[mpich2-dev] MPE and C++: 'mpi.h' is being #include'd inside a extern "C" { } block
Anthony Chan
chan at mcs.anl.gov
Tue Nov 17 18:26:01 CST 2009
The issue has been filed:
https://trac.mcs.anl.gov/projects/mpich2/ticket/941
and will be resolved through TRAC.
A.Chan
----- "Lisandro Dalcin" <dalcinl at gmail.com> wrote:
> If you try to compile the lines below using the 'mpicxx' (i.e. C++
> compiler wrapper) it fails.
> #include <stdlib.h>
> #include <mpe.h>
> int main(int n, char**v) { return 0; }
> This happens because "mpi.h" end-up being #include'd inside a extern
> "C" { } block, and that is obviously wrong for the C++ bindings.
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
More information about the mpich2-dev
