[mpich2-dev] Problem with MPI_Type_commit() and assert in segment_ops.c
Rob Ross
rross at mcs.anl.gov
Tue Jun 9 15:50:48 CDT 2009
Those type casts to (size_t) should be to (MPI_Aint).
That assertion is checking that a parameter being passed to
Segment_mpi_flatten is > 0. The parameter is the length of the list of
regions being passed in by reference to be filled in (the destination
of the list of regions). So for some reason we're getting a zero (or
possibly negative) value passed in as the length of the arrays.
There's only one place in the struct creation where
Segment_mpi_flatten() is called; it's line 666 (evil!) of
dataloop_create_struct.c. This is in
DLOOP_Dataloop_create_flattened_struct(), which is a function used to
make a struct into an indexed type.
The "pairtypes", such as MPI_SHORT_INT, are special cases in MPI in
that some of them have more than one "element type" (e.g. MPI_INT,
MPI_SHORT_INT) in them. My guess is that there's an assumption in the
DLOOP_Dataloop_create_flattened_struct() code path that is having
trouble with the pairtype.
I'm surprised that we might have introduced something between 1.0.7
and 1.1; I can't recall anything in particular that has changed in
this code path. Someone should check the repo logs and see if
something snuck in?
Rob
On Jun 9, 2009, at 3:13 PM, Joe Ratterman wrote:
> The specifics of this test come from an MPI excerciser that gathered
> (using MPIR_Gather) a variety of types, including MPI_SHORT_INT.
> The way that gather is implemented, it created and then sent a
> struct datatype of the tmp-data from the software tree and the local-
> data. I pulled out the important bits, and got this test-case. It
> asserts on PPC32 Linux 1.1 and BGP 1.1rc0, but runs fine on 1.0.7.
> The addresses/displacements are fake, but were originally based on
> the actual values used inside MPIR_Gather. It does the type-create
> on the first two types just to show that it doesn't always fail.
> Error message:
> Creating addr=[0x1,0x2] types=[8c000003,4c00010d]
> struct_displs=[1,2] blocks=[256,256] MPI_BOTTOM=(nil)
> foo:25
> Assertion failed in file segment_ops.c at line 994: *lengthp > 0
> internal ABORT - process 0
> Code
> #include <stdio.h>
> #include <stdlib.h>
> #include <unistd.h>
> #include <mpi.h>
> void foo(void *sendbuf,
> MPI_Datatype sendtype,
> void *recvbuf,
> MPI_Datatype recvtype)
> int blocks[2];
> MPI_Aint struct_displs[2];
> MPI_Datatype types[2], tmp_type;
> blocks[0] = 256;
> struct_displs[0] = (size_t)sendbuf;
> types[0] = sendtype;
> blocks[1] = 256;
> struct_displs[1] = (size_t)recvbuf;
> types[1] = MPI_BYTE;
> printf("Creating addr=[%p,%p] types=[%x,%x] struct_displs=[%x,
> %x] blocks=[%d,%d] MPI_BOTTOM=%p\n",
> sendbuf, recvbuf, types[0], types[1], struct_displs[0],
> struct_displs[1], blocks[0], blocks[1], MPI_BOTTOM);
> MPI_Type_create_struct(2, blocks, struct_displs, types, &tmp_type);
> printf("%s:%d\n", __func__, __LINE__);
> MPI_Type_commit(&tmp_type);
> MPI_Type_free (&tmp_type);
> puts("Done");
> int main()
> MPI_Init(NULL, NULL);
> foo((void*)0x1,
> MPI_FLOAT_INT,
> (void*)0x2,
> MPI_BYTE);
> sleep(1);
> foo((void*)0x1,
> MPI_DOUBLE_INT,
> (void*)0x2,
> MPI_BYTE);
> sleep(1);
> foo((void*)0x1,
> MPI_SHORT_INT,
> (void*)0x2,
> MPI_BYTE);
> MPI_Finalize();
> return 0;
> I don't know anything about how this might be fixed, but we are
> looking into it as well.
> Thanks,
> Joe Ratterman
> jratt at us.ibm.com
More information about the mpich2-dev
