[mpich2-dev] [PATCH 4/4] Issue 4120: Fix dataloop copy to not update NULL pointers
Jeff Parker
jjparker at us.ibm.com
Sun Mar 30 23:54:12 CDT 2008
Function PREPEND_PREFIX(Dataloop_copy) copies a dataloop tree. It memcpy's
the tree in one chunk, and then calls PREPEND_PREFIX(Dataloop_update)
which fixes up pointers in the copy by adding the difference between the
src and dest. But, if the pointer being fixed is NULL, the copy gets a
non-NULL pointer, which is later used as the source of another copy, which
ultimately causes pointer overflow, and hence, the assertion that we added
for MPI_Aint work is hit. The fix is to only update the pointer if it is
not NULL.
Signed-off-by: Jeff Parker <jjparker at us.ibm.com>
.../src/mpid/common/datatype/dataloop/dataloop.c | 112 +++++++++++++-------
1 files changed, 72 insertions(+), 40 deletions(-)
diff --git a/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/dataloop.c b/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/dataloop.c
index 82f0530..054094b 100644
--- a/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/dataloop.c
+++ b/lib/mpi/mpich2/src/mpid/common/datatype/dataloop/dataloop.c
@@ -114,7 +114,7 @@ void PREPEND_PREFIX(Dataloop_copy)(void *dest,
* adding this difference to them. This way we can just copy the
* structure, including pointers, in one big block.
- ptrdiff = MPI_VOID_PTR_CAST_TO_MPI_AINT ( (char *) dest - (char *) src );
+ ptrdiff = (DLOOP_Offset) ( (char *) dest - (char *) src );
/* traverse structure updating pointers */
PREPEND_PREFIX(Dataloop_update)(dest, ptrdiff);
@@ -152,72 +152,104 @@ void PREPEND_PREFIX(Dataloop_update)(DLOOP_Dataloop *dataloop,
* LHS, so we get this much nastier form instead (using common
* struct for contig and vector):
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
- dataloop->loop_params.cm_t.dataloop =
- (DLOOP_Dataloop *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
+ if (dataloop->loop_params.cm_t.dataloop)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
+ dataloop->loop_params.cm_t.dataloop =
+ (DLOOP_Dataloop *) MPI_AINT_CAST_TO_VOID_PTR
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.cm_t.dataloop + ptrdiff);
if (!(dataloop->kind & DLOOP_FINAL_MASK))
PREPEND_PREFIX(Dataloop_update)(dataloop->loop_params.cm_t.dataloop, ptrdiff);
break;
case DLOOP_KIND_BLOCKINDEXED:
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
- dataloop->loop_params.bi_t.offset_array =
- (DLOOP_Offset *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
+ if (dataloop->loop_params.bi_t.offset_array)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
+ dataloop->loop_params.bi_t.offset_array =
+ (DLOOP_Offset *) MPI_AINT_CAST_TO_VOID_PTR
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.offset_array + ptrdiff);
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
- dataloop->loop_params.bi_t.dataloop =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
+ if (dataloop->loop_params.bi_t.dataloop)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
+ dataloop->loop_params.bi_t.dataloop =
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.bi_t.dataloop + ptrdiff);
PREPEND_PREFIX(Dataloop_update)(dataloop->loop_params.bi_t.dataloop, ptrdiff);
break;
case DLOOP_KIND_INDEXED:
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
- dataloop->loop_params.i_t.blocksize_array =
- (DLOOP_Count *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
+ if (dataloop->loop_params.i_t.blocksize_array)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
+ dataloop->loop_params.i_t.blocksize_array =
+ (DLOOP_Count *) MPI_AINT_CAST_TO_VOID_PTR
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.blocksize_array + ptrdiff);
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
- dataloop->loop_params.i_t.offset_array =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
+ if (dataloop->loop_params.i_t.offset_array)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
+ dataloop->loop_params.i_t.offset_array =
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.offset_array + ptrdiff);
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
- dataloop->loop_params.i_t.dataloop =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
+ if (dataloop->loop_params.i_t.dataloop)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
+ dataloop->loop_params.i_t.dataloop =
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.i_t.dataloop + ptrdiff);
PREPEND_PREFIX(Dataloop_update)(dataloop->loop_params.i_t.dataloop, ptrdiff);
break;
case DLOOP_KIND_STRUCT:
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
- dataloop->loop_params.s_t.blocksize_array =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
+ if (dataloop->loop_params.s_t.blocksize_array)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
+ dataloop->loop_params.s_t.blocksize_array =
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.blocksize_array + ptrdiff);
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
- dataloop->loop_params.s_t.offset_array =
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
+ if (dataloop->loop_params.s_t.offset_array)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
+ dataloop->loop_params.s_t.offset_array =
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.offset_array + ptrdiff);
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
- dataloop->loop_params.s_t.dataloop_array =
- (DLOOP_Dataloop **) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
+ if (dataloop->loop_params.s_t.dataloop_array)
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
+ dataloop->loop_params.s_t.dataloop_array =
+ (DLOOP_Dataloop **) MPI_AINT_CAST_TO_VOID_PTR
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) dataloop->loop_params.s_t.dataloop_array + ptrdiff);
/* fix the N dataloop pointers too */
looparray = dataloop->loop_params.s_t.dataloop_array;
for (i=0; i < dataloop->loop_params.s_t.count; i++) {
- MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
- looparray[i] = (DLOOP_Dataloop *) MPI_AINT_CAST_TO_VOID_PTR
- (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
+ if (looparray[i])
+ MPID_Ensure_Aint_fits_in_pointer(MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
+ looparray[i] = (DLOOP_Dataloop *) MPI_AINT_CAST_TO_VOID_PTR
+ (MPI_VOID_PTR_CAST_TO_MPI_AINT (char *) looparray[i] + ptrdiff);
if (dataloop->kind & DLOOP_FINAL_MASK) break;
1.5.3.7
More information about the mpich2-dev
