[mpich2-dev] A Question about romio-hints.
Rob Latham
robl at mcs.anl.gov
Mon Apr 27 16:00:51 CDT 2009
On Sun, Apr 26, 2009 at 08:30:59PM +0900, "Kwangho CHA" wrote:
> Dear All.
> I've interested in the effect of the aggregators in collective I/O
> and tried to change aggregator nodes using "/etc/romio-hints" file.
Great! I'm happy to see someone else using that feature.
> However, my MPI program was terminated abnormally, when I described
> "/etc/romio-hints", as follow;
> cb_config_list compute-0-0.local,compute-0-1.local,compute-0-2.local,compute-0-3.local
> Instead of this line, I also described "cb_config_list *:1", but it
> showed the same result.
> When I comment out the line of the romio-hints file, my MPI program
> works well.
> What should I check first?
When you say 'terminated abnormally', what happens? Does it dump
core? Does it exhibit incorrect behavior? How sophisticated a test
program do I need to reproduce this? Do any of the tests in
romio/test show the problem?
> My system consists of mpich2-1.0.8p1 and pvfs-2.8.1.
I may have fixed this in SVN. Can you either try with the 1.1b1
version or apply the attached patch to your tree?
Thanks
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
Type: text/x-diff
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/mpich2-dev/attachments/20090427/7739b8e0/attachment.bin>
More information about the mpich2-dev
