[mpich2-dev] MPE and C++: 'mpi.h' is being #include'd inside a	extern "C" { } block
    Lisandro Dalcin
    dalcinl at gmail.com
    Tue Nov 17 13:52:38 CST 2009
If you try to compile the lines below using the 'mpicxx' (i.e. C++
compiler wrapper) it fails.
#include <stdlib.h>
#include <mpe.h>
int main(int n, char**v) { return 0; }
This happens because "mpi.h" end-up being #include'd inside a extern
"C" { } block, and that is obviously wrong for the C++ bindings.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
More information about the mpich2-dev
