[mpich2-dev] I would like to ask a question about the mpibzip2
Darius Buntinas
buntinas at mcs.anl.gov
Fri Apr 3 10:03:54 CDT 2009
the -c flag to the compiler specifies that linking step should not be
done and to instead generate an object file. To generate an executable,
remove the -c flag.
Also, I see that you're compiling a c++ file (.cpp). You should use the
mpicxx compiler wrapper instead. Finally, when you use an mpi compiler
wrapper (like mpicc or mpicxx, etc), you don't need the -lmpi flag. The
compiler wrapper adds the necessary flags for mpi.
-d
On 04/02/2009 11:46 PM, 陈炜钊 wrote:
> Hello
> I would like to ask a question about the mpich2. When I use mpibzip2,
> Makefile of mpibzip2 told me to use this parameter -lmpi. but the
> linux prompted the error mpicpp. I would like to ask how I can let my
> mpich2 to use this parameter -lmpi. Error as follows
> [nisuser1 at master mpibzip2-0.6]$ ls
> AUTHORS ChangeLog COPYING Makefile Makefile~ MakefileBak
> mpibzip2.1 mpibzip2.cpp mybin README README~
> [nisuser1 at master mpibzip2-0.6]$ mpicc -c -O2 -o mpibzip2 mpibzip2.cpp
> -lbz2 -lmpi -lpthread
> gcc: -lbz2: linker input file unused because linking not done
> gcc: -lmpi: linker input file unused because linking not done
> gcc: -lpthread: linker input file unused because linking not done
> [nisuser1 at master mpibzip2-0.6]$ mpich2version
> MPICH2 Version: 1.0.8
> MPICH2 Release date: Unknown, built on Mon Mar 9 08:21:54 CST 2009
> MPICH2 Device: ch3:sock
> MPICH2 configure: --prefix=/opt/mpich2
> MPICH2 CC: gcc -O2
> MPICH2 CXX: c++ -O2
> MPICH2 F77: gfortran -O2
> MPICH2 F90: f95 -O2
> 我的主页:www.jetstudio.cn
> 我的blog:blog.jetstudio.cn
> 邮箱发送时间2009年4月3日
More information about the mpich2-dev
