[mpich2-dev] Problem with MPI_Type_commit() and assert in segment_ops.c
Joe Ratterman
jratt0 at gmail.com
Tue Jun 9 15:13:34 CDT 2009
The specifics of this test come from an MPI excerciser that gathered (using
MPIR_Gather) a variety of types, including MPI_SHORT_INT. The way that
gather is implemented, it created and then sent a struct datatype of the
tmp-data from the software tree and the local-data. I pulled out the
important bits, and got this test-case. It asserts on PPC32 Linux 1.1 and
BGP 1.1rc0, but runs fine on 1.0.7. The addresses/displacements are fake,
but were originally based on the actual values used inside MPIR_Gather. It
does the type-create on the first two types just to show that it doesn't
always fail.
Error message:
Creating addr=[0x1,0x2] types=[8c000003,4c00010d] struct_displs=[1,2]
blocks=[256,256] MPI_BOTTOM=(nil)
foo:25
Assertion failed in file segment_ops.c at line 994: *lengthp > 0
internal ABORT - process 0
Code
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <mpi.h>
void foo(void *sendbuf,
MPI_Datatype sendtype,
void *recvbuf,
MPI_Datatype recvtype)
int blocks[2];
MPI_Aint struct_displs[2];
MPI_Datatype types[2], tmp_type;
blocks[0] = 256;
struct_displs[0] = (size_t)sendbuf;
types[0] = sendtype;
blocks[1] = 256;
struct_displs[1] = (size_t)recvbuf;
types[1] = MPI_BYTE;
printf("Creating addr=[%p,%p] types=[%x,%x] struct_displs=[%x,%x]
blocks=[%d,%d] MPI_BOTTOM=%p\n",
sendbuf, recvbuf, types[0], types[1], struct_displs[0],
struct_displs[1], blocks[0], blocks[1], MPI_BOTTOM);
MPI_Type_create_struct(2, blocks, struct_displs, types, &tmp_type);
printf("%s:%d\n", __func__, __LINE__);
MPI_Type_commit(&tmp_type);
MPI_Type_free (&tmp_type);
puts("Done");
int main()
MPI_Init(NULL, NULL);
foo((void*)0x1,
MPI_FLOAT_INT,
(void*)0x2,
MPI_BYTE);
sleep(1);
foo((void*)0x1,
MPI_DOUBLE_INT,
(void*)0x2,
MPI_BYTE);
sleep(1);
foo((void*)0x1,
MPI_SHORT_INT,
(void*)0x2,
MPI_BYTE);
MPI_Finalize();
return 0;
I don't know anything about how this might be fixed, but we are looking into
it as well.
Joe Ratterman
jratt at us.ibm.com
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20090609/d83c3060/attachment.htm>
More information about the mpich2-dev
