[mpich2-dev] [opa-core] Problem with MPICH2 1.1 during MPI_Init() on PPC Linux 32bit
Darius Buntinas
buntinas at mcs.anl.gov
Tue Jun 9 15:23:10 CDT 2009
I see that there is a comment in opa_gcc_ppc.h that "these need to be
aligned on an 8-byte boundary to work on a BG/P." Do you know if this
is true?
Dave, this looks like your comment. Can you comment?
Should this be changed to "OPA_ATTRIBUTE((aligned (SIZEOF_VOID_P)))" to
handle different pointer sizes (similarly for SIZEOF_INT for ints)?
-d
On 06/09/2009 03:04 PM, Joe Ratterman wrote:
> This is the error I'm seeing:
> Assertion failed in file mpid_nem_init.c at line 89:
> sizeof(MPID_nem_cell_rel_ptr_t) == 4
> This appears to be the important code from the pre-processed version
> of mpid_nem_init.c
> # 11
> "/bglhome/usr1/jratt/src-sles10/mpich2/mpich2-1.1/src/openpa/src/primitives/opa_gcc_ppc.h"
> typedef struct { volatile int v __attribute__ ((aligned (8))); }
> OPA_int_t;
> typedef struct { void * volatile v __attribute__ ((aligned (8))); }
> OPA_ptr_t;
> # 188 "../include/mpid_nem_datatypes.h"
> typedef struct MPID_nem_cell_rel_ptr
> OPA_ptr_t p;
> MPID_nem_cell_rel_ptr_t;
> # 135 mpid/ch3/include/mpidi_ch3_conf.h
> #define SIZEOF_VOID_P 4
> # 85 mpid_nem_init.c
> /* The MPID_nem_cell_rel_ptr_t defined in mpid_nem_datatypes.h
> * should only contain a pointer. Also, we don't support compilers
> * which add random padding to the start of the structure. The
> * below assert should blow up if any of these happens. */
> MPIU_Assert(sizeof(MPID_nem_cell_rel_ptr_t) == SIZEOF_VOID_P);
> Given the above code, the size of that type appears to be 8 in both GCC
> and XLC. I see that the alignment is hard-coded to 8 in
> src/openpa/src/primitives/opa_gcc_ppc.h. Changing that first line to an
> alignment of 4, the type size shrinks to 4 (correspondingly, increasing
> it to 16 increases the type size as well).
> Changing the file to 4 and recompiling things allows a few simple tests
> to work fine--I haven't tried too much more.
> Thanks,
> Joe Ratterman
> jratt at us.ibm.com <mailto:jratt at us.ibm.com>
> opa-core mailing list
> opa-core at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-core
More information about the mpich2-dev
