[mpich2-dev] [mpich-discuss] Overflow in MPI_Aint
Pavan Balaji balaji at mcs.anl.gov
Tue Jul 21 15:38:41 CDT 2009
Joe,
> There are a number of MPI_Aint changes that are not in 1.1.  For
> example, there is a block of changes in configure.in that relates to
> this, and it is only in the BGP version.
I'm shifting this part of the discussion to mpich2-dev, since it's more
developer oriented.
In the top-level configure, the MPIR_Pint stuff should be in 1.1.1. With
respect to the MPI_OFFSET_TYPE part, is there a need for this? This is
cross-compile safe, as far as I can tell (there have been some cleanups
in the trunk, but this part should be correct even in 1.1). Could you
explain this a bit more?
With respect to the rest of the patch, a lot of it seems to be based on:
1. git-svn differences (e.g., .gitignore files).
2. variables that are automatically filled in by svn (e.g., $Revision$).
3. changes in the test suite.
Apart from these, I do see a few more changes that need to be
integrated. The dcmfd changes should be easy enough to integrate. I'll
look into the top-level changes as well.
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-dev mailing list
