[mpich2-dev] [mpich-discuss] Overflow in MPI_Aint
Pavan Balaji
balaji at mcs.anl.gov
Thu Jul 23 13:07:06 CDT 2009
Hi Joe,
I tried to extract the code change portions from the patch you sent, but
that doesn't seem to be easy (the patch seems to show many changes to
the docs and other such files which have not changed for a long time).
Is there a way for me to get the code changes, either from this patch,
or by exporting from some git branch?
-- Pavan
On 07/21/2009 03:38 PM, Pavan Balaji wrote:
> Joe,
>> There are a number of MPI_Aint changes that are not in 1.1. For
>> example, there is a block of changes in configure.in that relates to
>> this, and it is only in the BGP version.
> I'm shifting this part of the discussion to mpich2-dev, since it's more
> developer oriented.
> In the top-level configure, the MPIR_Pint stuff should be in 1.1.1. With
> respect to the MPI_OFFSET_TYPE part, is there a need for this? This is
> cross-compile safe, as far as I can tell (there have been some cleanups
> in the trunk, but this part should be correct even in 1.1). Could you
> explain this a bit more?
> With respect to the rest of the patch, a lot of it seems to be based on:
> 1. git-svn differences (e.g., .gitignore files).
> 2. variables that are automatically filled in by svn (e.g., $Revision$).
> 3. changes in the test suite.
> Apart from these, I do see a few more changes that need to be
> integrated. The dcmfd changes should be easy enough to integrate. I'll
> look into the top-level changes as well.
> -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-dev
