[mpich2-dev] Problem with MPICH2 1.1 during MPI_Init() on PPC Linux 32bit
Joe Ratterman
jratt0 at gmail.com
Tue Jun 9 15:04:04 CDT 2009
This is the error I'm seeing:
Assertion failed in file mpid_nem_init.c at line 89:
sizeof(MPID_nem_cell_rel_ptr_t) == 4
This appears to be the important code from the pre-processed version
of mpid_nem_init.c
# 11
"/bglhome/usr1/jratt/src-sles10/mpich2/mpich2-1.1/src/openpa/src/primitives/opa_gcc_ppc.h"
typedef struct { volatile int v __attribute__ ((aligned (8))); } OPA_int_t;
typedef struct { void * volatile v __attribute__ ((aligned (8))); }
OPA_ptr_t;
# 188 "../include/mpid_nem_datatypes.h"
typedef struct MPID_nem_cell_rel_ptr
OPA_ptr_t p;
MPID_nem_cell_rel_ptr_t;
# 135 mpid/ch3/include/mpidi_ch3_conf.h
#define SIZEOF_VOID_P 4
# 85 mpid_nem_init.c
/* The MPID_nem_cell_rel_ptr_t defined in mpid_nem_datatypes.h
* should only contain a pointer. Also, we don't support compilers
* which add random padding to the start of the structure. The
* below assert should blow up if any of these happens. */
MPIU_Assert(sizeof(MPID_nem_cell_rel_ptr_t) == SIZEOF_VOID_P);
Given the above code, the size of that type appears to be 8 in both GCC and
XLC. I see that the alignment is hard-coded to 8 in
src/openpa/src/primitives/opa_gcc_ppc.h. Changing that first line to an
alignment of 4, the type size shrinks to 4 (correspondingly, increasing it
to 16 increases the type size as well).
Changing the file to 4 and recompiling things allows a few simple tests to
work fine--I haven't tried too much more.
Joe Ratterman
jratt at us.ibm.com
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20090609/501fbf36/attachment.htm>
More information about the mpich2-dev
