[mpich2-dev] [PATCH 2/2] Issue 4920: Rename and Move MPI_Pint and Related MPI_Aint Casting Macros
Jeff Parker
jjparker at us.ibm.com
Fri May 16 07:24:50 CDT 2008
This patch is intended to be applied together with PATCH 1/2 and on top of the
already-submitted "MPI_Aint on 32-bit platform" patches.
Refer to PATCH 1/2 for further details.
Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
mpich2/src/binding/f77/buildiface | 12 ++--
mpich2/src/mpe2/src/logging/src/clog_commset.c | 4 +-
mpich2/src/mpi/attr/attrutil.c | 12 ++--
mpich2/src/mpi/attr/win_get_attr.c | 2 +-
mpich2/src/mpi/coll/allgather.c | 2 +-
mpich2/src/mpi/coll/alltoall.c | 4 +-
mpich2/src/mpi/coll/alltoallv.c | 8 +-
mpich2/src/mpi/coll/gather.c | 8 +-
mpich2/src/mpi/coll/gatherv.c | 8 +-
mpich2/src/mpi/coll/scatter.c | 4 +-
mpich2/src/mpi/coll/scatterv.c | 2 +-
mpich2/src/mpi/datatype/address.c | 4 +-
mpich2/src/mpi/datatype/get_address.c | 4 +-
mpich2/src/mpi/datatype/pack.c | 2 +-
mpich2/src/mpi/datatype/pack_external.c | 4 +-
mpich2/src/mpi/datatype/type_create_hvector.c | 2 +-
mpich2/src/mpi/datatype/type_create_resized.c | 4 +-
mpich2/src/mpi/datatype/type_hvector.c | 2 +-
mpich2/src/mpi/datatype/unpack.c | 2 +-
mpich2/src/mpi/datatype/unpack_external.c | 4 +-
mpich2/src/mpi/rma/accumulate.c | 2 +-
mpich2/src/mpi/rma/alloc_mem.c | 2 +-
mpich2/src/mpi/rma/get.c | 2 +-
mpich2/src/mpi/rma/put.c | 2 +-
mpich2/src/mpi/rma/win_create.c | 2 +-
mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c | 32 +++++-----
mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_rdcoll.c | 6 +-
mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_wrcoll.c | 4 +-
mpich2/src/mpi/romio/adio/common/ad_read_coll.c | 6 +-
.../src/mpi/romio/adio/common/ad_read_str_naive.c | 6 +-
mpich2/src/mpi/romio/adio/common/ad_write_coll.c | 4 +-
mpich2/src/mpi/romio/adio/common/ad_write_nolock.c | 2 +-
.../src/mpi/romio/adio/common/ad_write_str_naive.c | 6 +-
mpich2/src/mpi/romio/adio/include/adioi.h | 6 +-
.../src/mpid/common/datatype/dataloop/dataloop.c | 60 ++++++++--------
.../datatype/dataloop/dataloop_create_pairtype.c | 2 +-
.../datatype/dataloop/dataloop_create_struct.c | 2 +-
.../mpid/common/datatype/dataloop/segment_ops.c | 70 ++++++++++----------
mpich2/src/mpid/common/datatype/dataloop/veccpy.h | 12 ++--
mpich2/src/mpid/common/datatype/mpid_segment.c | 16 ++--
.../common/datatype/mpid_type_create_pairtype.c | 2 +-
.../dcmfd/src/coll/allgather/mpido_allgather.c | 8 +-
.../dcmfd/src/coll/allgatherv/mpido_allgatherv.c | 8 +-
.../dcmfd/src/coll/allreduce/mpido_allreduce.c | 4 +-
.../mpid/dcmfd/src/coll/alltoall/mpido_alltoall.c | 4 +-
.../dcmfd/src/coll/alltoallv/mpido_alltoallv.c | 4 +-
.../dcmfd/src/coll/alltoallw/mpido_alltoallw.c | 4 +-
mpich2/src/mpid/dcmfd/src/coll/bcast/mpido_bcast.c | 2 +-
.../src/mpid/dcmfd/src/coll/gather/mpido_gather.c | 4 +-
.../src/mpid/dcmfd/src/coll/reduce/mpido_reduce.c | 4 +-
.../src/coll/reduce_scatter/mpido_reduce_scatter.c | 2 +-
.../mpid/dcmfd/src/coll/scatter/mpido_scatter.c | 4 +-
.../mpid/dcmfd/src/coll/scatterv/mpido_scatterv.c | 4 +-
53 files changed, 196 insertions(+), 196 deletions(-)
diff --git a/mpich2/src/binding/f77/buildiface b/mpich2/src/binding/f77/buildiface
index b140983..2a6e705 100755
--- a/mpich2/src/binding/f77/buildiface
+++ b/mpich2/src/binding/f77/buildiface
@@ -1388,7 +1388,7 @@ sub addrint_in_decl {
sub addrint_in_arg {
my $count = $_[0];
- print $OUTFD "MPI_AINT_CAST_TO_VOID_PTR(MPI_Aint)((int)*(int *)v$count)";
+ print $OUTFD "MPIR_MPI_AINT_CAST_TO_VOID_PTR(MPI_Aint)((int)*(int *)v$count)";
sub attrint_ctof {
@@ -1402,7 +1402,7 @@ sub attrint_ctof {
*(MPI_Fint*)$cvar = 0;
else {
- *(MPI_Fint*)$cvar = (MPI_Fint)MPI_VOID_PTR_CAST_TO_MPI_AINT attr$cvar;
+ *(MPI_Fint*)$cvar = (MPI_Fint)MPIR_VOID_PTR_CAST_TO_MPI_AINT attr$cvar;
}\n";
@@ -1428,7 +1428,7 @@ sub addraint_in_decl {
sub addraint_in_arg {
my $count = $_[0];
- print $OUTFD "MPI_AINT_CAST_TO_VOID_PTR(MPI_Aint)((MPI_Aint)*(MPI_Aint *)v$count)";
+ print $OUTFD "MPIR_MPI_AINT_CAST_TO_VOID_PTR(MPI_Aint)((MPI_Aint)*(MPI_Aint *)v$count)";
sub attraint_ctof {
@@ -1440,7 +1440,7 @@ sub attraint_ctof {
*(MPI_Aint*)$cvar = 0;
else {
- *(MPI_Aint*)$cvar = MPI_VOID_PTR_CAST_TO_MPI_AINT attr$cvar;
+ *(MPI_Aint*)$cvar = MPIR_VOID_PTR_CAST_TO_MPI_AINT attr$cvar;
}\n";
@@ -2632,7 +2632,7 @@ FORT_DLL_SPEC void FORT_CALL mpirinitc2_( char *a FORT_MIXED_LEN(d1)
#ifdef USE_POINTER_FOR_BOTTOM
b = a;
#else
- b = a - MPI_VOID_PTR_CAST_TO_MPI_AINT MPIR_F_MPI_BOTTOM;
+ b = a - MPIR_VOID_PTR_CAST_TO_MPI_AINT MPIR_F_MPI_BOTTOM;
#endif
*v2 = (MPI_Fint)( b );
#ifdef HAVE_AINT_LARGER_THAN_FINT
@@ -2671,7 +2671,7 @@ FORT_DLL_SPEC void FORT_CALL mpirinitc2_( char *a FORT_MIXED_LEN(d1)
&specialInitStatement( $OUTFD );
print $OUTFD "\
#ifndef USE_POINTER_FOR_BOTTOM
- a = a - MPI_VOID_PTR_CAST_TO_MPI_AINT MPIR_F_MPI_BOTTOM;
+ a = a - MPIR_VOID_PTR_CAST_TO_MPI_AINT MPIR_F_MPI_BOTTOM;
#endif
*v2 = a;
}\n";
diff --git a/mpich2/src/mpe2/src/logging/src/clog_commset.c b/mpich2/src/mpe2/src/logging/src/clog_commset.c
index 09711f7..3414a29 100644
--- a/mpich2/src/mpe2/src/logging/src/clog_commset.c
+++ b/mpich2/src/mpe2/src/logging/src/clog_commset.c
@@ -303,7 +303,7 @@ const CLOG_CommIDs_t *CLOG_CommSet_add_intracomm( CLOG_CommSet_t *commset,
/* Set the input MPI_Comm's LID_key attribute with new local CommID's LID */
PMPI_Comm_set_attr( intracomm, commset->LID_key,
- MPI_AINT_CAST_TO_VOID_PTR (MPI_Aint) intracommIDs->local_ID );
+ MPIR_MPI_AINT_CAST_TO_VOID_PTR (MPI_Aint) intracommIDs->local_ID );
/* Set the Comm field */
intracommIDs->comm = intracomm;
@@ -358,7 +358,7 @@ CLOG_CommSet_add_intercomm( CLOG_CommSet_t *commset,
/* Set the input MPI_Comm's LID_key attribute with new local CommID */
PMPI_Comm_set_attr( intercomm, commset->LID_key,
- MPI_AINT_CAST_TO_VOID_PTR (MPI_Aint) intercommIDs->local_ID );
+ MPIR_MPI_AINT_CAST_TO_VOID_PTR (MPI_Aint) intercommIDs->local_ID );
/* Set the Comm field with the intercomm's info */
intercommIDs->comm = intercomm;
diff --git a/mpich2/src/mpi/attr/attrutil.c b/mpich2/src/mpi/attr/attrutil.c
index 99497b5..c3b314c 100644
--- a/mpich2/src/mpi/attr/attrutil.c
+++ b/mpich2/src/mpi/attr/attrutil.c
@@ -119,7 +119,7 @@ int MPIR_Call_attr_delete( int handle, MPID_Attribute *attr_p )
are MPI_Fint values, and we assume
sizeof(MPI_Fint) <= sizeof(MPI_Aint).
See also src/binding/f77/attr_getf.c . */
- fvalue = (MPI_Fint) MPI_VOID_PTR_CAST_TO_MPI_AINT (attr_p->value);
+ fvalue = (MPI_Fint) MPIR_VOID_PTR_CAST_TO_MPI_AINT (attr_p->value);
fextra = (MPI_Fint*) (attr_p->keyval->extra_state);
delfn.F77_DeleteFunction( &fhandle, &fkeyval, &fvalue,
fextra, &ierr );
@@ -141,7 +141,7 @@ int MPIR_Call_attr_delete( int handle, MPID_Attribute *attr_p )
if (delfn.F90_DeleteFunction) {
fhandle = (MPI_Fint) (handle);
fkeyval = (MPI_Fint) (attr_p->keyval->handle);
- fvalue = MPI_VOID_PTR_CAST_TO_MPI_AINT (attr_p->value);
+ fvalue = MPIR_VOID_PTR_CAST_TO_MPI_AINT (attr_p->value);
fextra = (MPI_Aint*) (attr_p->keyval->extra_state );
delfn.F90_DeleteFunction( &fhandle, &fkeyval, &fvalue,
fextra, &ierr );
@@ -241,13 +241,13 @@ int MPIR_Attr_dup_list( int handle, MPID_Attribute *old_attrs,
fkeyval = (MPI_Fint) (p->keyval->handle);
/* The following cast can lose data on systems whose
pointers are longer than integers */
- fvalue = (MPI_Fint) MPI_VOID_PTR_CAST_TO_MPI_AINT (p->value);
+ fvalue = (MPI_Fint) MPIR_VOID_PTR_CAST_TO_MPI_AINT (p->value);
fextra = (MPI_Fint*) (p->keyval->extra_state );
copyfn.F77_CopyFunction( &fhandle, &fkeyval, fextra,
&fvalue, &fnew, &fflag, &ierr );
if (ierr) mpi_errno = (int)ierr;
flag = fflag;
- new_value = MPI_AINT_CAST_TO_VOID_PTR (MPI_Aint) fnew;
+ new_value = MPIR_MPI_AINT_CAST_TO_VOID_PTR (MPI_Aint) fnew;
/* --BEGIN ERROR HANDLING-- */
if (mpi_errno != 0)
@@ -264,13 +264,13 @@ int MPIR_Attr_dup_list( int handle, MPID_Attribute *old_attrs,
MPI_Aint fvalue, fnew, *fextra;
- fvalue = MPI_VOID_PTR_CAST_TO_MPI_AINT (p->value);
+ fvalue = MPIR_VOID_PTR_CAST_TO_MPI_AINT (p->value);
fextra = (MPI_Aint*) (p->keyval->extra_state );
copyfn.F90_CopyFunction( &fhandle, &fkeyval, fextra,
flag = fflag;
- new_value = MPI_AINT_CAST_TO_VOID_PTR fnew;
+ new_value = MPIR_MPI_AINT_CAST_TO_VOID_PTR fnew;
if (mpi_errno != 0)
diff --git a/mpich2/src/mpi/attr/win_get_attr.c b/mpich2/src/mpi/attr/win_get_attr.c
index b862716..7e577fd 100644
--- a/mpich2/src/mpi/attr/win_get_attr.c
+++ b/mpich2/src/mpi/attr/win_get_attr.c
@@ -156,7 +156,7 @@ int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val,
case 2: /* Fortran BASE */
/* The Fortran routine that matches this routine should
provide an address-sized integer, not an MPI_Fint */
- *attr_int = MPI_VOID_PTR_CAST_TO_MPI_AINT (win_ptr->base);
+ *attr_int = MPIR_VOID_PTR_CAST_TO_MPI_AINT (win_ptr->base);
break;
case 4: /* Fortran SIZE */
/* We do not need to copy because we return the value,
diff --git a/mpich2/src/mpi/coll/allgather.c b/mpich2/src/mpi/coll/allgather.c
index b4b8f52..57d7dcd 100644
--- a/mpich2/src/mpi/coll/allgather.c
+++ b/mpich2/src/mpi/coll/allgather.c
@@ -107,7 +107,7 @@ int MPIR_Allgather (
MPID_Datatype_get_size_macro( recvtype, type_size );
/* This is the largest offset we add to recvbuf */
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
(comm_size * recvcount * recvtype_extent));
/* check if comm_size is a power of two */
diff --git a/mpich2/src/mpi/coll/alltoall.c b/mpich2/src/mpi/coll/alltoall.c
index 4e47efb..8ac96ad 100644
--- a/mpich2/src/mpi/coll/alltoall.c
+++ b/mpich2/src/mpi/coll/alltoall.c
@@ -537,10 +537,10 @@ int MPIR_Alltoall_inter(
/* Do the pairwise exchanges */
max_size = MPIR_MAX(local_size, remote_size);
- (MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
max_size*recvcount*recvtype_extent));
- (MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf +
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf +
max_size*sendcount*sendtype_extent));
for (i=0; i<max_size; i++) {
src = (rank - i + max_size) % max_size;
diff --git a/mpich2/src/mpi/coll/alltoallv.c b/mpich2/src/mpi/coll/alltoallv.c
index 4ec5040..792290d 100644
--- a/mpich2/src/mpi/coll/alltoallv.c
+++ b/mpich2/src/mpi/coll/alltoallv.c
@@ -99,7 +99,7 @@ int MPIR_Alltoallv (
dst = (rank+i) % comm_size;
if (recvcnts[dst]) {
MPID_Ensure_Aint_fits_in_pointer((
- MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf + rdispls[dst]*recv_extent));
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf + rdispls[dst]*recv_extent));
mpi_errno = MPIC_Irecv((char *)recvbuf+rdispls[dst]*recv_extent,
recvcnts[dst], recvtype, dst,
MPIR_ALLTOALLV_TAG, comm,
@@ -119,7 +119,7 @@ int MPIR_Alltoallv (
if (sendcnts[dst]) {
- MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf + sdispls[dst]*send_extent));
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf + sdispls[dst]*send_extent));
mpi_errno = MPIC_Isend((char *)sendbuf+sdispls[dst]*send_extent,
sendcnts[dst], sendtype, dst,
@@ -214,7 +214,7 @@ int MPIR_Alltoallv_inter (
else {
MPID_Ensure_Aint_fits_in_pointer ((
- MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf + rdispls[src]*recv_extent));
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf + rdispls[src]*recv_extent));
recvaddr = (char *)recvbuf + rdispls[src]*recv_extent;
recvcount = recvcnts[src];
@@ -225,7 +225,7 @@ int MPIR_Alltoallv_inter (
else {
sendaddr = (char *)sendbuf + sdispls[dst]*send_extent;
sendcount = sendcnts[dst];
diff --git a/mpich2/src/mpi/coll/gather.c b/mpich2/src/mpi/coll/gather.c
index f0e89de..e78d2a4 100644
--- a/mpich2/src/mpi/coll/gather.c
+++ b/mpich2/src/mpi/coll/gather.c
@@ -98,7 +98,7 @@ int MPIR_Gather (
if (rank == root)
MPID_Datatype_get_extent_macro(recvtype, extent);
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf+
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf+
(extent*recvcnt*comm_size));
@@ -256,10 +256,10 @@ int MPIR_Gather (
else {
blocks[0] = sendcnt;
- struct_displs[0] = MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf;
+ struct_displs[0] = MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf;
types[0] = sendtype;
blocks[1] = curr_cnt - nbytes;
- struct_displs[1] = MPI_VOID_PTR_CAST_TO_MPI_AINT tmp_buf;
+ struct_displs[1] = MPIR_VOID_PTR_CAST_TO_MPI_AINT tmp_buf;
types[1] = MPI_BYTE;
NMPI_Type_create_struct(2, blocks, struct_displs, types, &tmp_type);
@@ -547,7 +547,7 @@ int MPIR_Gather_inter (
(recvcnt*remote_size*extent));
for (i=0; i<remote_size; i++)
diff --git a/mpich2/src/mpi/coll/gatherv.c b/mpich2/src/mpi/coll/gatherv.c
index 8a3c3f9..2ee36b3 100644
--- a/mpich2/src/mpi/coll/gatherv.c
+++ b/mpich2/src/mpi/coll/gatherv.c
@@ -73,7 +73,7 @@ int MPIR_Gatherv (
/* each node can make sure it is not going to overflow aint */
- MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf + displs[rank] * extent));
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf + displs[rank] * extent));
for ( i=0; i<root; i++ ) {
if (recvcnts[i]) {
@@ -93,7 +93,7 @@ int MPIR_Gatherv (
if (sendbuf != MPI_IN_PLACE) {
if (recvcnts[rank]) {
- MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf + displs[rank]*extent));
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf + displs[rank]*extent));
mpi_errno = MPIR_Localcopy(sendbuf, sendcnt, sendtype,
((char *)recvbuf+displs[rank]*extent),
recvcnts[rank], recvtype);
@@ -107,7 +107,7 @@ int MPIR_Gatherv (
for ( i=root+1; i<comm_size; i++ ) {
if (recvcnts[i]) {
@@ -132,7 +132,7 @@ int MPIR_Gatherv (
for (i=0; i<remote_comm_size; i++) {
if (recvcnts[i]) {
mpi_errno = MPIC_Recv(((char *)recvbuf+displs[i]*extent),
diff --git a/mpich2/src/mpi/coll/scatter.c b/mpich2/src/mpi/coll/scatter.c
index 937f79d..da28599 100644
--- a/mpich2/src/mpi/coll/scatter.c
+++ b/mpich2/src/mpi/coll/scatter.c
@@ -99,7 +99,7 @@ int MPIR_Scatter (
recvcnt and recvtype are not valid */
MPID_Datatype_get_size_macro(sendtype, sendtype_size);
extent*sendcnt*comm_size));
nbytes = sendtype_size * sendcnt;
@@ -514,7 +514,7 @@ int MPIR_Scatter_inter (
MPID_Ensure_Aint_fits_in_pointer(extent*recvcnt*local_size);
sendcnt*remote_size*extent));
tmp_buf =
diff --git a/mpich2/src/mpi/coll/scatterv.c b/mpich2/src/mpi/coll/scatterv.c
index b60a5c4..5c4ac20 100644
--- a/mpich2/src/mpi/coll/scatterv.c
+++ b/mpich2/src/mpi/coll/scatterv.c
@@ -79,7 +79,7 @@ int MPIR_Scatterv (
* a minimal sanity check. maybe add a global var since we do loop over
* sendcount[] in MPI_Scatterv before calling this*/
- MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf + extent));
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf + extent));
/* We could use Isend here, but since the receivers need to execute
a simple Recv, it may not make much difference in performance,
diff --git a/mpich2/src/mpi/datatype/address.c b/mpich2/src/mpi/datatype/address.c
index 5ce6263..80706c6 100644
--- a/mpich2/src/mpi/datatype/address.c
+++ b/mpich2/src/mpi/datatype/address.c
@@ -88,7 +88,7 @@ int MPI_Address( void *location, MPI_Aint *address )
standard, I can't tell if this is a compiler bug or a language bug.
#ifdef CHAR_PTR_IS_ADDRESS
- *address = MPI_VOID_PTR_CAST_TO_MPI_AINT ((char *)location);
+ *address = MPIR_VOID_PTR_CAST_TO_MPI_AINT ((char *)location);
#else
/* Note that this is the "portable" way to generate an address.
The difference of two pointers is the number of elements
@@ -97,7 +97,7 @@ int MPI_Address( void *location, MPI_Aint *address )
of bytes from 0 to location */
/* To cover the case where a pointer is 32 bits and MPI_Aint is 64 bits,
add cast to unsigned so the high order address bit is not sign-extended. */
- *address = MPI_VOID_PTR_CAST_TO_MPI_AINT ((char *)location - (char *)MPI_BOTTOM);
+ *address = MPIR_VOID_PTR_CAST_TO_MPI_AINT ((char *)location - (char *)MPI_BOTTOM);
#endif
/* The same code is used in MPI_Get_address */
diff --git a/mpich2/src/mpi/datatype/get_address.c b/mpich2/src/mpi/datatype/get_address.c
index 9fdc911..a59eeff 100644
--- a/mpich2/src/mpi/datatype/get_address.c
+++ b/mpich2/src/mpi/datatype/get_address.c
@@ -98,14 +98,14 @@ int MPI_Get_address(void *location, MPI_Aint *address)
#else
between them, so this gives the number of chars between location
and ptr. As long as sizeof(char) represents one byte,
#endif
/* The same code is used in MPI_Address */
diff --git a/mpich2/src/mpi/datatype/pack.c b/mpich2/src/mpi/datatype/pack.c
index d7a27c6..3a247f1 100644
--- a/mpich2/src/mpi/datatype/pack.c
+++ b/mpich2/src/mpi/datatype/pack.c
@@ -191,7 +191,7 @@ int MPI_Pack(void *inbuf,
last = SEGMENT_IGNORE_LAST;
/* Ensure that pointer increment fits in a pointer */
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT outbuf) + (MPI_Aint)*position );
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT outbuf) + (MPI_Aint)*position );
MPID_Segment_pack(segp,
first,
diff --git a/mpich2/src/mpi/datatype/pack_external.c b/mpich2/src/mpi/datatype/pack_external.c
index e794c6a..6dbd570 100644
--- a/mpich2/src/mpi/datatype/pack_external.c
+++ b/mpich2/src/mpi/datatype/pack_external.c
@@ -135,7 +135,7 @@ int MPI_Pack_external(char *datarep,
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT outbuf) + *position );
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT outbuf) + *position );
MPID_Segment_pack_external32(segp,
first,
@@ -159,7 +159,7 @@ int MPI_Pack_external(char *datarep,
mpi_errno = MPIR_Err_create_code(
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_pack_external",
"**mpi_pack_external %s %p %d %D %p %L %p",
- datarep, inbuf, incount, datatype, outbuf, MPI_AINT_CAST_TO_LONG_LONG outcount, position);
+ datarep, inbuf, incount, datatype, outbuf, MPIR_MPI_AINT_CAST_TO_LONG_LONG outcount, position);
# endif
mpi_errno = MPIR_Err_return_comm( 0, FCNAME, mpi_errno );
diff --git a/mpich2/src/mpi/datatype/type_create_hvector.c b/mpich2/src/mpi/datatype/type_create_hvector.c
index 2cfe2da..a35a0c5 100644
--- a/mpich2/src/mpi/datatype/type_create_hvector.c
+++ b/mpich2/src/mpi/datatype/type_create_hvector.c
@@ -125,7 +125,7 @@ int MPI_Type_create_hvector(int count,
MPI_ERR_OTHER, "**mpi_type_create_hvector",
"**mpi_type_create_hvector %d %d %L %D %p", count,
- blocklength, MPI_AINT_CAST_TO_LONG_LONG stride, oldtype, newtype);
+ blocklength, MPIR_MPI_AINT_CAST_TO_LONG_LONG stride, oldtype, newtype);
# endif
mpi_errno = MPIR_Err_return_comm( NULL, FCNAME, mpi_errno );
diff --git a/mpich2/src/mpi/datatype/type_create_resized.c b/mpich2/src/mpi/datatype/type_create_resized.c
index 991fe8d..c8b15c7 100644
--- a/mpich2/src/mpi/datatype/type_create_resized.c
+++ b/mpich2/src/mpi/datatype/type_create_resized.c
@@ -121,8 +121,8 @@ int MPI_Type_create_resized(MPI_Datatype oldtype,
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_type_create_resized",
"**mpi_type_create_resized %D %L %L %p", oldtype,
- MPI_AINT_CAST_TO_LONG_LONG lb,
- MPI_AINT_CAST_TO_LONG_LONG extent,
+ MPIR_MPI_AINT_CAST_TO_LONG_LONG lb,
+ MPIR_MPI_AINT_CAST_TO_LONG_LONG extent,
newtype);
# endif
diff --git a/mpich2/src/mpi/datatype/type_hvector.c b/mpich2/src/mpi/datatype/type_hvector.c
index 8e6f87b..dc40877 100644
--- a/mpich2/src/mpi/datatype/type_hvector.c
+++ b/mpich2/src/mpi/datatype/type_hvector.c
@@ -121,7 +121,7 @@ int MPI_Type_hvector(int count,
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_type_hvector",
"**mpi_type_hvector %d %d %L %D %p", count, blocklen,
- MPI_AINT_CAST_TO_LONG_LONG stride,
+ MPIR_MPI_AINT_CAST_TO_LONG_LONG stride,
old_type, newtype_p);
# endif
diff --git a/mpich2/src/mpi/datatype/unpack.c b/mpich2/src/mpi/datatype/unpack.c
index cfc5048..50c55ce 100644
--- a/mpich2/src/mpi/datatype/unpack.c
+++ b/mpich2/src/mpi/datatype/unpack.c
@@ -134,7 +134,7 @@ int MPI_Unpack(void *inbuf, int insize, int *position,
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT inbuf) + (MPI_Aint)*position );
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT inbuf) + (MPI_Aint)*position );
MPID_Segment_unpack(segp,
first,
diff --git a/mpich2/src/mpi/datatype/unpack_external.c b/mpich2/src/mpi/datatype/unpack_external.c
index 9804cdc..6bea2f7 100644
--- a/mpich2/src/mpi/datatype/unpack_external.c
+++ b/mpich2/src/mpi/datatype/unpack_external.c
@@ -119,7 +119,7 @@ int MPI_Unpack_external(char *datarep,
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT inbuf) + *position );
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT inbuf) + *position );
MPID_Segment_unpack_external32(segp,
first,
@@ -144,7 +144,7 @@ int MPI_Unpack_external(char *datarep,
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_unpack_external",
"**mpi_unpack_external %s %p %L %p %p %d %D", datarep, inbuf,
- MPI_AINT_CAST_TO_LONG_LONG insize,
+ MPIR_MPI_AINT_CAST_TO_LONG_LONG insize,
position, outbuf, outcount, datatype);
# endif
diff --git a/mpich2/src/mpi/rma/accumulate.c b/mpich2/src/mpi/rma/accumulate.c
index d563d8a..b4897a0 100644
--- a/mpich2/src/mpi/rma/accumulate.c
+++ b/mpich2/src/mpi/rma/accumulate.c
@@ -157,7 +157,7 @@ int MPI_Accumulate(void *origin_addr, int origin_count, MPI_Datatype
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_accumulate",
"**mpi_accumulate %p %d %D %d %L %d %D %O %W", origin_addr, origin_count, origin_datatype,
- target_rank, MPI_AINT_CAST_TO_LONG_LONG target_disp, target_count, target_datatype, op, win);
+ target_rank, MPIR_MPI_AINT_CAST_TO_LONG_LONG target_disp, target_count, target_datatype, op, win);
# endif
mpi_errno = MPIR_Err_return_win( win_ptr, FCNAME, mpi_errno );
diff --git a/mpich2/src/mpi/rma/alloc_mem.c b/mpich2/src/mpi/rma/alloc_mem.c
index 330d884..f281bd6 100644
--- a/mpich2/src/mpi/rma/alloc_mem.c
+++ b/mpich2/src/mpi/rma/alloc_mem.c
@@ -113,7 +113,7 @@ int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr)
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_alloc_mem",
- "**mpi_alloc_mem %L %I %p", MPI_AINT_CAST_TO_LONG_LONG size, info, baseptr);
+ "**mpi_alloc_mem %L %I %p", MPIR_MPI_AINT_CAST_TO_LONG_LONG size, info, baseptr);
# endif
diff --git a/mpich2/src/mpi/rma/get.c b/mpich2/src/mpi/rma/get.c
index 71db17b..7c02488 100644
--- a/mpich2/src/mpi/rma/get.c
+++ b/mpich2/src/mpi/rma/get.c
@@ -153,7 +153,7 @@ int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_get", "**mpi_get %p %d %D %d %L %d %D %W",
origin_addr, origin_count, origin_datatype, target_rank,
- MPI_AINT_CAST_TO_LONG_LONG target_disp, target_count, target_datatype, win);
+ MPIR_MPI_AINT_CAST_TO_LONG_LONG target_disp, target_count, target_datatype, win);
# endif
diff --git a/mpich2/src/mpi/rma/put.c b/mpich2/src/mpi/rma/put.c
index 7234b70..ee82f5b 100644
--- a/mpich2/src/mpi/rma/put.c
+++ b/mpich2/src/mpi/rma/put.c
@@ -153,7 +153,7 @@ int MPI_Put(void *origin_addr, int origin_count, MPI_Datatype
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_put", "**mpi_put %p %d %D %d %L %d %D %W",
# endif
diff --git a/mpich2/src/mpi/rma/win_create.c b/mpich2/src/mpi/rma/win_create.c
index a2bc2b1..ba3f556 100644
--- a/mpich2/src/mpi/rma/win_create.c
+++ b/mpich2/src/mpi/rma/win_create.c
@@ -134,7 +134,7 @@ int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info,
mpi_errno, MPIR_ERR_RECOVERABLE, FCNAME, __LINE__, MPI_ERR_OTHER, "**mpi_win_create",
- "**mpi_win_create %p %L %d %I %C %p", base, MPI_AINT_CAST_TO_LONG_LONG size, disp_unit, info, comm, win);
+ "**mpi_win_create %p %L %d %I %C %p", base, MPIR_MPI_AINT_CAST_TO_LONG_LONG size, disp_unit, info, comm, win);
# endif
mpi_errno = MPIR_Err_return_comm( comm_ptr, FCNAME, mpi_errno );
diff --git a/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c b/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c
index 3812bc1..16a2d2c 100644
--- a/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c
+++ b/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_aggrs.c
@@ -886,9 +886,9 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
others_req[i].lens = (int *)
ADIOI_Malloc(count_others_req_per_proc[i]*sizeof(int));
- if ( (MPI_Puint)others_req[i].offsets < (MPI_Puint)recvBufForOffsets )
+ if ( (MPIR_Puint)others_req[i].offsets < (MPIR_Puint)recvBufForOffsets )
recvBufForOffsets = others_req[i].offsets;
- if ( (MPI_Puint)others_req[i].lens < (MPI_Puint)recvBufForLens )
+ if ( (MPIR_Puint)others_req[i].lens < (MPIR_Puint)recvBufForLens )
recvBufForLens = others_req[i].lens;
others_req[i].mem_ptrs = (MPI_Aint *)
@@ -917,11 +917,11 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
for (i=0; i<nprocs; i++)
if ( (my_req[i].count) &&
- ((MPI_Puint)my_req[i].offsets <= (MPI_Puint)sendBufForOffsets) )
+ ((MPIR_Puint)my_req[i].offsets <= (MPIR_Puint)sendBufForOffsets) )
sendBufForOffsets = my_req[i].offsets;
- ((MPI_Puint)my_req[i].lens <= (MPI_Puint)sendBufForLens) )
+ ((MPIR_Puint)my_req[i].lens <= (MPIR_Puint)sendBufForLens) )
sendBufForLens = my_req[i].lens;
@@ -938,9 +938,9 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
sdispls[i] = 0;
else
sdispls[i] = (int)
- ( ( (MPI_Puint)my_req[i].offsets -
- (MPI_Puint)sendBufForOffsets ) /
- (MPI_Puint)sizeof(ADIO_Offset) );
+ ( ( (MPIR_Puint)my_req[i].offsets -
+ (MPIR_Puint)sendBufForOffsets ) /
+ (MPIR_Puint)sizeof(ADIO_Offset) );
// Receive these offsets from process i.
rcounts[i] = count_others_req_per_proc[i];
@@ -948,9 +948,9 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
rdispls[i] = 0;
else
rdispls[i] = (int)
- ( ( (MPI_Puint)others_req[i].offsets -
- (MPI_Puint)recvBufForOffsets ) /
+ ( ( (MPIR_Puint)others_req[i].offsets -
+ (MPIR_Puint)recvBufForOffsets ) /
/* Exchange the offsets */
@@ -972,9 +972,9 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
sdispls[i] = 0;
else
sdispls[i] = (int)
- ( ( (MPI_Puint)my_req[i].lens -
- (MPI_Puint)sendBufForLens ) /
- (MPI_Puint) sizeof(int) );
+ ( ( (MPIR_Puint)my_req[i].lens -
+ (MPIR_Puint)sendBufForLens ) /
+ (MPIR_Puint) sizeof(int) );
@@ -982,9 +982,9 @@ void ADIOI_BGL_Calc_others_req(ADIO_File fd, int count_my_req_procs,
rdispls[i] = 0;
else
rdispls[i] = (int)
- ( ( (MPI_Puint)others_req[i].lens -
- (MPI_Puint)recvBufForLens ) /
+ ( ( (MPIR_Puint)others_req[i].lens -
+ (MPIR_Puint)recvBufForLens ) /
/* Exchange the lengths */
diff --git a/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_rdcoll.c b/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_rdcoll.c
index e9c834f..ee7d8bb 100644
--- a/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_rdcoll.c
+++ b/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_rdcoll.c
@@ -587,7 +587,7 @@ static void ADIOI_Read_and_exch(ADIO_File fd, void *buf, MPI_Datatype
if (req_off < real_off + real_size) {
count[i]++;
- ADIOI_Assert((((ADIO_Offset)(MPI_Puint)read_buf)+req_off-real_off) == (ADIO_Offset)(MPI_Puint)(read_buf+req_off-real_off));
+ ADIOI_Assert((((ADIO_Offset)(MPIR_Puint)read_buf)+req_off-real_off) == (ADIO_Offset)(MPIR_Puint)(read_buf+req_off-real_off));
MPI_Address(read_buf+req_off-real_off,
&(others_req[i].mem_ptrs[j]));
ADIOI_Assert((real_off + real_size - req_off) == (int)(real_off + real_size - req_off));
@@ -668,7 +668,7 @@ static void ADIOI_Read_and_exch(ADIO_File fd, void *buf, MPI_Datatype
if (for_next_iter) {
tmp_buf = (char *) ADIOI_Malloc(for_next_iter);
- ADIOI_Assert((((ADIO_Offset)(MPI_Puint)read_buf)+real_size-for_next_iter) == (ADIO_Offset)(MPI_Puint)(read_buf+real_size-for_next_iter));
+ ADIOI_Assert((((ADIO_Offset)(MPIR_Puint)read_buf)+real_size-for_next_iter) == (ADIO_Offset)(MPIR_Puint)(read_buf+real_size-for_next_iter));
ADIOI_Assert((for_next_iter+coll_bufsize) == (size_t)(for_next_iter+coll_bufsize));
memcpy(tmp_buf, read_buf+real_size-for_next_iter, for_next_iter);
ADIOI_Free(read_buf);
@@ -888,7 +888,7 @@ static void ADIOI_Fill_user_buffer(ADIO_File fd, void *buf, ADIOI_Flatlist_node
while (size) { \
size_in_buf = ADIOI_MIN(size, flat_buf_sz); \
- ADIOI_Assert((((ADIO_Offset)(MPI_Puint)buf) + user_buf_idx) == (ADIO_Offset)(MPI_Puint)(buf + user_buf_idx)); \
+ ADIOI_Assert((((ADIO_Offset)(MPIR_Puint)buf) + user_buf_idx) == (ADIO_Offset)(MPIR_Puint)(buf + user_buf_idx)); \
ADIOI_Assert(size_in_buf == (size_t)size_in_buf); \
memcpy(((char *) buf) + user_buf_idx, \
&(recv_buf[p][recv_buf_idx[p]]), size_in_buf); \
diff --git a/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_wrcoll.c b/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_wrcoll.c
index f79ed35..12d22f4 100644
--- a/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_wrcoll.c
+++ b/mpich2/src/mpi/romio/adio/ad_bgl/ad_bgl_wrcoll.c
@@ -552,7 +552,7 @@ static void ADIOI_Exch_and_write(ADIO_File fd, void *buf, MPI_Datatype
if (req_off < off + size) {
count[i]++;
- ADIOI_Assert((((ADIO_Offset)(MPI_Puint)write_buf)+req_off-off) == (ADIO_Offset)(MPI_Puint)(write_buf+req_off-off));
+ ADIOI_Assert((((ADIO_Offset)(MPIR_Puint)write_buf)+req_off-off) == (ADIO_Offset)(MPIR_Puint)(write_buf+req_off-off));
MPI_Address(write_buf+req_off-off,
ADIOI_Assert((off + size - req_off) == (int)(off + size - req_off));
@@ -935,7 +935,7 @@ static void ADIOI_W_Exchange_data(ADIO_File fd, void *buf, char *write_buf,
while (size) { \
memcpy(&(send_buf[p][send_buf_idx[p]]), \
((char *) buf) + user_buf_idx, size_in_buf); \
diff --git a/mpich2/src/mpi/romio/adio/common/ad_read_coll.c b/mpich2/src/mpi/romio/adio/common/ad_read_coll.c
index c6bd6e5..f5220a9 100644
--- a/mpich2/src/mpi/romio/adio/common/ad_read_coll.c
+++ b/mpich2/src/mpi/romio/adio/common/ad_read_coll.c
@@ -665,7 +665,7 @@ static void ADIOI_Read_and_exch(ADIO_File fd, void *buf, MPI_Datatype
count[i]++;
@@ -718,7 +718,7 @@ static void ADIOI_Read_and_exch(ADIO_File fd, void *buf, MPI_Datatype
@@ -918,7 +918,7 @@ static void ADIOI_Fill_user_buffer(ADIO_File fd, void *buf, ADIOI_Flatlist_node
while (size) { \
diff --git a/mpich2/src/mpi/romio/adio/common/ad_read_str_naive.c b/mpich2/src/mpi/romio/adio/common/ad_read_str_naive.c
index b377d96..be6c192 100644
--- a/mpich2/src/mpi/romio/adio/common/ad_read_str_naive.c
+++ b/mpich2/src/mpi/romio/adio/common/ad_read_str_naive.c
@@ -81,7 +81,7 @@ void ADIOI_GEN_ReadStrided_naive(ADIO_File fd, void *buf, int count,
req_off = off;
req_len = flat_buf->blocklens[b_index];
- ADIOI_Assert((((ADIO_Offset)(MPI_Puint)buf) + userbuf_off) == (ADIO_Offset)(MPI_Puint)(buf + userbuf_off));
+ ADIOI_Assert((((ADIO_Offset)(MPIR_Puint)buf) + userbuf_off) == (ADIO_Offset)(MPIR_Puint)(buf + userbuf_off));
ADIOI_Assert(req_len == (int) req_len);
ADIO_ReadContig(fd,
(char *) buf + userbuf_off,
@@ -245,7 +245,7 @@ void ADIOI_GEN_ReadStrided_naive(ADIO_File fd, void *buf, int count,
req_off = off;
req_len = frd_size;
ADIO_ReadContig(fd,
@@ -311,7 +311,7 @@ void ADIOI_GEN_ReadStrided_naive(ADIO_File fd, void *buf, int count,
req_len = size;
userbuf_off = i_offset;
ADIO_ReadContig(fd,
diff --git a/mpich2/src/mpi/romio/adio/common/ad_write_coll.c b/mpich2/src/mpi/romio/adio/common/ad_write_coll.c
index f82405d..76e3a5e 100644
--- a/mpich2/src/mpi/romio/adio/common/ad_write_coll.c
+++ b/mpich2/src/mpi/romio/adio/common/ad_write_coll.c
@@ -447,7 +447,7 @@ static void ADIOI_Exch_and_write(ADIO_File fd, void *buf, MPI_Datatype
count[i]++;
@@ -819,7 +819,7 @@ static void ADIOI_Fill_send_buffer(ADIO_File fd, void *buf, ADIOI_Flatlist_node
while (size) { \
diff --git a/mpich2/src/mpi/romio/adio/common/ad_write_nolock.c b/mpich2/src/mpi/romio/adio/common/ad_write_nolock.c
index c331ac8..5ff0897 100644
--- a/mpich2/src/mpi/romio/adio/common/ad_write_nolock.c
+++ b/mpich2/src/mpi/romio/adio/common/ad_write_nolock.c
@@ -139,7 +139,7 @@ void ADIOI_NOLOCK_WriteStrided(ADIO_File fd, void *buf, int count,
flat_buf->blocklens[i]);
#endif
ADIOI_Assert(flat_buf->blocklens[i] == (unsigned)flat_buf->blocklens[i]);
- ADIOI_Assert((((ADIO_Offset)(MPI_Puint)buf) + (ADIO_Offset)j*(ADIO_Offset)buftype_extent + flat_buf->indices[i]) == (ADIO_Offset)((MPI_Puint)buf + (ADIO_Offset)j*(ADIO_Offset)buftype_extent + flat_buf->indices[i]));
+ ADIOI_Assert((((ADIO_Offset)(MPIR_Puint)buf) + (ADIO_Offset)j*(ADIO_Offset)buftype_extent + flat_buf->indices[i]) == (ADIO_Offset)((MPIR_Puint)buf + (ADIO_Offset)j*(ADIO_Offset)buftype_extent + flat_buf->indices[i]));
#ifdef ADIOI_MPE_LOGGING
MPE_Log_event( ADIOI_MPE_write_a, 0, NULL );
#endif
diff --git a/mpich2/src/mpi/romio/adio/common/ad_write_str_naive.c b/mpich2/src/mpi/romio/adio/common/ad_write_str_naive.c
index 38e47f9..abff76c 100644
--- a/mpich2/src/mpi/romio/adio/common/ad_write_str_naive.c
+++ b/mpich2/src/mpi/romio/adio/common/ad_write_str_naive.c
@@ -83,7 +83,7 @@ void ADIOI_GEN_WriteStrided_naive(ADIO_File fd, void *buf, int count,
ADIO_WriteContig(fd,
(int)req_len,
@@ -246,7 +246,7 @@ void ADIOI_GEN_WriteStrided_naive(ADIO_File fd, void *buf, int count,
req_len = fwr_size;
(int)req_len,
@@ -312,7 +312,7 @@ void ADIOI_GEN_WriteStrided_naive(ADIO_File fd, void *buf, int count,
(int)req_len,
diff --git a/mpich2/src/mpi/romio/adio/include/adioi.h b/mpich2/src/mpi/romio/adio/include/adioi.h
index db30f92..eb38d0a 100644
--- a/mpich2/src/mpi/romio/adio/include/adioi.h
+++ b/mpich2/src/mpi/romio/adio/include/adioi.h
@@ -654,13 +654,13 @@ int ADIOI_MPE_postwrite_b;
to (possible) 4 byte ptr cast) */
/* Should work even on 64bit or old 32bit configs */
/* Use MPID_Ensure_Aint_fits_in_pointer from mpiutil.h and
- MPI_AINT_CAST_TO_VOID_PTR from configure (mpi.h) */
+ MPIR_MPI_AINT_CAST_TO_VOID_PTR from configure (mpi.h) */
#include "mpiimpl.h"
- #define ADIOI_AINT_CAST_TO_VOID_PTR MPI_AINT_CAST_TO_VOID_PTR
+ #define ADIOI_AINT_CAST_TO_VOID_PTR MPIR_MPI_AINT_CAST_TO_VOID_PTR
/* The next two casts are only used when you don't want sign extension
when casting a (possible 4 byte) aint to a (8 byte) long long or offset */
- #define ADIOI_AINT_CAST_TO_LONG_LONG MPI_AINT_CAST_TO_LONG_LONG
+ #define ADIOI_AINT_CAST_TO_LONG_LONG MPIR_MPI_AINT_CAST_TO_LONG_LONG
#define ADIOI_AINT_CAST_TO_OFFSET ADIOI_AINT_CAST_TO_LONG_LONG
#define ADIOI_ENSURE_AINT_FITS_IN_PTR(aint_value) MPID_Ensure_Aint_fits_in_pointer(aint_value)
diff --git a/mpich2/src/mpid/common/datatype/dataloop/dataloop.c b/mpich2/src/mpid/common/datatype/dataloop/dataloop.c
index 054094b..7de4967 100644
--- a/mpich2/src/mpid/common/datatype/dataloop/dataloop.c
+++ b/mpich2/src/mpid/common/datatype/dataloop/dataloop.c
@@ -155,11 +155,11 @@ void PREPEND_PREFIX(Dataloop_update)(DLOOP_Dataloop *dataloop,
if (dataloop->loop_params.cm_t.dataloop)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
dataloop->loop_params.cm_t.dataloop =
- (DLOOP_Dataloop *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
+ (DLOOP_Dataloop *) MPIR_MPI_AINT_CAST_TO_VOID_PTR
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
if (!(dataloop->kind & DLOOP_FINAL_MASK))
@@ -169,18 +169,18 @@ void PREPEND_PREFIX(Dataloop_update)(DLOOP_Dataloop *dataloop,
case DLOOP_KIND_BLOCKINDEXED:
if (dataloop->loop_params.bi_t.offset_array)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
dataloop->loop_params.bi_t.offset_array =
- (DLOOP_Offset *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
+ (DLOOP_Offset *) MPIR_MPI_AINT_CAST_TO_VOID_PTR
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
if (dataloop->loop_params.bi_t.dataloop)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
dataloop->loop_params.bi_t.dataloop =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
@@ -190,26 +190,26 @@ void PREPEND_PREFIX(Dataloop_update)(DLOOP_Dataloop *dataloop,
case DLOOP_KIND_INDEXED:
if (dataloop->loop_params.i_t.blocksize_array)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
dataloop->loop_params.i_t.blocksize_array =
- (DLOOP_Count *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
+ (DLOOP_Count *) MPIR_MPI_AINT_CAST_TO_VOID_PTR
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
if (dataloop->loop_params.i_t.offset_array)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
dataloop->loop_params.i_t.offset_array =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
if (dataloop->loop_params.i_t.dataloop)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
dataloop->loop_params.i_t.dataloop =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
@@ -219,26 +219,26 @@ void PREPEND_PREFIX(Dataloop_update)(DLOOP_Dataloop *dataloop,
case DLOOP_KIND_STRUCT:
if (dataloop->loop_params.s_t.blocksize_array)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
dataloop->loop_params.s_t.blocksize_array =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
if (dataloop->loop_params.s_t.offset_array)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
dataloop->loop_params.s_t.offset_array =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
if (dataloop->loop_params.s_t.dataloop_array)
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
dataloop->loop_params.s_t.dataloop_array =
- (DLOOP_Dataloop **) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
+ (DLOOP_Dataloop **) MPIR_MPI_AINT_CAST_TO_VOID_PTR
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
/* fix the N dataloop pointers too */
@@ -246,9 +246,9 @@ void PREPEND_PREFIX(Dataloop_update)(DLOOP_Dataloop *dataloop,
for (i=0; i < dataloop->loop_params.s_t.count; i++) {
if (looparray[i])
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
- looparray[i] = (DLOOP_Dataloop *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
+ looparray[i] = (DLOOP_Dataloop *) MPIR_MPI_AINT_CAST_TO_VOID_PTR
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
diff --git a/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_pairtype.c b/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_pairtype.c
index d5f7b86..11c7a7a 100644
--- a/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_pairtype.c
+++ b/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_pairtype.c
@@ -11,7 +11,7 @@
struct { ut1_ a; ut2_ b; } foo; \
disps[0] = 0; \
- disps[1] = MPI_VOID_PTR_CAST_TO_MPI_AINT ((char *) &foo.b - (char *) &foo.a); \
+ disps[1] = MPIR_VOID_PTR_CAST_TO_MPI_AINT ((char *) &foo.b - (char *) &foo.a); \
types[0] = mt1_; \
types[1] = mt2_; \
diff --git a/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_struct.c b/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_struct.c
index d9fc694..50fe3c7 100644
--- a/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_struct.c
+++ b/mpich2/src/mpid/common/datatype/dataloop/dataloop_create_struct.c
@@ -622,7 +622,7 @@ static int DLOOP_Dataloop_create_flattened_struct(int count,
if (oldtypes[i] != MPI_UB && oldtypes[i] != MPI_LB && blklens[i] != 0)
- PREPEND_PREFIX(Segment_init)((char *) MPI_AINT_CAST_TO_VOID_PTR disps[i],
+ PREPEND_PREFIX(Segment_init)((char *) MPIR_MPI_AINT_CAST_TO_VOID_PTR disps[i],
(DLOOP_Count) blklens[i],
oldtypes[i],
segp,
diff --git a/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c b/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c
index c7e5473..0700f29 100644
--- a/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c
+++ b/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c
@@ -38,22 +38,22 @@ int PREPEND_PREFIX(Segment_contig_m2m)(DLOOP_Offset *blocks_p,
if (paramp->direction == DLOOP_M2M_TO_USERBUF) {
/* userbuf is a pointer (not a displacement) since it is being used on a memcpy */
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off );
- memcpy((char *) MPI_AINT_CAST_TO_VOID_PTR ((MPI_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off),
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off );
+ memcpy((char *) MPIR_MPI_AINT_CAST_TO_VOID_PTR ((MPIR_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off),
paramp->streambuf,
size);
else {
memcpy(paramp->streambuf,
- (char *) ( MPI_AINT_CAST_TO_VOID_PTR ((MPI_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off) ),
+ (char *) ( MPIR_MPI_AINT_CAST_TO_VOID_PTR ((MPIR_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off) ),
size);
/* streambuf is a pointer (not a displacement) since it was used on a memcpy */
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT (paramp->streambuf)) + size );
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT (paramp->streambuf)) + size );
paramp->streambuf += size;
return 0;
@@ -81,8 +81,8 @@ int PREPEND_PREFIX(Segment_vector_m2m)(DLOOP_Offset *blocks_p,
/* userbuf is a pointer (not a displacement) since it is being used for a memory copy */
- cbufp = (char*)( MPI_AINT_CAST_TO_VOID_PTR ( (MPI_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off ) );
+ cbufp = (char*)( MPIR_MPI_AINT_CAST_TO_VOID_PTR ( (MPIR_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) + rel_off ) );
DLOOP_Handle_get_size_macro(el_type, el_size);
whole_count = (blksz > 0) ? (*blocks_p / (DLOOP_Offset)blksz) : 0;
@@ -116,18 +116,18 @@ int PREPEND_PREFIX(Segment_vector_m2m)(DLOOP_Offset *blocks_p,
memcpy(cbufp, paramp->streambuf, ((DLOOP_Offset)blksz) * el_size);
/* streambuf is a pointer (not a displacement) since it is being used for a memory copy */
((DLOOP_Offset)blksz) * el_size );
paramp->streambuf += ((DLOOP_Offset)blksz) * el_size;
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT (cbufp)) + stride );
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT (cbufp)) + stride );
cbufp += stride;
if (blocks_left) {
memcpy(cbufp, paramp->streambuf, ((DLOOP_Offset)blocks_left) * el_size);
((DLOOP_Offset)blocks_left) * el_size );
paramp->streambuf += ((DLOOP_Offset)blocks_left) * el_size;
@@ -161,7 +161,7 @@ int PREPEND_PREFIX(Segment_vector_m2m)(DLOOP_Offset *blocks_p,
memcpy(paramp->streambuf, cbufp, (DLOOP_Offset)blksz * el_size);
(DLOOP_Offset)blksz * el_size );
paramp->streambuf += (DLOOP_Offset)blksz * el_size;
cbufp += stride;
@@ -170,7 +170,7 @@ int PREPEND_PREFIX(Segment_vector_m2m)(DLOOP_Offset *blocks_p,
memcpy(paramp->streambuf, cbufp, (DLOOP_Offset)blocks_left * el_size);
(DLOOP_Offset)blocks_left * el_size );
paramp->streambuf += (DLOOP_Offset)blocks_left * el_size;
@@ -206,10 +206,10 @@ int PREPEND_PREFIX(Segment_blkidx_m2m)(DLOOP_Offset *blocks_p,
rel_off + offsetarray[curblock] );
- cbufp = (char*) MPI_AINT_CAST_TO_VOID_PTR
- ((MPI_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) +
+ cbufp = (char*) MPIR_MPI_AINT_CAST_TO_VOID_PTR
+ ((MPIR_VOID_PTR_CAST_TO_MPI_AINT (paramp->userbuf)) +
rel_off + offsetarray[curblock]);
if (blocklen > blocks_left) blocklen = blocks_left;
@@ -243,7 +243,7 @@ int PREPEND_PREFIX(Segment_blkidx_m2m)(DLOOP_Offset *blocks_p,
(DLOOP_Offset)blocklen * el_size );
paramp->streambuf += (DLOOP_Offset)blocklen * el_size;
blocks_left -= blocklen;
@@ -280,10 +280,10 @@ int PREPEND_PREFIX(Segment_index_m2m)(DLOOP_Offset *blocks_p,
if (cur_block_sz > blocks_left) cur_block_sz = blocks_left;
@@ -317,7 +317,7 @@ int PREPEND_PREFIX(Segment_index_m2m)(DLOOP_Offset *blocks_p,
cur_block_sz * el_size );
paramp->streambuf += cur_block_sz * el_size;
blocks_left -= cur_block_sz;
@@ -636,7 +636,7 @@ static int DLOOP_Segment_contig_mpi_flatten(DLOOP_Offset *blocks_p,
* disps + blklens fits in a pointer. Just let it truncate, if the sizeof a pointer is less
* than the sizeof an MPI_Aint.
- last_end = (char*) MPI_AINT_CAST_TO_VOID_PTR
+ last_end = (char*) MPIR_MPI_AINT_CAST_TO_VOID_PTR
(paramp->disps[last_idx] + ((DLOOP_Offset)paramp->blklens[last_idx]));
@@ -661,10 +661,10 @@ static int DLOOP_Segment_contig_mpi_flatten(DLOOP_Offset *blocks_p,
else {
/* Since bufp can be a displacement and can be negative, we cannot use
- * MPI_VOID_PTR_CAST_TO_MPI_AINT to cast the sum to a pointer. Just let it
+ * MPIR_VOID_PTR_CAST_TO_MPI_AINT to cast the sum to a pointer. Just let it
* sign extend.
- paramp->disps[last_idx+1] = MPI_PTR_DISP_CAST_TO_MPI_AINT bufp + rel_off;
+ paramp->disps[last_idx+1] = MPIR_PTR_DISP_CAST_TO_MPI_AINT bufp + rel_off;
paramp->blklens[last_idx+1] = size;
paramp->index++;
@@ -720,11 +720,11 @@ static int DLOOP_Segment_vector_mpi_flatten(DLOOP_Offset *blocks_p,
last_idx = paramp->index - 1;
if (last_idx >= 0) {
/* Since disps can be negative, we cannot use MPID_Ensure_Aint_fits_in_pointer to verify that
- * disps + blklens fits in a pointer. Nor can we use MPI_AINT_CAST_TO_VOID_PTR to cast the
+ * disps + blklens fits in a pointer. Nor can we use MPIR_MPI_AINT_CAST_TO_VOID_PTR to cast the
* sum to a pointer. Just let it truncate, if the sizeof a pointer is less than the sizeof
* an MPI_Aint.
- last_end = (char *) MPI_AINT_CAST_TO_VOID_PTR
+ last_end = (char *) MPIR_MPI_AINT_CAST_TO_VOID_PTR
( paramp->disps[last_idx] +
(MPI_Aint)(paramp->blklens[last_idx]) );
@@ -754,10 +754,10 @@ static int DLOOP_Segment_vector_mpi_flatten(DLOOP_Offset *blocks_p,
else {
* sign extend.
paramp->index++;
@@ -812,11 +812,11 @@ static int DLOOP_Segment_blkidx_mpi_flatten(DLOOP_Offset *blocks_p,
* an MPI_Aint.
@@ -845,10 +845,10 @@ static int DLOOP_Segment_blkidx_mpi_flatten(DLOOP_Offset *blocks_p,
else {
* sign extend.
- paramp->disps[last_idx+1] = MPI_PTR_DISP_CAST_TO_MPI_AINT bufp + rel_off + offsetarray[last_idx+1];
+ paramp->disps[last_idx+1] = MPIR_PTR_DISP_CAST_TO_MPI_AINT bufp + rel_off + offsetarray[last_idx+1];
paramp->index++;
@@ -903,11 +903,11 @@ static int DLOOP_Segment_index_mpi_flatten(DLOOP_Offset *blocks_p,
* an MPI_Aint.
@@ -937,10 +937,10 @@ static int DLOOP_Segment_index_mpi_flatten(DLOOP_Offset *blocks_p,
else {
* sign extend.
paramp->index++;
diff --git a/mpich2/src/mpid/common/datatype/dataloop/veccpy.h b/mpich2/src/mpid/common/datatype/dataloop/veccpy.h
index 04a4858..4f7d602 100644
--- a/mpich2/src/mpid/common/datatype/dataloop/veccpy.h
+++ b/mpich2/src/mpid/common/datatype/dataloop/veccpy.h
@@ -11,20 +11,20 @@
#ifdef HAVE_ANY_INT64_T_ALIGNEMENT
#define MPIR_ALIGN8_TEST(p1,p2)
#else
-#define MPIR_ALIGN8_TEST(p1,p2) && (((MPI_VOID_PTR_CAST_TO_MPI_AINT p1 | MPI_VOID_PTR_CAST_TO_MPI_AINT p2) & 0x7) == 0)
+#define MPIR_ALIGN8_TEST(p1,p2) && (((MPIR_VOID_PTR_CAST_TO_MPI_AINT p1 | MPIR_VOID_PTR_CAST_TO_MPI_AINT p2) & 0x7) == 0)
#endif
#ifdef HAVE_ANY_INT32_T_ALIGNEMENT
#define MPIR_ALIGN4_TEST(p1,p2)
#else
-#define MPIR_ALIGN4_TEST(p1,p2) && (((MPI_VOID_PTR_CAST_TO_MPI_AINT p1 | MPI_VOID_PTR_CAST_TO_MPI_AINT p2) & 0x3) == 0)
+#define MPIR_ALIGN4_TEST(p1,p2) && (((MPIR_VOID_PTR_CAST_TO_MPI_AINT p1 | MPIR_VOID_PTR_CAST_TO_MPI_AINT p2) & 0x3) == 0)
#endif
#define MPIDI_COPY_FROM_VEC(src,dest,stride,type,nelms,count) \
if (!nelms) { \
- src = (char*) MPI_AINT_CAST_TO_VOID_PTR \
- ((MPI_VOID_PTR_CAST_TO_MPI_AINT (src)) + \
+ src = (char*) MPIR_MPI_AINT_CAST_TO_VOID_PTR \
+ ((MPIR_VOID_PTR_CAST_TO_MPI_AINT (src)) + \
((DLOOP_Offset)count * (DLOOP_Offset)stride) ); \
else if (stride % sizeof(type)) { \
@@ -38,8 +38,8 @@
#define MPIDI_COPY_TO_VEC(src,dest,stride,type,nelms,count) \
if (!nelms) { \
- dest = (char*) MPI_AINT_CAST_TO_VOID_PTR \
- ((MPI_VOID_PTR_CAST_TO_MPI_AINT (dest)) + \
+ dest = (char*) MPIR_MPI_AINT_CAST_TO_VOID_PTR \
+ ((MPIR_VOID_PTR_CAST_TO_MPI_AINT (dest)) + \
else if (stride % (DLOOP_Offset)sizeof(type)) { \
diff --git a/mpich2/src/mpid/common/datatype/mpid_segment.c b/mpich2/src/mpid/common/datatype/mpid_segment.c
index e478949..2210d61 100644
--- a/mpich2/src/mpid/common/datatype/mpid_segment.c
+++ b/mpich2/src/mpid/common/datatype/mpid_segment.c
@@ -248,7 +248,7 @@ static int MPID_Segment_contig_pack_to_iov(DLOOP_Offset *blocks_p,
paramp->u.pack_vector.vectorp[last_idx].DLOOP_VECTOR_LEN;
- MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT (bufp)) + rel_off );
+ MPID_Ensure_Aint_fits_in_pointer( (MPIR_VOID_PTR_CAST_TO_MPI_AINT (bufp)) + rel_off );
if ((last_idx == paramp->u.pack_vector.length-1) &&
(last_end != ((char *) bufp + rel_off)))
@@ -346,7 +346,7 @@ static int MPID_Segment_vector_pack_to_iov(DLOOP_Offset *blocks_p,
@@ -423,13 +423,13 @@ static int MPID_Segment_contig_flatten(DLOOP_Offset *blocks_p,
#ifdef MPID_SP_VERBOSE
MPIU_dbg_printf("\t[contig flatten: index = %d, loc = (" MPI_AINT_FMT_HEX_SPEC " + " MPI_AINT_FMT_HEX_SPEC ") = " MPI_AINT_FMT_HEX_SPEC ", size = " MPI_AINT_FMT_DEC_SPEC "]\n",
index,
- MPI_VOID_PTR_CAST_TO_MPI_AINT bufp,
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT bufp,
(MPI_Aint) rel_off,
- MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off,
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off,
(MPI_Aint) size);
#endif
- if (index > 0 && ((DLOOP_Offset) MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off) ==
+ if (index > 0 && ((DLOOP_Offset) MPIR_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off) ==
((paramp->u.flatten.offp[index - 1]) +
(DLOOP_Offset)paramp->u.flatten.sizep[index - 1]))
@@ -437,7 +437,7 @@ static int MPID_Segment_contig_flatten(DLOOP_Offset *blocks_p,
paramp->u.flatten.sizep[index - 1] += size;
else {
- paramp->u.flatten.offp[index] = ((int64_t) MPI_VOID_PTR_CAST_TO_MPI_AINT bufp) + (int64_t) rel_off;
+ paramp->u.flatten.offp[index] = ((int64_t) MPIR_VOID_PTR_CAST_TO_MPI_AINT bufp) + (int64_t) rel_off;
paramp->u.flatten.sizep[index] = size;
paramp->u.flatten.index++;
@@ -500,7 +500,7 @@ static int MPID_Segment_vector_flatten(DLOOP_Offset *blocks_p,
blocks_left = 0;
((paramp->u.flatten.offp[index - 1]) + (DLOOP_Offset)paramp->u.flatten.sizep[index - 1]))
/* add this size to the last region rather than using up another one */
@@ -508,7 +508,7 @@ static int MPID_Segment_vector_flatten(DLOOP_Offset *blocks_p,
else if (index < paramp->u.flatten.length) {
/* take up another region */
- paramp->u.flatten.offp[index] = (DLOOP_Offset) MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off;
+ paramp->u.flatten.offp[index] = (DLOOP_Offset) MPIR_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off;
diff --git a/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c b/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c
index e509101..99f2ec7 100644
--- a/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c
+++ b/mpich2/src/mpid/common/datatype/mpid_type_create_pairtype.c
@@ -19,7 +19,7 @@
type_size = sizeof(foo.a) + sizeof(foo.b); \
type_extent = (MPI_Aint) sizeof(foo); \
el_size = (sizeof(foo.a) == sizeof(foo.b)) ? (int) sizeof(foo.a) : -1; \
- true_ub = (MPI_VOID_PTR_CAST_TO_MPI_AINT ((char *) &foo.b - \
+ true_ub = (MPIR_VOID_PTR_CAST_TO_MPI_AINT ((char *) &foo.b - \
(char *) &foo.a)) + \
(MPI_Aint) sizeof(foo.b); \
alignsize = MPIR_MAX(MPID_Datatype_get_basic_size(mt1_), \
diff --git a/mpich2/src/mpid/dcmfd/src/coll/allgather/mpido_allgather.c b/mpich2/src/mpid/dcmfd/src/coll/allgather/mpido_allgather.c
index 98b40a7..425150d 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/allgather/mpido_allgather.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/allgather/mpido_allgather.c
@@ -90,7 +90,7 @@ int MPIDO_Allgather_Async_bcast(void *sendbuf,
dt_true_lb);
comm_ptr->local_size * recvcount * extent));
@@ -169,7 +169,7 @@ int MPIDO_Allgather_Bcast(void *sendbuf,
MPI_Aint extent;
@@ -322,14 +322,14 @@ MPIDO_Allgather(void *sendbuf,
dt_null,
send_true_lb);
- (MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf + send_true_lb));
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf + send_true_lb));
config.largecount = (sendcount>32768);
/* Needed in alltoall/allreduce implementations */
recv_true_lb + comm_ptr->local_size*send_size));
/* verify everyone's datatype contiguity */
diff --git a/mpich2/src/mpid/dcmfd/src/coll/allgatherv/mpido_allgatherv.c b/mpich2/src/mpid/dcmfd/src/coll/allgatherv/mpido_allgatherv.c
index 1c423aa..7936ec4 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/allgatherv/mpido_allgatherv.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/allgatherv/mpido_allgatherv.c
@@ -110,7 +110,7 @@ int MPIDO_Allgatherv_Async_bcast(void *sendbuf,
dt_true_lb);
displs[comm_ptr->rank] * extent));
if(sendbuf != MPI_IN_PLACE)
@@ -203,7 +203,7 @@ int MPIDO_Allgatherv_Bcast(void *sendbuf,
/* This isn't technically big enough, but we don't want to
* add an assert inside the loop */
@@ -355,7 +355,7 @@ MPIDO_Allgatherv(void *sendbuf,
dt_null,
send_true_lb);
int buffer_sum = 0;
@@ -387,7 +387,7 @@ MPIDO_Allgatherv(void *sendbuf,
comm_ptr);
- (MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf + recv_true_lb + buffer_sum));
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf + recv_true_lb + buffer_sum));
/* determine which protocol to use */
/* 1) Tree allreduce
diff --git a/mpich2/src/mpid/dcmfd/src/coll/allreduce/mpido_allreduce.c b/mpich2/src/mpid/dcmfd/src/coll/allreduce/mpido_allreduce.c
index 6cf6748..1800148 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/allreduce/mpido_allreduce.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/allreduce/mpido_allreduce.c
@@ -321,7 +321,7 @@ int MPIDO_Allreduce(
dt_ptr,
dt_true_lb);
dt_true_lb);
recvbuf = ((char *)recvbuf + dt_true_lb);
@@ -349,7 +349,7 @@ int MPIDO_Allreduce(
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf +
+ MPID_Ensure_Aint_fits_in_pointer(MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf +
dt_true_lb);
sendbuf = ((char *)sendbuf + dt_true_lb);
// int err =
diff --git a/mpich2/src/mpid/dcmfd/src/coll/alltoall/mpido_alltoall.c b/mpich2/src/mpid/dcmfd/src/coll/alltoall/mpido_alltoall.c
index c16169c..f5b0e6d 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/alltoall/mpido_alltoall.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/alltoall/mpido_alltoall.c
@@ -80,9 +80,9 @@ MPIDO_Alltoall(void *sendbuf,
trcvlen, dt_null, rdt_true_lb);
- MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf + sdt_true_lb);
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf + sdt_true_lb);
- MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf + rdt_true_lb);
+ MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf + rdt_true_lb);
if(sendcount == 0 || recvcount == 0)
return MPI_SUCCESS;
diff --git a/mpich2/src/mpid/dcmfd/src/coll/alltoallv/mpido_alltoallv.c b/mpich2/src/mpid/dcmfd/src/coll/alltoallv/mpido_alltoallv.c
index 74a9030..b86f96a 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/alltoallv/mpido_alltoallv.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/alltoallv/mpido_alltoallv.c
@@ -79,9 +79,9 @@ MPIDO_Alltoallv(void *sendbuf,
MPIDI_Datatype_get_info(1, recvtype, rcv_contig, trcvlen,
if(!comm_ptr->dcmf.alltoalls ||
diff --git a/mpich2/src/mpid/dcmfd/src/coll/alltoallw/mpido_alltoallw.c b/mpich2/src/mpid/dcmfd/src/coll/alltoallw/mpido_alltoallw.c
index 4e96122..825ca8e 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/alltoallw/mpido_alltoallw.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/alltoallw/mpido_alltoallw.c
@@ -89,9 +89,9 @@ MPIDO_Alltoallw(void *sendbuf,
diff --git a/mpich2/src/mpid/dcmfd/src/coll/bcast/mpido_bcast.c b/mpich2/src/mpid/dcmfd/src/coll/bcast/mpido_bcast.c
index 8a928f8..b02d435 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/bcast/mpido_bcast.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/bcast/mpido_bcast.c
@@ -201,7 +201,7 @@ int MPIDO_Bcast(void * buffer,
dt_true_lb);
- (MPI_VOID_PTR_CAST_TO_MPI_AINT buffer + dt_true_lb));
+ (MPIR_VOID_PTR_CAST_TO_MPI_AINT buffer + dt_true_lb));
data_buffer = (char *)buffer+dt_true_lb;
/* tree asserts if the data type size is actually 0. should we make
diff --git a/mpich2/src/mpid/dcmfd/src/coll/gather/mpido_gather.c b/mpich2/src/mpid/dcmfd/src/coll/gather/mpido_gather.c
index 350b805..b354b74 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/gather/mpido_gather.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/gather/mpido_gather.c
@@ -157,11 +157,11 @@ int MPIDO_Gather(void *sendbuf,
true_lb);
sendbuf = (char *)sendbuf + true_lb;
true_lb);
recvbuf = (char *)recvbuf + true_lb;
diff --git a/mpich2/src/mpid/dcmfd/src/coll/reduce/mpido_reduce.c b/mpich2/src/mpid/dcmfd/src/coll/reduce/mpido_reduce.c
index 1d6ce2b..803abe3 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/reduce/mpido_reduce.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/reduce/mpido_reduce.c
@@ -266,13 +266,13 @@ int MPIDO_Reduce(void * sendbuf,
unsigned usingrect=1 && rectavail;
unsigned usingrectring=(rectringavail && count > 16384);
- MPID_Ensure_Aint_fits_in_pointer( MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
+ MPID_Ensure_Aint_fits_in_pointer( MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
dt_true_lb);
recvbuf = (char *)recvbuf + dt_true_lb;
- MPID_Ensure_Aint_fits_in_pointer (MPI_VOID_PTR_CAST_TO_MPI_AINT sendbuf +
+ MPID_Ensure_Aint_fits_in_pointer (MPIR_VOID_PTR_CAST_TO_MPI_AINT sendbuf +
dt_true_lb);
sendbuf = (char *)sendbuf + dt_true_lb;
// int err =
diff --git a/mpich2/src/mpid/dcmfd/src/coll/reduce_scatter/mpido_reduce_scatter.c b/mpich2/src/mpid/dcmfd/src/coll/reduce_scatter/mpido_reduce_scatter.c
index 014fb53..d2eba18 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/reduce_scatter/mpido_reduce_scatter.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/reduce_scatter/mpido_reduce_scatter.c
@@ -80,7 +80,7 @@ int MPIDO_Reduce_scatter(void *sendbuf,
memset(displs, 0, size*sizeof(int));
dt_lb);
sendbuf = (char *)sendbuf + dt_lb;
diff --git a/mpich2/src/mpid/dcmfd/src/coll/scatter/mpido_scatter.c b/mpich2/src/mpid/dcmfd/src/coll/scatter/mpido_scatter.c
index 025dd73..702ed04 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/scatter/mpido_scatter.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/scatter/mpido_scatter.c
@@ -114,12 +114,12 @@ int MPIDO_Scatter(void *sendbuf,
if(bcastscatter)
true_lb);
if(recvbuf != MPI_IN_PLACE)
- MPID_Ensure_Aint_fits_in_pointer (MPI_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
+ MPID_Ensure_Aint_fits_in_pointer (MPIR_VOID_PTR_CAST_TO_MPI_AINT recvbuf +
true_lb);
diff --git a/mpich2/src/mpid/dcmfd/src/coll/scatterv/mpido_scatterv.c b/mpich2/src/mpid/dcmfd/src/coll/scatterv/mpido_scatterv.c
index 8befe04..61d73f6 100644
--- a/mpich2/src/mpid/dcmfd/src/coll/scatterv/mpido_scatterv.c
+++ b/mpich2/src/mpid/dcmfd/src/coll/scatterv/mpido_scatterv.c
@@ -270,7 +270,7 @@ int MPIDO_Scatterv(void *sendbuf,
if(rank == root)
+ true_lb);
@@ -278,7 +278,7 @@ int MPIDO_Scatterv(void *sendbuf,
+ true_lb);
1.5.3.7
More information about the mpich2-dev
