[mpich2-dev] problem with resized mpich2 test
Ryzhykh, Alexey alexey.ryzhykh at intel.com
Tue May 12 07:29:48 CDT 2009
I am working   in Intel MPI project.
Our testing constantly shows   the failure of  resized  test from mpich2-test/mpi/io on different platforms.
The test output is:
 newbuf[0] is 20, should be 10,
 newbuf[1] is 55, should be 55,
 newbuf[2] is 55, should be 55,
 newbuf[3] is 55, should be 20
 Found 1 errors
The bug is reproduced with mpich2 1.1 beta.
The reason of bug is wrong file offsets generated for file view based on resized data type.
Could you please help to solve the problem?
With best regards,
Alexey Ryzhykh,
Intel, Sarov
Closed Joint Stock Company Intel A/O
Registered legal address: Krylatsky Hills Business Park,
17 Krylatskaya Str., Bldg 4, Moscow 121614,
Russian Federation
This e-mail and any attachments may contain confidential material for
the sole use of the intended recipient(s). Any review or distribution
by others is strictly prohibited. If you are not the intended
recipient, please contact the sender and delete all copies.
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090512/de65aa77/attachment.htm>
More information about the mpich2-dev mailing list
