[mpich2-dev] [PATCH 1/1] Issue 4120: Fix 8-byte MPI_Aint compile warnings
Jeff Parker
jjparker at us.ibm.com
Mon Mar 31 21:41:24 CDT 2008
Fixed compiler warnings by using the configurable cast macros for MPI_Aint.
Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
lib/mpi/mpich2/src/binding/f77/buildiface | 12 ++--
lib/mpi/mpich2/src/mpi/datatype/type_get_name.c | 2 +-
.../mpid/common/datatype/dataloop/segment_ops.c | 53 +++++++++++++-------
lib/mpi/mpich2/src/util/mem/handlemem.c | 4 +-
4 files changed, 43 insertions(+), 28 deletions(-)
diff --git a/lib/mpi/mpich2/src/binding/f77/buildiface b/lib/mpi/mpich2/src/binding/f77/buildiface
index f5564b6..a08afa9 100755
--- a/lib/mpi/mpich2/src/binding/f77/buildiface
+++ b/lib/mpi/mpich2/src/binding/f77/buildiface
@@ -1388,7 +1388,7 @@ sub addrint_in_decl {
sub addrint_in_arg {
my $count = $_[0];
- print $OUTFD "(void *)(MPI_Aint)((int)*(int *)v$count)";
+ print $OUTFD "MPI_AINT_CAST_TO_VOID_PTR(MPI_Aint)((int)*(int *)v$count)";
sub attrint_ctof {
@@ -1402,7 +1402,7 @@ sub attrint_ctof {
*(MPI_Fint*)$cvar = 0;
else {
- *(MPI_Fint*)$cvar = (MPI_Fint)(MPI_Aint)attr$cvar;
+ *(MPI_Fint*)$cvar = (MPI_Fint)MPI_VOID_PTR_CAST_TO_MPI_AINT attr$cvar;
}\n";
@@ -1428,7 +1428,7 @@ sub addraint_in_decl {
sub addraint_in_arg {
my $count = $_[0];
- print $OUTFD "(void *)(MPI_Aint)((MPI_Aint)*(MPI_Aint *)v$count)";
+ print $OUTFD "MPI_AINT_CAST_TO_VOID_PTR(MPI_Aint)((MPI_Aint)*(MPI_Aint *)v$count)";
sub attraint_ctof {
@@ -1440,7 +1440,7 @@ sub attraint_ctof {
*(MPI_Aint*)$cvar = 0;
else {
- *(MPI_Aint*)$cvar = (MPI_Aint)attr$cvar;
+ *(MPI_Aint*)$cvar = MPI_VOID_PTR_CAST_TO_MPI_AINT attr$cvar;
}\n";
@@ -2622,7 +2622,7 @@ FORT_DLL_SPEC void FORT_CALL mpirinitc2_( char *a FORT_MIXED_LEN(d1)
#ifdef USE_POINTER_FOR_BOTTOM
b = a;
#else
- b = a - (MPI_Aint) MPIR_F_MPI_BOTTOM;
+ b = a - MPI_VOID_PTR_CAST_TO_MPI_AINT MPIR_F_MPI_BOTTOM;
#endif
*v2 = (MPI_Fint)( b );
#ifdef HAVE_AINT_LARGER_THAN_FINT
@@ -2661,7 +2661,7 @@ FORT_DLL_SPEC void FORT_CALL mpirinitc2_( char *a FORT_MIXED_LEN(d1)
&specialInitStatement( $OUTFD );
print $OUTFD "\
#ifndef USE_POINTER_FOR_BOTTOM
- a = a - (MPI_Aint) MPIR_F_MPI_BOTTOM;
+ a = a - MPI_VOID_PTR_CAST_TO_MPI_AINT MPIR_F_MPI_BOTTOM;
#endif
*v2 = a;
}\n";
diff --git a/lib/mpi/mpich2/src/mpi/datatype/type_get_name.c b/lib/mpi/mpich2/src/mpi/datatype/type_get_name.c
index 2783de0..fbba673 100644
--- a/lib/mpi/mpich2/src/mpi/datatype/type_get_name.c
+++ b/lib/mpi/mpich2/src/mpi/datatype/type_get_name.c
@@ -147,7 +147,7 @@ int MPIR_Datatype_init_names( void )
MPIU_DBG_MSG_FMT(DATATYPE,VERBOSE,(MPIU_DBG_FDEST,
- "mpi_names[%d].name = %x\n", i, (unsigned) (MPI_Aint)mpi_names[i].name ));
+ "mpi_names[%d].name = %p\n", i, mpi_names[i].name ));
MPIU_Strncpy( datatype_ptr->name, mpi_names[i].name,
MPI_MAX_OBJECT_NAME );
diff --git a/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c b/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c
index 9087f54..6fe799f 100644
--- a/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c
+++ b/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/segment_ops.c
@@ -671,7 +671,7 @@ static int DLOOP_Segment_vector_mpi_flatten(DLOOP_Offset *blocks_p,
struct PREPEND_PREFIX(mpi_flatten_params) *paramp = v_paramp;
DLOOP_Handle_get_size_macro(el_type, el_size);
- blocks_left = *blocks_p;
+ blocks_left = (int)*blocks_p;
for (i=0; i < count && blocks_left > 0; i++) {
int last_idx;
@@ -689,31 +689,37 @@ static int DLOOP_Segment_vector_mpi_flatten(DLOOP_Offset *blocks_p,
last_idx = paramp->index - 1;
if (last_idx >= 0) {
- last_end = ((char *) paramp->disps[last_idx]) +
- paramp->blklens[last_idx];
+ MPID_Ensure_Aint_fits_in_pointer( paramp->disps[last_idx] +
+ (MPI_Aint)(paramp->blklens[last_idx]) );
+ last_end = (char *) MPI_AINT_CAST_TO_VOID_PTR
+ ( paramp->disps[last_idx] +
+ MPID_Ensure_Aint_fits_in_pointer( MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off );
if ((last_idx == paramp->length-1) &&
- (last_end != ((char *) bufp + rel_off)))
+ (last_end != (char *) MPI_AINT_CAST_TO_VOID_PTR
+ ( MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off) ) )
/* we have used up all our entries, and this one doesn't fit on
* the end of the last one.
*blocks_p -= (blocks_left + (size / (int) el_size));
#ifdef MPID_SP_VERBOSE
- MPIU_dbg_printf("\t[vector to vec exiting (1): next ind = %d, %d blocks processed.\n",
+ MPIU_dbg_printf("\t[vector to vec exiting (1): next ind = %d, " MPI_AINT_FMT_DEC_SPEC " blocks processed.\n",
paramp->u.pack_vector.index,
- (int) *blocks_p);
+ *blocks_p);
#endif
return 1;
- else if (last_idx >= 0 && (last_end == ((char *) bufp + rel_off)))
+ else if (last_idx >= 0 && (last_end == (char *) MPI_AINT_CAST_TO_VOID_PTR
+ ( MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off ) ) )
/* add this size to the last vector rather than using up new one */
paramp->blklens[last_idx] += size;
else {
- paramp->disps[last_idx+1] = (MPI_Aint) ((char *) bufp + rel_off);
+ paramp->disps[last_idx+1] = MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off;
paramp->blklens[last_idx+1] = size;
paramp->index++;
@@ -722,9 +728,9 @@ static int DLOOP_Segment_vector_mpi_flatten(DLOOP_Offset *blocks_p,
- MPIU_dbg_printf("\t[vector to vec exiting (2): next ind = %d, %d blocks processed.\n",
+ MPIU_dbg_printf("\t[vector to vec exiting (2): next ind = %d, " MPI_AINT_FMT_DEC_SPEC " blocks processed.\n",
- (int) *blocks_p);
+ *blocks_p);
#endif
/* if we get here then we processed ALL the blocks; don't need to update
@@ -774,7 +780,8 @@ static int DLOOP_Segment_blkidx_mpi_flatten(DLOOP_Offset *blocks_p,
MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT bufp) + rel_off );
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off) ))
@@ -787,13 +794,15 @@ static int DLOOP_Segment_blkidx_mpi_flatten(DLOOP_Offset *blocks_p,
#endif
return 1;
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT bufp + rel_off) ) )
else {
- paramp->disps[last_idx+1] = (MPI_Aint) ((char *) bufp + rel_off + offsetarray[last_idx+1]);
+ paramp->disps[last_idx+1] = (MPI_Aint) (MPI_VOID_PTR_CAST_TO_MPI_AINT bufp +
paramp->index++;
@@ -802,9 +811,9 @@ static int DLOOP_Segment_blkidx_mpi_flatten(DLOOP_Offset *blocks_p,
- (int) *blocks_p);
+ *blocks_p);
#endif
@@ -847,12 +856,17 @@ static int DLOOP_Segment_index_mpi_flatten(DLOOP_Offset *blocks_p,
+ MPID_Ensure_Aint_fits_in_pointer( (MPI_VOID_PTR_CAST_TO_MPI_AINT bufp) + rel_off );
@@ -865,7 +879,8 @@ static int DLOOP_Segment_index_mpi_flatten(DLOOP_Offset *blocks_p,
#endif
return 1;
diff --git a/lib/mpi/mpich2/src/util/mem/handlemem.c b/lib/mpi/mpich2/src/util/mem/handlemem.c
index 9c30067..a242e2f 100644
--- a/lib/mpi/mpich2/src/util/mem/handlemem.c
+++ b/lib/mpi/mpich2/src/util/mem/handlemem.c
@@ -312,8 +312,8 @@ void *MPIU_Handle_obj_alloc(MPIU_Object_alloc_t *objmem)
MPIU_DBG_MSG_FMT(HANDLE,TYPICAL,(MPIU_DBG_FDEST,
- "Allocating handle %x (0x%08x)\n",
- (unsigned) (MPI_Aint)ptr, ptr->handle));
+ "Allocating handle %p (0x%08x)\n",
+ ptr, ptr->handle));
#ifdef USE_MEMORY_TRACING
/* We set the object to an invalid pattern. This is similar to
1.5.3.7
More information about the mpich2-dev
