[mpich2-dev] problem with resized mpich2 test
Rajeev Thakur thakur at mcs.anl.gov
Tue May 12 10:49:45 CDT 2009
Alexey,
            This was discussed last month on the list. See the thread with
the subject "Update resized.c code to match the comments" at
http://lists.mcs.anl.gov/pipermail/mpich2-dev/2009-April/thread.html . The
test is right and the ROMIO code was fixed for it last summer. The above
thread has the svn version numbers for the changes.
Raejev
  _____
From: mpich2-dev-bounces at mcs.anl.gov [mailto:mpich2-dev-bounces at mcs.anl.gov]
On Behalf Of Ryzhykh, Alexey
Sent: Tuesday, May 12, 2009 7:30 AM
To: mpich2-dev at mcs.anl.gov
Cc: Voronov, German; Truschin, Vladimir
Subject: [mpich2-dev] problem with resized mpich2 test
I am working   in Intel MPI project.
Our testing constantly shows   the failure of  resized  test from
mpich2-test/mpi/io on different platforms.
The test output is:
 newbuf[0] is 20, should be 10,
 newbuf[1] is 55, should be 55,
 newbuf[2] is 55, should be 55,
 newbuf[3] is 55, should be 20
 Found 1 errors
The bug is reproduced with mpich2 1.1 beta.
The reason of bug is wrong file offsets generated for file view based on
resized data type.
Could you please help to solve the problem?
With best regards,
Alexey Ryzhykh,
Intel, Sarov
Closed Joint Stock Company Intel A/O
Registered legal address: Krylatsky Hills Business Park,
17 Krylatskaya Str., Bldg 4, Moscow 121614,
Russian Federation
This e-mail and any attachments may contain confidential material for
the sole use of the intended recipient(s). Any review or distribution
by others is strictly prohibited. If you are not the intended
recipient, please contact the sender and delete all copies.
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20090512/bab28186/attachment.htm>
More information about the mpich2-dev mailing list
