --git a/mpich2/src/mpi/comm/comm_group.c b/mpich2/src/mpi/comm/comm_group.c
index 7835307..d0700ae 100644
--- a/mpich2/src/mpi/comm/comm_group.c
+++ b/mpich2/src/mpi/comm/comm_group.c
@@ -49,7 +49,7 @@ int MPIR_Comm_group_impl(MPID_Comm *comm_ptr, MPID_Group **group_ptr)
local_vcr = comm_ptr->vcr;
for (i=0; i<n; i++) {
- (void) MPID_VCR_Get_lpid( local_vcr[i], &lpid );
+ (void) MPID_VCR_Get_lpid( local_vcr, i, &lpid );
(*group_ptr)->lrank_to_lpid[i].lrank = i;
(*group_ptr)->lrank_to_lpid[i].lpid = lpid;
diff --git a/mpich2/src/mpi/comm/comm_remote_group.c b/mpich2/src/mpi/comm/comm_remote_group.c
index a331bd0..5792df7 100644
--- a/mpich2/src/mpi/comm/comm_remote_group.c
+++ b/mpich2/src/mpi/comm/comm_remote_group.c
@@ -41,7 +41,7 @@ int MPIR_Comm_remote_group_impl(MPID_Comm *comm_ptr, MPID_Group **group_ptr)
- (void) MPID_VCR_Get_lpid( comm_ptr->vcr[i], &lpid );
+ (void) MPID_VCR_Get_lpid( comm_ptr->vcr, i, &lpid );
(*group_ptr)->size = n;
diff --git a/mpich2/src/mpi/comm/comm_split.c b/mpich2/src/mpi/comm/comm_split.c
index 964f241..603ee78 100644
--- a/mpich2/src/mpi/comm/comm_split.c
+++ b/mpich2/src/mpi/comm/comm_split.c
@@ -236,8 +236,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int color, int key, MPID_Comm **ne
MPID_VCRT_Get_ptr( (*newcomm_ptr)->local_vcrt,
&(*newcomm_ptr)->local_vcr );
for (i=0; i<new_size; i++) {
- MPID_VCR_Dup( comm_ptr->local_vcr[keytable[i].color],
- &(*newcomm_ptr)->local_vcr[i] );
+ MPID_VCR_Dup( comm_ptr->local_vcr, keytable[i].color,
+ (*newcomm_ptr)->local_vcr, i );
if (keytable[i].color == comm_ptr->rank) {
(*newcomm_ptr)->rank = i;
@@ -261,8 +261,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int color, int key, MPID_Comm **ne
MPID_VCRT_Create( new_remote_size, &(*newcomm_ptr)->vcrt );
MPID_VCRT_Get_ptr( (*newcomm_ptr)->vcrt, &(*newcomm_ptr)->vcr );
for (i=0; i<new_remote_size; i++) {
- MPID_VCR_Dup( comm_ptr->vcr[remotekeytable[i].color],
- &(*newcomm_ptr)->vcr[i] );
+ MPID_VCR_Dup( comm_ptr->vcr, remotekeytable[i].color,
+ (*newcomm_ptr)->vcr, i );
(*newcomm_ptr)->context_id = remote_context_id;
@@ -278,8 +278,8 @@ int MPIR_Comm_split_impl(MPID_Comm *comm_ptr, int color, int key, MPID_Comm **ne
MPID_VCRT_Create( new_size, &(*newcomm_ptr)->vcrt );
- MPID_VCR_Dup( comm_ptr->vcr[keytable[i].color],
+ MPID_VCR_Dup( comm_ptr->vcr, keytable[i].color,
diff --git a/mpich2/src/mpi/comm/commutil.c b/mpich2/src/mpi/comm/commutil.c
index 1eeaedc..fb7108d 100644
--- a/mpich2/src/mpi/comm/commutil.c
+++ b/mpich2/src/mpi/comm/commutil.c
@@ -269,8 +269,8 @@ int MPIR_Comm_commit(MPID_Comm *comm)
for (i = 0; i < num_local; ++i) {
/* For rank i in the new communicator, find the corresponding
rank in the input communicator */
- MPID_VCR_Dup( comm->vcr[local_procs[i]],
- &comm->node_comm->vcr[i] );
+ MPID_VCR_Dup( comm->vcr, local_procs[i],
+ comm->node_comm->vcr, i );
MPID_Dev_comm_create_hook( comm->node_comm );
@@ -297,8 +297,8 @@ int MPIR_Comm_commit(MPID_Comm *comm)
for (i = 0; i < num_external; ++i) {
- MPID_VCR_Dup( comm->vcr[external_procs[i]],
- &comm->node_roots_comm->vcr[i] );
+ MPID_VCR_Dup( comm->vcr, external_procs[i],
+ comm->node_roots_comm->vcr, i );
MPID_Dev_comm_create_hook( comm->node_roots_comm );
@@ -1006,7 +1006,7 @@ int MPIR_Comm_copy( MPID_Comm *comm_ptr, int size, MPID_Comm **outcomm_ptr )
for (i=0; i<size; i++) {
- MPID_VCR_Dup( comm_ptr->vcr[i], &newcomm_ptr->vcr[i] );
+ MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->vcr, i );
diff --git a/mpich2/src/mpi/comm/intercomm_create.c b/mpich2/src/mpi/comm/intercomm_create.c
index e713830..0cb5c1e 100644
--- a/mpich2/src/mpi/comm/intercomm_create.c
+++ b/mpich2/src/mpi/comm/intercomm_create.c
@@ -105,7 +105,7 @@ PMPI_LOCAL int MPID_GPID_GetAllInComm( MPID_Comm *comm_ptr, int local_size,
for (i=0; i<comm_ptr->local_size; i++) {
*gpid++ = 0;
- (void)MPID_VCR_Get_lpid( comm_ptr->vcr[i], gpid );
+ (void)MPID_VCR_Get_lpid( comm_ptr->vcr, i, gpid );
gpid++;
*singlePG = 1;
@@ -140,8 +140,8 @@ PMPI_LOCAL int MPID_VCR_CommFromLpids( MPID_Comm *newcomm_ptr,
/* printf( "[%d] Remote rank %d has lpid %d\n",
MPIR_Process.comm_world->rank, i, lpids[i] ); */
if (lpids[i] < commworld_ptr->remote_size) {
- MPID_VCR_Dup( commworld_ptr->vcr[lpids[i]],
- &newcomm_ptr->vcr[i] );
+ MPID_VCR_Dup( commworld_ptr->vcr, lpids[i],
+ newcomm_ptr->vcr, i );
else {
/* We must find the corresponding vcr for a given lpid */
@@ -163,7 +163,7 @@ PMPI_LOCAL int MPID_LPID_GetAllInComm( MPID_Comm *comm_ptr, int local_size,
/* FIXME: Should be using the local_size argument */
MPIU_Assert( comm_ptr->local_size == local_size );
- (void)MPID_VCR_Get_lpid( comm_ptr->vcr[i], &local_lpids[i] );
+ (void)MPID_VCR_Get_lpid( comm_ptr->vcr, i, &local_lpids[i] );
return 0;
@@ -539,7 +539,7 @@ int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader,
MPID_VCRT_Create( comm_ptr->local_size, &newcomm_ptr->local_vcrt );
MPID_VCRT_Get_ptr( newcomm_ptr->local_vcrt, &newcomm_ptr->local_vcr );
- MPID_VCR_Dup( comm_ptr->vcr[i], &newcomm_ptr->local_vcr[i] );
+ MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->local_vcr, i );
/* Inherit the error handler (if any) */
diff --git a/mpich2/src/mpi/comm/intercomm_merge.c b/mpich2/src/mpi/comm/intercomm_merge.c
index 8fae687..b672767 100644
--- a/mpich2/src/mpi/comm/intercomm_merge.c
+++ b/mpich2/src/mpi/comm/intercomm_merge.c
@@ -227,11 +227,11 @@ int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm)
/* remote group first */
j = 0;
for (i=0; i<comm_ptr->remote_size; i++) {
- MPID_VCR_Dup( comm_ptr->vcr[i], &newcomm_ptr->vcr[j++] );
+ MPID_VCR_Dup( comm_ptr->vcr, i, newcomm_ptr->vcr, j++ );
if (i == comm_ptr->rank) newcomm_ptr->rank = j;
- MPID_VCR_Dup( comm_ptr->local_vcr[i], &newcomm_ptr->vcr[j++] );
+ MPID_VCR_Dup( comm_ptr->local_vcr, i, newcomm_ptr->vcr, j++ );
else {
@@ -239,10 +239,10 @@ int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm)
j = 0;
diff --git a/mpich2/src/mpi/group/grouputil.c b/mpich2/src/mpi/group/grouputil.c
index dda81b3..963bad4 100644
--- a/mpich2/src/mpi/group/grouputil.c
+++ b/mpich2/src/mpi/group/grouputil.c
@@ -383,7 +383,7 @@ int MPIR_GroupCheckVCRSubset( MPID_Group *group_ptr, int vsize, MPID_VCR *vcr,
vsize*sizeof(MPID_Group_pmap_t),mpi_errno, "" );
/* Initialize the vmap */
for (i=0; i<vsize; i++) {
- MPID_VCR_Get_lpid( vcr[i], &vmap[i].lpid );
+ MPID_VCR_Get_lpid( vcr, i, &vmap[i].lpid );
vmap[i].lrank = i;
vmap[i].next_lpid = 0;
vmap[i].flag = 0;
diff --git a/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h b/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
index d7db400..9081a4a 100644
--- a/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
+++ b/mpich2/src/mpid/dcmfd/include/mpidi_hooks.h
@@ -13,7 +13,8 @@
#define __include_mpidi_hooks_h__
-typedef dcmf_task_t MPID_VCR;
+typedef void MPID_VCR;
+typedef dcmf_task_t MPIDI_VCR;
typedef struct MPIDI_VCRT * MPID_VCRT;
typedef size_t MPIDI_msg_sz_t;
diff --git a/mpich2/src/mpid/dcmfd/include/mpidi_macros.h b/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
index 3acd105..73f1be9 100644
--- a/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
+++ b/mpich2/src/mpid/dcmfd/include/mpidi_macros.h
@@ -232,7 +232,7 @@ MPIDI_Context_local(MPID_Request * req)
#define MPID_VCR_GET_LPID(vcr, index) \
- vcr[index]; \
+ ((MPIDI_VCR*)vcr)[index]; \
#define MPID_GPID_Get(comm_ptr, rank, gpid) \
diff --git a/mpich2/src/mpid/dcmfd/src/mpid_init.c b/mpich2/src/mpid/dcmfd/src/mpid_init.c
index 1a31681..4acdb13 100644
--- a/mpich2/src/mpid/dcmfd/src/mpid_init.c
+++ b/mpich2/src/mpid/dcmfd/src/mpid_init.c
@@ -277,7 +277,7 @@ int MPID_Init(int * argc,
rc = MPID_VCRT_Get_ptr(comm->vcrt, &comm->vcr);
MPID_assert(rc == MPI_SUCCESS);
- comm->vcr[i] = i;
+ ((MPIDI_VCR*)comm->vcr)[i] = i;
/* basically a noop for now */
MPIDI_Comm_create(comm);
@@ -295,7 +295,7 @@ int MPID_Init(int * argc,
- comm->vcr[0] = rank;
+ ((MPIDI_VCR*)comm->vcr)[0] = rank;
diff --git a/mpich2/src/mpid/dcmfd/src/mpid_vc.c b/mpich2/src/mpid/dcmfd/src/mpid_vc.c
index a106fc0..2fb4769 100644
--- a/mpich2/src/mpid/dcmfd/src/mpid_vc.c
+++ b/mpich2/src/mpid/dcmfd/src/mpid_vc.c
@@ -17,20 +17,20 @@ struct MPIDI_VCRT
MPIU_OBJECT_HEADER;
unsigned size; /**< Number of entries in the table */
- MPID_VCR vcr_table[0]; /**< Array of virtual connection references */
+ MPIDI_VCR vcr_table[0]; /**< Array of virtual connection references */
- *new_vcr = orig_vcr;
- return MPI_SUCCESS;
+ ((MPIDI_VCR*)new_vcr)[new_index] = MPID_VCR_GET_LPID(orig_vcr, origin_index);
+ return MPI_SUCCESS;
- *lpid_ptr = (int)vcr;
+ *lpid_ptr = MPID_VCR_GET_LPID(vcr, index);
int MPID_VCRT_Create(int size, MPID_VCRT *vcrt_ptr)
@@ -38,7 +38,7 @@ int MPID_VCRT_Create(int size, MPID_VCRT *vcrt_ptr)
struct MPIDI_VCRT * vcrt;
int result;
- vcrt = MPIU_Malloc(sizeof(struct MPIDI_VCRT) + size*sizeof(MPID_VCR));
+ vcrt = MPIU_Malloc(sizeof(struct MPIDI_VCRT) + size*sizeof(MPIDI_VCR));
if (vcrt != NULL)
MPIU_Object_set_ref(vcrt, 1);
1.7.2.2
More information about the mpich2-dev
